Everything posted by BANYAN
Perhaps also worth considering this design for 'rocking' the vessel of sandbars or the mud in ports? (Many ships in shallow ports sat on the mud when the tide went out.) By shifting weight/cargo fore or aft would perhaps raise the keel sufficiently to get her off? But, I think this would have been an addition or complimentary outcome, rather than a design feature? cheers Pat
- 508 replies
That's a ripper find Keith. Thanks for sharing these photos which proved a great insight as to how these lamps were made and assembled. cheers Pat
This is one very nice model Eberhard, especially at the scale you are working. Kudos! cheers Pat
A very different subject for your next effort Greg; did all that rust attract you I have seen some info that suggested both guns may be removed to make-way for the installation of four 87-inch missile launcher modules, carrying up to 12 missiles. Which version are you building? cheers Pat
- 47 replies
- Zumwalt
- Snowman Model
Some great research and discussion here - following with interest. Thanks guys. cheers Pat
- 508 replies
Interesting videos and info; thanks Isaiah. cheers Pat
Can't wait to see the planking going on this beauty; nice work Ian. cheers Pat
- 536 replies
- Quadrireme
- radio
Hi Rick, I am sorry that I have not looked into your build before this - my loss as you are producing a very nice model. I have had a quick look through but will go back and read-in more carefully. Quite the task you have set yourself for a first model. That said, you appear to be well and truly up to the challenge. If you had not mentioned your issues with hull symmetry I would have never known, it looks fine in most photographs. I too like your shackles, they are very effective especially at scale 1/96. The deck furniture is coming along very well and looks great. For someone who claims they are not very good at joinery, you seem to be doing a very creditable job of it. You asked about sealing your deck? Once I have completed my deck planking, I mask/tape off the known deck furniture areas (outer boundary to allow glue to take) and give it as coat of Testors 'Dull Cote' which is a flat/matt varnish. I find this helps to protect the deck planking (especially as they are much lighter coloured planks), and should I accidently mark the planks doing other work, I can simply give it a light scrape to remove the marking and recoat the area. I use small scrapers made from old scalpel or similar blades for this. Being matt finish small touch-pups do not show. I am very much looking forward to your further updates. cheers Pat
- 348 replies
- Flying Fish
- Model Shipways
That's a great outcome; and 'kudos' well deserved. cheers Pat
- 3,560 replies
- clipper
- hull model
That great that Mike and his daughter were able to come and personally view your excellent work Rob; I'll bet they were as thrilled as you. cheers Pat
- 3,560 replies
- clipper
- hull model
Archaeological Evidence for the Development of RN Gunnery
BANYAN replied to Steve20's topic in Nautical/Naval History
Thanks Steve, much appreciated. cheers Pat -
A wonderfully turned-out sectional model Dave; congratulations on her completion - it looks great! cheers Pat
- 143 replies
Hi Allan, I cannot recall where I came across the attached - note, it is annotated on the side as being an extract from an 'Ordnance Manual' (possibly USN sourced?). While the carriage furniture arrangement is different, the number and purpose of the bolts etc appears similar. Note that item18, while in a different location is listed as an eye for the 'training tackle'. A separate bolt (5) is placed forward of this atop the carriage bracket for the gun tackle, item 6 for the train tackle, and item 11 for the breech rope. Not sure if this helps to resolve the issue but does harken back to my earlier thoughts of the second eye being for a training tackle? cheers Pat
Party time indeed, and well deserved. your persistence in overcoming the many issues that arose has really paid dividends - the model looks great! cheers Pat
- 740 replies
- Tudor
- restoration
(and 4 more)
