Posts posted by bobandlucy
On 8/27/2024 at 2:11 PM, Blacksmith said:
I have most of the MS vehicles and I now have time to start building. As a newbie to wagons, I need help on which to start with - Buckboard or Doc Buggy. I know the Concord, Chuck, Conestoga, Medicine wagon, and Pumper are way down the line. I know I will have lots of questions.
I am building my second, the Concord Stage Coach, it has not been what I'd call an easy build. . . intermediate level maybe.
Have fun!
May I say that I never saw the appeal of this kind of figure modeling until now.
Thanks
bob
- mtaylor, Canute, Old Collingwood and 1 other
4
You are quite the builder! Love the shop, and glimpses of your yard.
bob
- Canute, thibaultron, Jack12477 and 2 others
5
Finished the "running gear," ready for painting. Tricky to assemble. The holes for the "hounds" (the two curved members penetrating the axle assembly) were considerably oversized, and it took me quite a while to figure out how to shim without throwing off other critical dimensional relationships. But I did it!
I don't expect nicely made metal castings, so I wasn't disappointed with those supplied with this kit! Spent a good deal of time cleaning them up and then correcting the shapes. But I am a very patient modeler. . .
The square-headed bolts are made from "escutcheon" nails. I squeezed them into a rough square shape in a vise, them filed the top flat and cleaned up the squeeze from the underside of the head. There are quite a few of these bolts on the model, so I'm getting better at forming them as the building progresses.
- mtaylor, Landlubber Mike, Jack12477 and 6 others
9
Very Nice! Interesting to see the differences between the version I built and yours. . .
bob
- Keith Black, Paul Le Wol, Glen McGuire and 1 other
3
1
1 hour ago, tmj said:
Now "THAT's" what I'm talking about! "Beautiful work, beautiful display! It can't get any better than 'this' unless Model Trailways starts putting real hair on their horses!
The horses/harnesses do look very nice. I'm not sure if I'll do them, but I will consider. . .
@Tankerman I don't recognize your model as a Model Trailways offering. It looks fantastic! Could you please explain it's function and origin? Is it something you scratch-built?
bob
- Egilman, Jack12477, Old Collingwood and 3 others
6
Planked the roof, and covered with provided cloth to simulate canvas. I used Mod Podge (new to me, mentioned in the manual) as the adhesive. Feels really solid now.
Added rub rails to the roof and painted flat black:
Made the passenger sway straps. I've been putting this off because initially I did not understand the instructions, but after re-reading a few hundred times it finally sunk into what remains of my grey matter. These four straps were my days work, and they are yet to be installed. The strap material is thin fibrous gasket material and is used to simulate leather. After assembly I gave them a wash of thinned paint, same as used for the "leather" seats inside the cabin.
I had soldered the baggage rails earlier, and this represents a big step forward for me. I chemically blackened them yesterday and am very pleased with the results:
Got the seats installed. I think it looks pretty good, except the bare wood of the seat and backrest bases can be seen between some of the cushions where spacing had to be adjusted. If I were to do over, I'd paint stripes before gluing on the cushions. I don't think this will be real noticeable after the cabin is completed, and the view inside will be only from the sides.
I've not been good about updating this log. Jumping around a lot, as I do- but shaping all of the seat and side cushions took quite a while. . .
Today I joined the sides to the bottom, which took a certain amount of swearing, but I'm happy enough with the results:
Was hoping to make the doors operable, but after many tries, was happy enough just to get them in as fixed in place. The compound curves make this very tricky indeed.
Work will continue on the undercarriage, which is very complex considering this time period, but for now I am enjoying the coach body more. . .
- mtaylor, Old Collingwood, yvesvidal and 6 others
9
I have joined the girls on the deck. Can someone pour me a whiskey? Rocks, please.
Bob
- thibaultron and bcochran
1
1
On 5/7/2024 at 4:50 AM, Wawona59 said:
Wonderful Doctor's Buggy Bob. I built this kit as a gift for my daughter who is a Registered Nurse and a horse lover. I recall having some issues with the soft metal springs getting out of shape. If I built another horse drawn model with leaf springs I might consider making them from scratch using brass strips. I really enjoyed building this model. I'll be checking in on your Stagecoach build.
BTW, I think your buggy came out better than mine.
Thank you very much, John!
Leaving the undercarriage/running gear aside for awhile, I started constructing the coach body. The process is very similar
to ship building; vertical pieces are added to outer framework, faired, then horizontal pieces added and faired:
The vertical framing members are held at the proper height off the work surface by sacrificial extensions, which are later removed.
Very clever. Designer Bob Crane, who also designed the Doctor's Buggy completed earlier, has done good work on both models.
Exterior paneling added to one side, will need minor filling/sanding:
Extensions removed at interior:
Very enjoyable project thus far.
I enjoyed building the Doctor's Buggy so much that I ordered the Concord Stagecoach and am well into it at this time.
Picture of finished model from the manual:
I see opportunity for lots of scratch-made doodads!
Starting the undercarriage:
Pins are soldered to the U-straps to simulate bolts:
Made a mistake in reducing the width and length of the wooden part of this axle assembly because the drawings showed them as matching. . .
This resulted in a poor fit of the U-straps as well as not providing enough stand-off for the wheels; I'll need to add material somehow:
Waiting on a couple of missing parts to continue with the undercarriage. So I assembled the wheels.
The wheels have a carved scalloped design between the spokes. Not easy to make these uniform in plywood!
I finished painted one wheel. The red and black decoration is done with Sharpie pens, which quickly stopped flowing
when used on painted wood. The decorations also came out somewhat wobbly. If I can do better on the other wheels,
I may re-do this one. The decorations are supposed to be on both sides of the wheel, but I may decide not to do them inboard. . .
12 hours ago, kgstakes said:
Are your hubs brass? Wood? Did you make up the wheels or did you buy them?
The Hubs are aluminum, furnished with the kit. I made the wheels using kit-supplied materials.
- Ryland Craze, mtaylor, Jack12477 and 4 others
7
18 hours ago, Landlubber Mike said:
That came out great! Nice job!
Thank you!
- mtaylor, Old Collingwood, Egilman and 1 other
4
18 hours ago, kgstakes said:
Very nice great job!!
Thanks!
- Old Collingwood, mtaylor, Canute and 1 other
4
I've kind of drifted away from the Syren model for a while. . . I have always been attracted by the Doctor's Buggy from Model Expo, and decided to build it. I'm glad I did- it was a lot of fun.
I'm done with the model and really did not take very many photographs. Hoping that one or two progress pics qualifies this as a "log."
Body under construction:
First attempt scratch-built Doctor's Bag, abandoned. The third attempt was successful, and consists of wood and wire frame and silkspan fabric:
Body mounted on undercarriage assembly (tricky) and Doctor's Bag installed:
Scratch-built Horse Whip under construction:
Finished Buggy, mounted on display board:
I did not get the wheels canted exactly right, but it seems stable and uniform, and will keep as is.
This is not an entry-level model, but I was well-served by the education I received in the progressive Shipwright's series, and I was able to rise to the challenge.
I have begun the Concord Stagecoach, also from Model Expo, and will try to do a more detailed log for that one. Hope you enjoy. . .
Bob
Sorry Capt. Joe- too much time has passed for me to give any meaningful advice here. . . I'll look at your log.
Bob
The Shipyard at Foss' Landing (Diorama) by gjdale (Grant) - FINISHED - SierraWest - Scale 1:87 (HO)
in Non-ship/categorised builds
Awesome! Seeing your work sent me to the Sierra West site where I settled on the O scale Sawmill Project. This one-man manufacturer, Brett Gallant, gives superb customer service at a level not experienced by myself, ever.
This is quite a different kind of modeling than I have done before and I look forward to the many hours it will take to construct. I'll look to your build for relevant tips and techniques. I will probably post a log on the S.W. site so as to benefit from the experience to be found there, but may show periodic progress here at MSW, as Chuck and admins. don't seem to mind posts of non-ship builds.
Thanks for the inspiration, Grant. If I can do half as well, I'll be happy.
Bob
