Posts posted by DocBlake
Nice work on the planking, Don! I use the same technique (weld bond and CA glues)) for my planking. The CA is a "liquid clamp" which holds while the Weldbond cures.
- Canute, zoly99sask, mtaylor and 5 others
8
Hi Mike!
I have a Byrnes saw which I use to do most of the finish work on the planks I use. I also have a full-sized woodworking shop for furniture building. I typically will use my band saw or full size table saw to break down planks into billets, and then use my planer or thickness sander to finish them. The Byrnes saw is the final step. I have the advantage of some great local suppliers of rough hardwoods,including exotics at very reasonable prices. You can get manageable billets at WoodCraft or Rockler stares in your area. Take a trip there and see what they stock...typically everything in 1/8, 1/2, and 1/4" thicknesses, and widths of 2 to6 inches (easy to cut on a Byrnes saw).
I'm at the Mystic Seaport Wooden Boat Show now, but I'll send photos of the rosewood when I get home on the weekend.
- Canute, mtaylor and Landlubber Mike
3
I've worked with black wood and it would look good. If you're looking for a little more character consider Bolivian rosewood. You can find pieces nearly black with strands of dark, dark brown and purplish grain running through them. I've used rosewood for the wales, black strikes and hatch coamings on my last several projects. A little warmer than "black-black". I'd consider yellow heart for the Morgan's ochre. I was aboard her today and that thought struck me before reading this thread!
- Canute, GuntherMT, CaptainSteve and 3 others
6
John: I think your doing a fine job with the first planking. I do agree with Mark about the plank next to the garboard strake. That curve at the forward end needs to be shaved down. It's creating a "bottleneck" effect that will interfere with the remaining strakes to be fitted
Thanks for all the comments and "likes" guys!
I'm working on the chainplates right now, making them out of 20 gauge copper wire. The blackening with Pewter Black is slower with the copper than it is with brass. I'm having to go back 2 or three times to get the effect I want. The Jax product is pretty cheap ($22 for 16 ounces, as opposed to about $7 for 3 ounces of Birchwood-Casey) so I'm not worried about going broke! I haven't purchased the cleaning solution, but I'll order some today and see how it affects the blackening of the copper.
John: I just drilled a hole through the front axle and used one of the famous "yellow nails" as the pin. Use the pin to pierce the deck and drill another hole in the deck ( #71 drill). Epoxy the pin in place before mounting the cannon. Put a little epoxy on the tip of the pin and slide it into the hole you drilled on the deck. It will hold the carriage in place and be invisible
Thanks, guys!
Don: Go for it! It's a fun build, and you can work on other things at the same time as I've done.
I remade the trunnions (they were too short) and blacken them with my new favorite blackening agent for brass: Jax Pewter Black. The stuff is amazing! Just paint it on with a brush and when black enough, wipe with a rag or paper towel. No "crusting" and I didn't do any acid washing or acetone rinsing like with Blacken-It. It also blackens solder. You should try it!
Each gun carriage was given a pin sticking down from the front axle to fix them in place and holes were drilled in the deck. The only things left on the guns are fastening the cap squares.
Excellent job on this model. Really first rate. I'll be visiting the "Morgan" during the Wooden Boat Show in Mystic, CT next week. The kit is on my shelf, also. I plan to take hundreds of pictures to use when I begin my build.
- Landlubber Mike and mrshanks
2
I think the hull looks great! There are always a few low spots to fill, but looking at your work I don't see too many! Keep going!
Nice start to the planking. It should turn out well.
- Seventynet, Elijah, EJ_L and 1 other
4
Slow going with the summer heating up. I did fit the cap rails at the stern of the ship. The kit doesn't include a taffrail so I made my own and installed it. It gives a finished look to the transom. The taffrail and cap rails are stained with Fiebing's leather dye. No poly yet. There are five roof beams for the great cabin to install, as well as 5 planks of cabin roofing in the midline, I'm planning to use swiss pear rather than holly decking stock, because technically, the roof is a roof, not a poop deck. Once those things are installed, there are just the stern lights to fabricate and the aft of the model is complete. I'd like to make my own stern lights out of holly. The kit has some nice 3-D printed windows provided, but I want to do it myself. I'm just not sure how, right now!
- gjdale, mrshanks, zoly99sask and 6 others
9
Phantom by Elijah - FINISHED - Model Shipways - 1:96 - New York Pilot Boat
in - Kit build logs for subjects built from 1851 - 1900
The garboard strake is important, and I think you've got it nailed, Elijah. Often it's allowed to "creep up" the bow, causing trouble in the planking down the line.
