Paul Le Wol
NRG Member-
Everything posted by Paul Le Wol
Hi Everyone, hope you are all doing well. Thank you very much for the Comments and Likes! The hull planking is finished. As the planks ran off the bulkheads and below the waterline, 1/8" blocks of basswood were added to define the waterline and add to the structural integrity of the hull. They were glued into place after the planking was installed to make it easier for clamping. Once the blocks had been installed the planks were planed down so that they were 1/16" proud of the blocks. The process started at the stern and moved forward. I had some Cleco type side grip clamps that had been used for metal work. They have a strong grip but didn't mark the AYC. They were good for the straight lengths. I got them from Aircraft Spruce. They are about 6.00 CAD each plus you need the pliers to put them on and take them off. I started making the tabs that are glued to the back of the planks longer so that they extended from both sides. This made them interlock with the previous plank's tabs. After the planking was completed they were sanded back to the waterline and the hull was mounted back onto the build board. I went over it with 120 grit paper but it still needs more sanding. Once the sanding is finished the rub rails can be attached. Hope to see you when the dust settles.
Ross, congratulations on completing Diana! She is beautiful. Good luck with your Essex build
Looking good Glen! Glad you could fly the original flag.
- 301 replies
- Constitution
- Bluejacket Shipcrafters
Best White Wood Glue For Ship Building
Paul Le Wol replied to OldeManToad's topic in Modeling tools and Workshop Equipment
Hi OldeManToad, welcome to MSW. I’ve been using LePage Multi Purpose White glue with good results. I like using white glue solely because it dries opaque. Even if the model is being painted I don’t like looking at yellow glue stains while it is being built. Have never tried Titebond. Good luck with your Albatros build. I should have said that it dries translucent. -
Ryland, congratulations on receiving the Jim Roberts Award and thanks for posting the great photo!
- 263 replies
- Medway Longboat
- Syren Ship Model Company
Glen, the deck houses are exceptional, especially the rails!
- 106 replies
- Kentoshi-Sen
- bottle
Hi Everyone, I hope all is good. Thank you for the great Comments and Likes. Just have a bit of a planking update today. I worked my way up to the rails and added support for the forecastle subdeck which will be 1/32" plywood. The model had to be removed from the build board and turned over to finish the fairing and planking down to the water line. Once that was done I started to focus on the counter. The first two strakes on Port and Starboard needed tapering, bending and twisting. A combination of CA and white PVA was used to keep them in place. My 2 year old Starbond CA was not up for the job so I picked up some Bob Smith CA. Read a lot of good reviews about Bob Smith and I completely agree with them. Support made from 1/8" basswood sheet has been added at the water line. The rest of the counter planks have a slight taper and run off the stern so back to using just white PVA. Next post I hope to be finished the hull planking. See you soon.
This is my take on the people in the photo. If the woman was the captain, she would be standing in the doorway of the pilot house wearing a big smile. She may be the captain’s wife/ daughter who had just brought him lunch. The captain is eating lunch in the pilot house because she wants to take the dishes home before they get underway again The man driving the car is a travelling salesman so the captain has to keep his eye on him during lunch. Those guys in the background are a whole other story.
- 732 replies
- Lula
- sternwheeler
Hi Kim, the wood effect on the masts and the painting of the eagle look great!
- 7 replies
- America
- Schooner Yacht
Jacques, just thinking out loud here but would it be possible to draw the stem on the drawing with the A and B cant frames. If the upper ends of A and B are the same distance apart as on the plan view then having the stem drawn there might get you close to the required length
- 139 replies
- ancre
- Bateau de Lanveoc
Keith, my thoughts and prayers are with you.
- 732 replies
- Lula
- sternwheeler
Thank you Glen, This is my favorite part of the job. (Not that its a job.🙂) Thank you Yves, I don’t think I’m up to the challenge of making a realistic sea base. I was thinking about getting a slab of 1/2 Corian countertop type material cut for a base. Something dark grey. Thank you Jacques, the jig worked well but wow did that take a long time! Thank you so much Keith.
Hey Everyone, thank you for the Likes and Comments. The are always appreciated! Planking has been moving along at a pretty good clip. The first plank laid was CA'd into the rabbet at the stem. Spacers were made that sit between the waterways and the longitudinal boards on the bulwark stanchions making it easier to maintain the proper run of the first strake. The strake above this one contains the freeing ports and the scuppers. The scuppers were filed into one plank port and starboard using a strip of brass with a notch filed into it. There are 21 scuppers on each side. The planks are edge glued and glued to the bulkheads using white PVA. Small tabs are glued to the backsides of the planks to help keep them aligned. A mold was cut out of a pine board in order to shape the planks running around the stern. The two trigger clamps pivot on their jaws as the planks are moistened and heated with a heat gun. These planks are attached with CA just at the centerline and then with PVA the rest of the way. I added some filler blocks where the port lights will go. The next photo shows the tabs behind the planks ganging up at the bow. And this is what she looks like today. The planks are not in scale but the wider planks are just easier to install and the hull will be painted. Once it is planked up to the forecastle and cabin decks the model will have to be tipped over and the lower bulkheads faired. Take care!
