Paul Le Wol
NRG Member-
Everything posted by Paul Le Wol
Hi Jacques, I could be mistaken but in one of the above pictures there seems to be a different type of material running along the ridge. Possibly for protection of thatch while working up there. Another boat has its sail (?) draped along the ridge. Something like this could aid in the snagging issues. Everything is looking great.
- 286 replies
Nils, what splendid work you have done. Another one of your creations where every time you look at it you see another story being told!
- 330 replies
Dave, the results of your labor are beautiful! Your Sharpie looks so good on that stand. Congratulations on finishing!
KLarsen, congratulations on finishing your Santa Caterina. She and her rigging look exceptional!
- 61 replies
- ancre
- Santa Caterina
Nils, the plumbing looks excellent. ( as well as everything else)
- 330 replies
Bryan, congratulations on finishing the Sea of Galilee boat. There shall be four very happy grandkids!
- 134 replies
- sea of galilee boat
- SE Miller
Jacques! Congratulations on finishing The Cargo Canoa. Looking great.
- 286 replies
Hi Seb, nice start to your build log.
- 33 replies
- Bounty Jolly Boat
- Artesania Latina
Seb, congratulations on finishing the Dinghy. Excellent work! Looking forward to the Jolly Boat.
- 8 replies
- Dinghy
- Midwest Products
Jeff, congratulations on finishing your longship. Beautiful work!
- 27 replies
- Slavic Longship
- Falkonet
Hi Jacques, I think both stain and paint look equally as nice. On the Cargo Canoa maybe you could slide a slice of black wire insulation or something similar over the pin of the upper pintle to fill the gap. Everything is looking great
- 286 replies
Mike, congratulations on finishing your skiff. Fine looking job!
- 18 replies
- Pot Pie Skiff
- Wye River Models
bbrennan! Congratulations on completing your dory. Looks great. Good luck with the Skiff.
- 19 replies
- Grand Banks Dory
- Model Shipways
(and 3 more)
Hi Jacques, I did the same as you. Started with a small drill bit and then enlarged the hole with a small round fill. It was easier to get a clean edge with the pear.
- 286 replies
Hi Jacques, everything is looking great. When building the Nordland Boat I had the same decisions to make on how to finish the inside of the plywood hull planking. It didn’t accept stain well at all. I ended up sealing the planks with a coat of Minwax wipe on poly . I then added some finely sanded pencil lead ,using a sanding block , to a small amount of wipe on poly. The poly turns black after a bit of stirring. When applied as a second coat and removing the excess, the planks had a grey look to them. At the time I described it as a mildewed look. Maybe there are other ways of tinting sealer. The fun is all in the experimenting
- 286 replies
Hi Kit, welcome to the forum. Good luck with your restoration. Great looking photos!
- 6 replies
- decorative models
- Restoration
