Oldsalt1950
Posts posted by Oldsalt1950
  1. Dave, I'll give it a try to help you understand what exactly a "yardarm" is. The outer section of a yard we all assume is the yardarm, and we are correct, but to explain a bit better, think of a person standing erect with their arms outstretched. In such a case we can measure what we call arm span, the distance from fingertip to fingertip. In this measurement we have included the shoulders. A yard is broken down the same way, and in just about the same proportions. The center section , some times worked or figured from round to octagonal or slightly bellied would be the distance proportionally from shoulder to shoulder, after that the arm section begins. The arm section of a yard is more tapered or worked to a smaller circumference just like the bones in a human arm get smaller on the way to the wrist.
  2. Weller makes a good soldering iron. Get one with a chisel tip. 30 watts should do the job easily. You will also need to think about solder and flux. This is where things get more interesting. Try to avoid acid fluxes. Trix makes a good low melting point solder and compatible flux that should meet your requirements. If you haven't soldered before, the trick is to keep a clean tip, meaning no contaminants and not over heated. Be sure and keep the tip "tinned" meaning a thin coat of solder on it. If the tip starts getting black wipe it clean on a damp sponge or paper towel and re-tin.
  3. It is the tannins in tea that stain the sails not the tea. The acid is neutralized once the sails are removed from the tea and rinsed. If you have any concerns about the sails degrading you can go to a pet supply store and purchase a simple aquarium buffer solution that neutralizes acid in water. A simple aquarium water test kit( get the strips) can be used for this purpose. Test your tap water, record the reading, then place the sails in the water and test again to see the difference, then follow the buffer agent directions to neutralize if needed.
  4. Dave, as you know i am currently building ME's Rattlesnake and it has been on hold. I am placing and order with Syren for all the blocks the hearts and cleats. I am also replacing all the planking then the rope. I looked over everything and can't really say i liked what I saw that was provided in the kit. The only cast metal part I will be using is the anchor proper. It will almost double the cost of the kit but it will also make it more to scale and aesthetically pleasing to the eye, not to mention the wood is easier to shape and work with.
    Jim
  5. If you look carefully at the gun port picture you can see there are modifications. There are no hinges. They added some sort of fixture to hold the port lid in the air (the rods are visible). Changes are made during every restoration. Some to enhance viewing of certain features some to try and get back to the historically correct configuration. You can only do so much to replicate what was on Victory during her prime.
  6. Chris, what if you broke the kit up similar to the way Chuck Passaro is doing the Winchelsea. You could even break up the instruction manual to correspond to how the kit is divided, sort of hull, deck and fittings, boats and cannons, masts spars and rigging. Just a thought. It isn't like anyone is going to speed build the Indy in a few weeks.
  7. I'd start with Model Expos ModelShipright series. They are designed to lead you along in the various aspects of shipbuilding. As far as tools are concerned, get a good miter box and razor saw, a knife (Exacto or Excel) a dual scale ruler inches /cm, needle nose pliers, a tweezer. Carpenters glue, sandpaper, some superglue, and a variety of clamps. A stand alone mirror, or one with clamps attached for those small blocks so you can see what you are working on. As your budget, time and skills increase you can add other tools as needed. Best of luck to you, and look forward to reading your building log whatever you decide to get.
