Oldsalt1950
Posts posted by Oldsalt1950
  1. The sails could have probably stood a little ironing. For the barrels, put a small eyelet into each side of the racks they are laying in and then tie them down. Nothing will be on the deck for anyone to trip over. Just lash the line around the barrels and through the eyelets and tie them off. For the anchors you could add two additional large cleats attached to the false ribs on the forward bulkheads and tie them up to them. I'd go with hanks of rope not coils. Pilot boats were usually very busy.
  2. The first thing I would do is mark the center of the piece while it is laid over its position on the plans to determine if both sides are off, if the slot for attaching to the center frame is also not off. Then take a measurement of how much you need to add to the piece. Usually there is some thin scrap you will have from taking pieces out of the laser cut sheets they are in, use this to make your shim if it is a little too thick that is okay as you will be removing some of the material when you fair the hull before planking. Glue the shim on with either wood glue or CA(super glue) and let the glue cure .
  3. A little heads-up to anyone about to build or thinking of building Ms's Rattlesnake. If you have read any of the build logs you know about all of us breaking the cross timbers on the forward and aft bulkheads. Decide ahead of time if you are going to install and rig cannons in all the gun ports. If not then place a piece of scrap across the knock outs in the aft bulkheads except for the most forward one. That knock out will be used for what would be the removable bulkhead. That bulkhead also needs to be built up and detailed and installed prior to planking the upper bulwarks or it is going to be difficult to put in place. With a little work, you can use the knock out for the removable bulkhead, but take into account the deck planking and waterway as you shape it.
  4. Welcome DeHammer. You got an excellent deal on the Bluenose kit. As Mark stated above, someone, namely me will suggest Model Expo. You might want to look at the Model Shipways Shipwright 3 Kit Combo Series. You'll get a lot of practice and some decent instructions with the kits. 3 boats, 3 stands, some so-so tools, paint, glue and not feel overwhelmed at the start. The current price is about $170 which works out to less than $60 per kit. The other nice thing with Model Expo is that if you break, lose, or screw up a part they will replace it for you at no cost. If the bug really hits you after you have assembled your kit(s) then look into some of the best kits out there namely Vanguard and Syren Ship Models. Both designers are members here. If and when you find a kit that sparks your interest, look at the building logs for that kit and see what problems or issues the builders had and also what they did to add additional detail. Above all though have fun, and ask questions we are a friendly lot.
    Jim
  5. Devin, you are doing great and have taken some very good work practices to heart. Making perfectly square ends when cutting stock to length is hard but if you mark the piece and clamp it in the miter box it won't move or flex, this should help. It took me awhile to realize that that was what was happening. Don't worry about how much time you are committing to a job. This isn't a race, enjoy the time you spend working on each phase and you will be rewarded in the end.
  6. Finally something to show. The exterior gunwale planking is almost completed. Will then add the cut outs for the sweep ports and sheaves, drill the holes for the scuppers and mark out the aft quarter light which is replacing the Britannia quarter light fitting. Attempted making the fancy molding ends, not happy with them, but may have a work around that will be easier. considering you have to round off a piece that is only 5/32nds square. Perhaps a dowel considering it is getting painted any way. Once the interior bulkhead is planked I'll be adding some color just to see what the ship is starting to look like. The current assembly has a bit of weight to it.
