Rustyj
Everything posted by Rustyj
  1. Working on the frames here and there is an interesting way they designed the sweep and gun port openings. As you can see from the plans they are all cut out prior to installing the frames. I used the Byrnes table saw and disk sander to make the cuts. The nice thing is that if they are off a bit I can adjust them as the upper hull is planked inside and out.
  2. Thanks Paddy, You know you can always have the plans reduced to the Triton scale. It would save a lot on the wood costs and completed size. If I had to purchase the wood in 1/2" billets I don't think I would have done it at this scale either.
  3. Hi David and E&T, Thanks for looking in. Sorry for the delay but I missed your posts. Well I’ve finished the Triton cross section and she’s safely tucked away in her case. Now it’s time to get back to the “set up”. Now where was I had left off? Oh yes I had completed the keel and now it is time to cut out the pieces for the frames. There are a total 17 frames 5 of which are doubles so that’s 22 frames to make. I will take and cut up the frame plans and use temporary paper glue to adhere them to the cherry billets. Then I will use the scroll saw to cut them out, over lay them on the plans and then glue them up using wood glue. It doesn't show but remember the wood for the frames is 1/2" (12.7mm) thick. And here is a single and double frame all glue together and the chocks added. Two down and a whole bunch more to go.
  4. Great start Bob. I look forward to your improvements and modifications. Should be fun for us all.
  5. Hi Glenn, I'm glad to see you are back and off to a great start. I'm also glad you are doing a build log of the Vanguard as I have her "on the shelf" and will use your fine work as a reference. Welcome back my friend.
  6. Hi Glenn, Good to hear from you again. I devoted the bulk of my time recently to finishing the Triton Cross section. Now it’s time to start things back up again.
  7. Hi Jim, I’ve used the foam center sanding sticks but never tried a paint stirrer before. Great idea.
  8. Hi Bob, Happy Birthday and congratulations on finishing up your build. Very well done. It was a joy watching along and I’m really looking forward to your Essex. I know seeing your work will tempt me to build her too but I must remain strong! Enjoy.
  9. Great work on the entire build Grant. That happy/sad moment of completing her is approaching fast.
  10. Hi Daniel, Sorry for the delay getting back to you but that four letter word "work" has kept me away but I'm back now. I'm glad you enjoyed following along. It was a lot of fun. The bomb vessel and Echo cross sections need some serious attention next.
  11. Thank you Antony, I’ve the two other cross sections (Echo and Bomb) to finish up and then who knows from there. Thank you very much David and Ron.
  12. Hi Grant, I too would like to echo the very nice job on the brackets.
  13. Thank you Kevin, Grant and Christian. Hi Paddy. No documentation. I saw it done that way in Chad’s build log, liked it so I did it that way too
  14. Thanks Pete. Glad to help when I can. Thanks Russ. Hi Augie. Thanks and I look forward to your new build. Thanks Grant. Just a 3 weeks then it's back to the workshop. Thanks Mark. No pressure needed with 2 projects still under way.
  15. Only one? Seriously you are doing a great job and well done on fairing the frames. They look great.
  16. Hi all, First off I must apologize for being tardy in responding to your kind words and comments. It is the bane of this time of year for me when my part time retirement job becomes a fulltime job and unfortunately starting Monday and for the next 20 days becomes an overtime job. Oh well it's the price I pay for a lot of time off in the winter. Thank you Greg. Thanks Mark. I was pleasantly surprised on how the case came out. Thank you Grant. Thanks Bob, Hard to say right now but knowing me both will get attention just not sure which will be primary and which secondary. It could change from week to week too. Thanks Kevin, the end is a happy/sad time for me too. Ok here we go. To finish off the base of the case I purchased some molding which enclosed the top but still allows for removal. It was all stained and sealed with polyurethane. I then attached the cross section to the base by drilling through the base and into the keel and then screwed the keel to the base. And here she is in the completed case. And some more pictures out of the case. Again I would like to thank Russ for all of his hard work in the beginning making this project possible and for his help and encouragement throughout not just mine but everyone’s builds. And then to all of you who continually helped, encouraged and proofed my efforts I give a heart felt thank you too.
  17. Very very nice Bob. Great idea on the bitts. Gotta remember that. I also see some bits and pieces for the gun carriages in the background.
  18. Thank you Antony and Pete. The display cover came from http://www.collectingwarehouse.com/. Not the cheapest but service was fast and the cover is first rate.
  19. Well I've installed the ladders and have started working on the case. Here are the ladders, The base is made out of oak. I used the full sized table saw to cut the recess for the plexi cover. And here is the cover in place. As I said before the cover was purchased on line as I did not feel comfortable making it on my own. (AKA Lazy) Gotta finish up the case, just a few fiddly things to do and clean her up and we should be done.
