Posts posted by goatfarmer11
Amazing work, well done sir.
- John Ruy and VitusBering
- 1
- 1
3 hours ago, Bob Cleek said:
"Thread drift" is an inherent danger is any forum discussion. It's just as well to head it off at the pass. Back to the subject of hull construction:
You are certainly free to build your hull however you wish and, regardless of the construction method you choose, you will have to do some drawing to generate additional transverse body sections, as Wefalck has described so well. That said, I would urge you to carefully study the shape of the classic steam launch hull in which "form follows function." The shape has been developed with speed and the high-torque low-RPM steam engine's power in mind. (One determining factor being the necessity of the larger diameter higher pitched steam propeller.) Framing and planking the elegant shape of the steam launch's elliptical fan tail counter stern is, in my experience, the most complex and difficult framing and planking job of all stern shapes. Contrasted with the ordinary transom stern where the planks run fairly flat to a relatively vertical sternpost and are "sawed off" at the transom, the fantail launch stern with its long shallow run aft, requires that the planks take a significant twist between the point of maximum beam and the sternpost rabbet, which transitions from relatively vertical at the keel to relatively horizontal at the deck. Therefore, I strongly urge you to seriously consider employing the "lift" or "bread and butter" construction method for such a model hull. The relative difficulties between the alternative construction methods in this instance are at opposite ends of the difficulty spectrum.
See: https://www.gartsideboats.com/custom-boatbuilding/22-foot-steam-launch-design-123.html for a sequential photographic demonstration of the construction of a plank on frame steam launch hull. (Plan and photos below from Paul Gartside's website.)
Thank you Bob and I appreciate what you are saying. I am truly not interested in the bread and butter method at this point for many reasons. The most important is this is not how I "imagine" building a model boat. I also feel that a 42 inch long hull as Miranda has would require far more carving to fair than my skills will permit. I foresee needing gallons of filler and lots of sanding and still not having a fair hull.
However, after looking at the link you shared in the previous post I am now thinking building something similar to how that launch was built could result in the finished product that I so desire. Is this the "lift" method you mention? The look of the closely spaced bent frames is what I see in my head when I think of such a boat from this era. I think if I milled some 1/8" x 3/8" cherry to be bent for the frames the end product could be spectacular.
- KeithAug, mtaylor, FriedClams and 1 other
- 4
2 hours ago, Innisfree said:
I'm sorry. Unsolicited commentary is, apparently, one of my character flaws. I see you are headed for great things with this build and I continue to watch and learn right alongside you.
No apologies necessary Jack. I agree with you totally that more frames will make a better hull in the long run. The problem only comes from me learning to "design" them. Commentary is always appreciated and this time it is just pushing me to learn something new. As stated by Bob Cleek learning to loft opens up a whole new world of possibilities and that is a good thing. Thanks for following along and I too hope she ends up being a great build.
- FriedClams, mtaylor and jpalmer1970
- 3
1 hour ago, wefalck said:
Exactly, you don't want to red-design the hull, but only to develop intermediate bulkhead/frame stations. That's why I suggested the above procedure that only requires basic drawing tools. You can actually substitute the flexible ruler with a piece of stiff copper wire that you straighten first and then bend to the desired shape. Very thick soldering wire would also work. It has to be just some wire that is not springy.
Yes, and now I have done some reading up on the subject I am going to attempt to try this soon. Perhaps a little practice and I will build a basic understanding and confidence of the procedure. Thank you.
- FriedClams, mtaylor, jpalmer1970 and 1 other
- 4
Ok...now we are jumping to conclusions that aren't really necessary. Let me start by saying that Miranda was a boat designed and built by Basil Harley in 1985. The build was published in Model Boats magazine and this includes the steam engine and boiler that he used in her. I am following these plans and the frustrations only began when it was suggested to me that more bulkheads would make for an easier to plank hull. I agree with this and have only been wanting to figure out how to do this. By removing the bulkheads and using frames instead, the inherent weight change in the hull should be minimal. The steam plant and the boat have been built by others and and she sails just fine. I am not designing this vessel but simply making some minor changes.
As far as the engine and steam plant go I am very comfortable with the fabrication of these. I am fairly new to steam as in I have not yet built a steam plant. I have been studying steam engines, boilers, condensers, water pumps burners, etc. for a couple of years now. I am by no means an expert on the subject but I consider the subject well studied and am now ready to build my first engine and boiler. I will be using the powerplant designed by Basil Harley for Miranda so lets just say the plant "should" be just fine for the vessel. I am aware of the proper materials and methods to build and test a pressure vessel of this type in a safe manner. Live steam is what led me to Miranda so the model boat building is very new to me and once I am satisfied with her hull the rest can begin to come together.
I appreciate the comments and concerns but lets not take this project too far off its course.
Thanks
Unfortunately my "plans" have no line drawings at all. They simply have drawings of the bulkheads so how to loft anything from them I am not sure. I went back and checked the article of the boat in Model boat Magazine and there is no mention of line drawings there either.
- mtaylor and Keith Black
- 2
2 hours ago, wefalck said:
Denis, I don't think 'scratchbuilding' is so much more complicated than working with a kit. It's question of doing things systematically.
Didn't the proposal of bread-and-butter construction come up in earlier discussions? One of us may have mentioned it as a method for making a core from which to take an empty hull using GRP. It can be relatively materials- and cost-friendly, as one can use insulation foam-board for the core that is to be discarded. Fairing the core between the template stations can be done by eye. However, you have to learn working with glassfibre mats and polyester resin.
Agreed, I think my point of starting with a kit might make it a better learning experience as having instructions might teach a better "order of operations". There is much for me to learn and that I am willing to do. Whether I am able is to be determined.
- mtaylor, Keith Black and FriedClams
- 3
Thank you Bob for your well thought out reply to my problems. I had not given bread and butter a thought until now. It has been my intention of creating more frames as I go along but I've had problems understanding the basics of lofting new lines drawings. Perhaps a good book can help me through this. The reason I have ditched the idea of bulkheads is to keep the inner hull as unobstructed as possible so I will have plenty of room for all of the necessary equipment for this build.
It may seem that starting with a scratch build is a bit over my head and starting with a kit may have been a better idea. However after looking at kits they do not fit in my budget for this summer. Maybe putting Miranda on hold is the best idea. Maybe I should get more complete plans for a different vessel and build some experience with that? I will say even as frustrating as it may seem I have still been enjoying this journey so far.
Lots of food for thought and I appreciate the input. I have some decisions to make.
- FriedClams, Keith Black, jpalmer1970 and 1 other
- 4
May I add as a new model builder I was not even aware of these tapers. Now that I am I may feel compelled to include them to some degree. This is why I joined this forum, so I could learn about the details that can make a good model a great model.
- mtaylor, allanyed, Knocklouder and 6 others
- 9
I hope those of you following along aren't going to get sick of me but I have, for the third time, restarted Miranda. For whatever reason, the plank on bulkhead method just isn't working for me. It doesn't seem to be what I envisioned when model ship building entered my mind. I want to make Miranda more in a style that she would have been originally built at the yard. My methods are certainly not authentic to the original but the finished product may be closer to the real thing.
I have started by bending and laminating some of the ribs for her.
And I have started to build up the Keel to make it stronger than the one piece board that I started with.
I think I am going to be much happier having an open hull and after fiber glassing it should be plenty strong enough. It will also give me places to put things like radio gear and fuel in the stem and stern.
I also took the time to make a build board from 3/4" melamine. I learned the importance of this so I can take accurate measurements as I progress through this hull to make sure things are following the contours and remain square, I have attached a sketch of the hull to the board to help maintain the lines.
More to come in the near future and as always comments and suggestions are welcome.
To build in such a small scale amazes me, very nice.
- Keith Black, Gahm and mtaylor
- 3
This looks like a wonderful kit you are starting with, I would like to pull up a chair and follow along.
I just found your build log LegoKing, it looks like things are coming along nicely. I'll pull up a chair and see her through completion.
1 hour ago, KeithAug said:
Denis - I bought an old mahogany table which had worm in some of the soft wood framework. It proved to be low cost and very good quality wood. You might want to consider getting some old mahogany as it is much better quality than the modern stuff.
I have already told my wife that we will be on the lookout for old furniture left beside the road or at yard sales. It seems a good source for some good ship building lumber. Thank you
- FriedClams, Keith Black and mtaylor
- 3
17 minutes ago, KeithAug said:
What wood are you using for planking Dennis? Are you double planking?
I've opted for Poplar for planking. I found a board I didn't even know I had that has been in the barn for several years so I chopped it up. If all goes well on the first layer I may use mahogany for the second layer. That is to be determined.
- Keith Black, mtaylor and FriedClams
- 3
Another update to my build log. I got caught up to where I was before...
And after trying to fit the extra bulkheads I tried to draw I found I am no good at lofting lol. I was not happy with their fit at all so I will not be using them. I did practice bending some 3/8" x 3/8" cherry and I think I may try to fit some "frames" between the bulkheads. I only got 1 minor crack and it should not be a problem. I will have to do it by trial and error but I think in this way I can adjust them to be a perfect fit.
I began fitting the gunwales and am very happy with the curvature of them this time. Everything flows smoothly as it should. I have one more layer to put on those and I will lay some dummy planks to get the shapes for the frames I am going to add.
Thanks for following along.
- FriedClams, wefalck, GrandpaPhil and 7 others
- 10
It looks like things are coming along nicely Papa Duke. I'll pull up a chair and follow along.
Todays progress was slow but unlike last time I spent more time cutting the bulkheads to get them as accurate as possible. I cut outside the lines and sanded to the lines. I now have 10 bulkheads instead of 5 but after fitting them I can tell that the 5 extra that I created are not going to work well. I do think I can modify them as I go but this will be a slow process. I have gotten a whole new respect for ship designers. I believe I may spend some time to learn proper lofting techniques. Life would be so much easier. Here is where I ended today...nothing has been glued as it only got up to 43* F today and I feared the glue would not hold well. I also want to do some more fitting of the bulkheads that I tried to create to smooth out some lines.
Thanks to those of you following along and offering advice.
- GrandpaPhil, KeithAug, mtaylor and 3 others
- 6
7 hours ago, KeithAug said:
Denis - over the coming weeks I am going to be generating a lot of intermediate frames which may be of some interest to you.
Definitely looking forward to that! Thanks
- KeithAug, FriedClams and Keith Black
- 3
Sea of Galilee Boat by Knocklouder - FINISHED - SE Miller - 1/20 scale
in - Kit subjects built Up to and including 1500 AD
That turned out beautiful, thanks for sharing your build.
