Decoyman
  • Gender
  • Location
    Crowmarsh Gifford, UK
1,238 profile views
  1. I use my Byrnes saw for a lot more than just shipbuilding and one thing I think would be helpful is to have a longer table as well as a wider one. Or at least an extension before and after the fence to support longer, more flexible pieces.
  2. I should try the hot (soldering?) iron trick. Up until now I have assumed that the small contact area would be disadvantageous, but, on the other hand, the associated cost is essentially zero, if you already have an iron. Thanks for the suggestion.
  3. I'm thinking of getting one of these, with the strap: https://luthiers-bench.com/products/bending-iron This is because I might build a lute, but also because I can see the use for shipbuilding. Rob
  4. Charles, Your explanation of Scrubby's fence - if I understand you correctly - suggests there is a machined 'bow' to the blade side. I've checked mine and it is dead straight. Perhaps Jim has changed the design of his saw, but it looks to me as though the whole fence is misaligned. Also the blade seems offset in its slot, although that might just be the photo. Attached are photos of my saw showing the fence almost exactly parallel with the guide slots in the table and the slot for the blade. IMG_4338.HEIC IMG_4336.HEIC
  5. Thanks, Charles - i'll look them up. Kind regards Rob (Decoyman)
  6. That's really helpful - thank you again. All I have to do now is find a piece of 22 mm aluminium....
  7. That's very helpful, thank you. I have a lathe too, so I might have a go at turning up a spacer. If it's not too much trouble, how do you normally do this? Best wishes Rob
  8. Thanks, Keith. Both, actually. I have two broken teeth on the carbide-tipped blade that came with the saw and my slitting saws are blunt!
  9. Can anyone recommend a supplier for blades for the Byrnes saw in the UK? Not having much luck finding anything and the odd company that seems to have something vaguely similar (for example, same diameter, wrong sized arbor) is remarkably expensive. Rob (Decoyman)
  10. Because the algae needs light to grow, I would have expected the green to be nearer the top of the waterline and not at all on the underside of the hull. Like this shot of the QM2. http://www.dailymail.co.uk/news/article-2575169/Adrift-sea-Extraordinary-photos-captain-Queen-Mary-II-standing-largest-ocean-liner-world.html#i-b8cc0eab
  11. A bit of an American-centred view of the world, I think, Ron. The Euro may be falling against the Dollar, but, within the Eurozone there is no change. Why would you sell nothing to a market of 500 million while you are waiting for the exchange rate with a market of 300 million to turn in your favour? It doesn't make sense.
  12. Nothing more at the moment, I'm afraid - it's a long time since I sat through a seminar on historic glass! Sorry. Rob
  13. Hi Druxey. Superb model, which I have been following avidly. I think cylinder glass in some form was available much earlier than the early 20th century. Many Georgian and Victorian houses over here have quite large panes of glass in them. I look after this building: https://en.m.wikipedia.org/wiki/Claremont_(country_house),where the original glass panes are substantial. I'd be happy to measure some for you, if it would help. This website: http://www.sashwindowslondon.org.uk/info/history-of-glass-manufacture.html has a potted history of glass referencing cylinder glass, polished plate glass, etc as available at the time of the Greenwich barge. Best wishes Rob
  14. Do they fit the Byrnes saw without adaptation?
