Everything posted by Ponto
On with the Gun Ports....the full scale plans were used as a template to transfer the openings and after measuring and remeasuring (and remeasuring) ...the gun ports were knocked out with straight edges and a scalpel. The holes were expanded to accommodate the inserts which will eventually allow for final planking and the rebates allowing the gun port lids to open and close. Some preliminary ideas on color scheme are being tested... The wales will definitely be black and I thought the brass cannon set on the black gun port sills might be attractive. Probably not too authentic but I let that ship sail long ago.....I'm using soft basswood on the gun port sills and debating switching too something a little more durable... the basswood is easy to work with but not very forgiving and shows every little mishap. LOL... still working with the text and image placement --- I hope it all makes sense --- and thanks for looking in..... JP
Vince,... I admire your determination and the results are evident. I'm also working thru "issues" with my Euromodel kit and I feel your pain. When all is said and done, I'm sure the model will scream Vince P. rather than Euromodel!!!! JP
- 593 replies
- royal william
- euromodels
Really nice and tidy workmanship! JP
- 222 replies
- 18th century longboat
- model shipways
How to best measure Rope....Make a handy chart for yourself.
Ponto replied to Chuck's topic in Masting, rigging and sails
Love it,.... simplicity in form yet the differences (however minute) are readily discernible by eye ----- and I never would have thought it! The proof is in the chart and thanks for that................ JP -
All good points and pretty much my philosophy and thoughts on the subject,.... how do even measure and tell the difference between .018 and .021 line??? JP
....scratch builders......... jp
A superb effort Chris... 6 years well spent! jp
- 290 replies
- confederacy
- frigate
Thanks everyone for your likes and patience with my rants. The first planking is complete aside from the stern which needs to be buttoned up after some test fitting with the supplied castings. I'm quite happy with the symmetry and the shape along the hull from all perspectives. At this point, only the gun deck is glued in place and the other decks fit accurately with my preliminary pin placements. I suppose my next plan of attack is knocking out the openings for all the fire power.........and then fitting out the gun deck ---- I don't know if there is any advantage to finish the final planking with wales or to complete the gun deck beforehand.............. JP
Hi Simon,... thanks for looking in. I understand the "issues" with the supplied bulkheads can be overcome with some effort, but, having said that, I'm thinking that I didn't get very good value for what the kit cost me initially. Compared to my investment on Corel's WVH ( I caught it on sale) and what that kit entailed, .... I think I over paid for the Euromodel kit! You're definitely correct with your assessment of the plans ,... they are inconsistent and can be quite frustrating. I'll try to keep my gripes to a minimum however, and will not give up on her........stay tuned for my rendition of the Le Renommee ---- it will be one of a kind! JP
Well, I must be doing something right, ...(but only after double and triple checking my initial effort). While the linked build log took 4.5 years to complete, it's interesting to note that similar challenges were encountered during the initial stages of construction....namely, the suspect accuracy of a number of the supplied bulkheads. Future Le Renommee builders should be prepared to address this. After all is said and done, I'm quite sure that no two of these Euromodel kits would end up looking the same,... and I suppose this is a good thing from where I stand. I wonder if this is unique to the Euromodel brand or just a general result of wooden ship models? JP
While my intent is not to direct anyone from this site, I would recommend the link supplied by Nigel as an additional source of reference........for those interested in the Le Renommee kit, the Russian builder was quite ambitious and did carve his own ornamentation and spent some time on the kit before completion. I use the build log often since for support since the Euromodel step by step instructions are sparse....... I promised myself I would tend to the weed "issues" in the yard today but now it is raining so may as well spend time in the shipyard ... how convenient...LOL......Anyway, here are some progress shots for those interested........... ***I recently learned that the waterline is not necessarily parallel to the keel... it needs more than one measurement from the plans and in this case, is "shorter" towards the bow. Also, and it may not be apparent from the photo, I did taper the keel according to the plans,...the width is narrower toward the bow and stern while the bulk of the width is found amidship. Thanks for looking in and enjoy......... JP
There are some very special builds on this forum and this one can certainly be considered as very special!!!! JP
I've used quick setting epoxy with success in these instances,....and your stern is looking fabulous, by the way..... JP
- 593 replies
- royal william
- euromodels
After the the drama of my last posting I decided to switch gears and initiate the first planking. At the pace I build, I need to go back to the drawing board and teach myself techniques and pour over the many resources offered at this wonderful site. The images show my progress to date. When the hull is filled in up to the gun deck, I will turn my attention to the deck planking and its fitting out. Thanks for looking in...... JP
.... an extremely special accomplishment,... your efforts and the results are overwhelming!!!! JP
- 227 replies
- cumberland
- 74 gun
Pandora by marsalv - FINISHED - 1:52
Ponto replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Nicely done,.........one to follow for sure!! JP
