Everything posted by schooner
Finishing the Cheeks and Hawse Bolsters The half of the cheeks that rest on the hull were made of 1/8” thick strip wood the same width as the stem cheeks and the moulding was made from plastic rod. The hawse bolsters were placed at the outboard corners of the head grating: After painting and the addition of the figurehead the stem is pretty well set with the exception of the slot for the gammoning, which as can be seen, I’m still in the process of drilling and filing out: The instructions call for drilling out the hawse holes as one of the last steps in the build which did not make a lot of sense to me since it would have been really hard to clean up all the tear-outs on the inside of the bulwarks with all the rigging in place so I did it now. To help cover up the tear-outs I added interior bolsters which I have seen on other builds from this era.
- 142 replies
- alfred
- solid hull
Starting the Cheeks and Trail Boards The cheeks are large structural assemblies that help strengthen the stem. There are usually 2 parts; one on the stem and one that continues along the bow, on or above the wales. The cheeks on the stem have another layer called the trail boards which usually have some decoration, or at least some moulding. The kit provides a brittania metal piece for the trail boards. It is different than the shape of the tailboards on the plans and from the general shape of my stem area: I traced the trail board from the plans, at least as much of it as was shown, the outermost part literally disappears up the figurehead's backside but the general shape can be assumed. I like this shape better so I will go with it: Since the cheek under the trail board was supposed to be trimmed to match the shape of the trail board I will effectively be combining them into one piece. I shaped it out of 1/8” stock and glued them on each side of the stem: Once in place the stem cheeks should be tapered to that their outboard ends will fit inside the opening on the back of the figurehead. The kit-supplied brittania figurehead was a pleasant surprise. It needed no cleanup at all and the detail is amazing: The rear opening of the figurehead is well done, the lower half is slightly wider to accommodate the combined widths of the stem and both cheeks and the upper half is slightly narrower where all the rails will fit into (hopefully): After tapering the figurehead sits snuggly on the end of the stem, and although I don’t show it here, its’ top is right about 1/8” below the bowsprit, as called for in the plans.
- 142 replies
- alfred
- solid hull
Bowsprit & Jib boom I finished up the bulwark area around the bowsprit by raising the stem to support it and then penciled in the locations for all the “stuff” that goes on the bowsprit. The height of the bowsprit cap is from the plans but I had to go to AOS Essex for the width, about 40% of the height is good: The instructions call for tapering the jib boom, which I did. I recommend skipping that step for 2 reasons; the tapering is not noticable on such a small dowel, and more importantly, the tapered end lost its' rigidity - it would have been a huge hassle trying to keep it straight while under tension from multiple directions, assumming it didn't break. I redid it without tapering. Here’s the completed bowsprit and jib boom: Here’s the bowsprit dry fitted in place. The paper you can see on the stem below it is a template I’m going to use to scratch the trailboards.
- 142 replies
- alfred
- solid hull
Things start to get complicated I thought my next step would be per the sequence laid out in the instructions, i.e. adding the details along the bulwarks working fore to aft, so I thought I would start with the catheads (the davits that the anchors hang from) but I ran into a problem that will take me in a different direction and hopefully not into a rathole. The problem is that the plans only show the catheads on the outboard profile (the side view of the ship) and since the catheads are located where the bow has it’s very bluff curve I could not figure out where they get placed (an overhead view would have solved this problem). After a lot of looking at the instructions, the plans, build logs of contemporary models and the instructions for ModelExpo’s SYREN, which are, hands-down, best set of instructions I have ever seen, I finally figured out that the catheads need to be above the hawse bolster (the holes where the anchor hawsers pass thru the hull), which in turn is part of the whole complicated head railing assembly. (BTW, the SYREN’s instructions are available online , as are the ones for all the ModelExpo kits on their website) After a lot more studying I think I understand how the head rails go together (every set of instructions I looked at said the head railings were the most difficult and complicated part of 18th century ship models) I realized I would have to tackle the head railings but before I could do that I needed to assemble the bowsprit for 3 reasons: 1) I want to rig the gammoning (a bunch of figure 8’s that lash the bowsprit to the hull) before adding the railings since it will be very difficult to do it after they are in place 2) I want to ensure that the gammoning is vertical which will depend on the slot in the stem the “hole” in the grating, and the chocks on the bowsprit, and 3) because I need to ensure that the figurehead, which although decorative is a key part of the head rail assembly, is not going to interfere with bowsprit which sits right above it. So bottom line: I’ll be departing from the build sequence in the instructions because of all the interrelationships of the “stuff” around the bow/stem I’m going to try to stay out of my own way and avoid bad language when finding out I should have done step 10 before step 2, so to speak. I’ll try do document each step and also what doesn’t work for those who may decide to try this kit. To get started on the bowsprit I had to do some plastic surgery where it will pass thru the bulwarks. When I added them I left a gap that needed filling at it’s bottom so the bowsprit will sit at the proper angle: I tapered the aft end of the bowsprit so it will sit properly (it, of course has not been cut to length yet) I also filled in the gammoning slot which had been cut in the stem early on since I will have to drill out a new one based on where the head rail grating sits. You can slo see a paper template for the the tailboards which I plan on making from scratch so they will be a better fit for my stem that the kit-provided britannia pieces.
- 142 replies
- alfred
- solid hull
Nice job cutting & filing - your seams look great (as does your smooth primer coat).
- 30 replies
- Red Baron
- Bluejacket Shipcrafters
Deck Planking Finished The instructions call for making the vertical bulkhead at the aft end of the main deck from the scribed decking material but I thought that would be a hassle trying to get a good fit at the outboard ends so I used planking strips placed vertically and topped with another strip that covered the ends and served as a flush piece for the quarterdeck planks to but up against. The quarterdeck planking went on without any problems and the reveals provide decent visibility down into the gun deck.
- 142 replies
- alfred
- solid hull
Avi, I have not built the Connie but I am building BlueJacket's ALFRED and I seem to recall the same issue with where to set the profile around the stern. I think your blue line might be correct because that is where the bulwarks end but when you get around to adding the transom it will be convex (bending aft) and it's center line will reach the red line. Bottom line - no need to cut to the blue line just now, wait until you hear from some folks with experience on this kit. You can always shorten the bulwarks later but it would be harder to lengthen them.
It's really hard to see any difference in the sponson locations based on the photos - especially with the flight deck on. That means it probably won't be obvious to anyone looking at the finished model. But if it bugs you, you could, as you said, relocate the sponsons but before you do that you might want to verify that the flight deck is parallel to the keel. Be careful - measurements like this are easy to screw up. You would need to make sure the hull is sitting on a flat surface (not a book), that it is level athwartship (i.e. not listing port or starboard) and then check the height of the flight deck (actually I mean the part of the hull that the flight deck sits on) along it's whole length. Using just a ruler and eyeball will likely give you some pretty unreliable data - you would need some sort of jig to run along the hull. Something like a high school football goal post with the crossbar held in place by clamps so it can be adjusted might do the trick. You could set it so the uprights stradle the hull and the crossbar just touches the forward edge of the deck and then move it aft - you will be able to see if the height is constant. If you think you have a problem you should come up with another way of checking it and verify there really is a problem before you do any sanding. As I said at the start, just based on your photos I think you are OK now.
- 25 replies
- Gambier Bay
- BlueJacket Shipcrafters
Main Deck planking completed The planking for the main deck is completed - I’ll wait until after it’s done on the quarterdeck before I clean all the saw dust out of the gun deck. Next up will be installing the short vertical bulkhead that divides the main deck from the quarterdeck.
- 142 replies
- alfred
- solid hull
Good luck Avi! She is not an easy choice for a first build but as you have seen on the Connie build logs on here it can be done, and done well. Best advice I can give is go slooooow. Take each step as a project in itself and forget how much is left to do. If you measure 4 times and cut once you should be in good shape.
Starting the Deck Planking I’ve got the centerline portion done. It’s been a real 2-steps forward, 1 back as I relearn how to do this. It would have been easier to plank the centerline and then add the hatches on top of it and cut holes for the bitts but it is really hard to clean up sawdust and debris from the gun deck with all the beams in place so I decided to do it this way. Next I’ll fill in the bow area back to the 3rd beam and then add 1 or 2 planks along each side.
- 142 replies
- alfred
- solid hull
Jep, glad you were able to get this one going again. If you need some references for what kind of stuff was on the catwalks you may want to go to the New Steelnavy site (steelnavy.com), look under "model gallery", select "aircraft carriers". About 2/3 of the way down the list there is the USS Kallin Bay - a very large model at Naval Aviation Museum in Pensacola and then down almost at the bottom of the list is an album of a 1/72 scale scratch build of the Gambier Bay.
- 25 replies
- Gambier Bay
I hope you have as much fun with it as I did. Good luck!
- 30 replies
- Red Baron
Fitting the Margin Planks My planking strips are 3/32” wide. I needed the margin planks to be a little wider and was able to find some 1/8” strip of the same thickness. The curvature at the bow is too severe to edge-bend the strips so I had to cut it out of sheet material. I traced the forward edge of the deck off of the plans on to a piece of paper to serve as a template. I only took it as far aft as the point where the planks will run straight. After a bit of trimming I had an acceptable fit: I then traced the outboard curve of the paper onto my sheet material, used a Dremel sanding drum to get a pretty close fit to the traced line and then, kept test firing the wood onto the deck, sanding and filing until the wood had a good fit. Next I set a compass at 3/32” and followed the outside of the curve to set the inside curve and the width of the forward, curved plank: A scarp joint was cut into the aft end of the forward plank and transferred to the forward edge of the next piece moving aft: The margin planks for the main deck are now in place:
- 142 replies
- alfred
- solid hull
Thanks Nic, should continue to be a lot of fun - until the rigging starts
- 142 replies
- alfred
- solid hull
Deck Furniture in place All the deck furniture is now in place. A couple of the items are dry-fitted and will be permanently attached one the planking or rigging is done.
- 142 replies
- alfred
- solid hull
Deck Framing and Furniture for Quarterdeck The deck beams and framing are done for the quarterdeck (which really pushes the term quarterdeck since it take up just over half of the ship’s length). The deck furniture is also done: Next up will be installation of the deck furniture and fabricating the margin planks and then it will be time to plank the decks.
- 142 replies
- alfred
- solid hull
Main Deck Framing All the main deck framing that I intend to add is in place with the exception of the athwartship pieces for the mast partners - I’m going to wait on those until I have the lower masts tapered, I want to avoid having them interfere with the mast rake and ideally, help set it.
- 142 replies
- alfred
- solid hull
Main Deck Beams and Deck Furniture All the deck beams are in place: The deck furniture for the main deck is done. The capstan is a solid piece of britannia. For the windlass the kit provides 3 britannia pieces; the 2 end pieces and the central axle with gear. The plans show “something” just forward of the windlass axle but it’s not clear what it is and the photos show the ship’s bell mounted above the axle but it’s not clear what it is mounted on. I figured it had to be where the ratchet/pawl assembly was so I made up my own and mounted the bell. The windlass will not be mounted until all the rigging is done around the foremast because otherwise it will be in the way. The belaying pins are very nice, good shape and to scale but I will probably be cursing them in a few month while I'm trying to handle 2 pairs of tweezers in the middle of a jungle of rigging to tie off a line. The openings in the large hatch cover are for the anchor cables to pass down thru.
- 142 replies
- alfred
- solid hull
Wow. There are some very impressive Syren builds on this site but I'd have to rate yours the best. Amazing craftsmanship. Syren will probably be my next build and I expect that I'll be using your build log as much as the kit instructions. Thanks for taking the time to make such a detailed, well illustrated log.
- 950 replies
- syren
- model shipways
