Jim Lad
Moderators
Everything posted by Jim Lad
  1. Interesting, Ken. On British ships the balls on the standard compass are usually referred to as 'Kelvin's balls' after Lord Kelvin, the inventor of the (more properly called) quadrantal correctors. Also on British ships, the port ball is usually red and the starboard one green! John
  2. A very ambitious project, Adrian, but as Druxey indicated, you certainly have the skills to do it. John
  3. Mark, I'm not sure that even epoxy will hold them safely without any sort of mechanical assistance - there's a heck of a lot of pressure on them once the shrouds are tightened up. How about a pin or two through the planking just to assist the epoxy? John
  4. Hello, and a warm welcome to the forum from 'Down Under'. John
  5. Beautiful work on very small parts. The stud link cable also looks very good - of your manufacture? John
  6. Congratulations on the completion of a superb model, Adrian! John
  7. Hello Pavel, and a warm welcome to the forum from 'Down Under'. John
  8. Hello Tim, and a warm welcome to the forum from "Down Under'. John
  9. Michael, Almost all of the running rigging, apart from the braces, runs down inside the shrouds/backstays or straight down the mast to pins at the foot of the mast. Is there any particular item of rigging that interests you? John
  10. Hello William, and a warm welcome to the forum. John
  11. Just catching up, Bob. She really does look the goods! John
  12. Looking good, Dan! The hawse pipe covers are (or were) a very common fitting on merchant ships. The idea was to stop water from squirting up the hawse pipes and over the deck when the ship dipped her bow into a sea. They usually simply consisted of a flat steel plate shaped to fit over the top of the hawse pipe and around the anchor cable. They were held in place by angle iron bars down each side of the hawse pipe and which they slipped into. Mostly they were fitted with some kind of simple handle to make sliding them on and off easier. John
  13. Hello, and a warm welcome from 'Down Under'. John
