Posts posted by captainbob
Yes, the tape is self sticking with a waxed paper backing. As for the plating, there was two was it was done. One was to start at the keel and lay the above panel overlapping the one below. The other method was to lay every other row of plating (1-3-5-7), then go back and lay the other rows (2-4-6) overlapping both the row below and above. According to the plans the Mariefred was plated by the second method.
Bob
She's beautiful. Well done.
Bob
- Omega1234, jay and kees de mol
3
Thanks Patrick, it was a fun learning experience. So I guess I'm not too old to learn yet.
Bob
Thanks for the "fix". After almost a week with no updates I was getting anxious. Great detail work.
Bob
- Omega1234, popeye the sailor, Piet and 1 other
4
Thanks Nils, Yves and Keith,
I referred to the aluminum as foil. Really it is an Aluminum tape used to tape the duct work in heating systems. Sorry about that.
Bob
- popeye the sailor, KeithAug, cog and 5 others
8
Hi All,
I have to move away from research for a while to build a little more. Or I will know everything there is to know about the Mariefred and never build her. The Mariefred is a very early (1903) steel boat. So like Nils (Mirabell61), I had to plate her, rivets and all. Maybe I shouldn’t say so but it was a lot easier that I thought it would be. The main problem is finding the right foil for the job. Most of what I found at the hardware store was too thin and doesn’t look right. There were four or five brands where us non-professionals find what we want. But walking down to the end of the store where the contractors go, I found the heaver foil that is needed. I found an old clock gear that I made into a ponce wheel and with just a little practice . . . here’s the results. I’ll accept it as a first try. Now paint and on to the rest of the boat.
Bob
I use Draft Sight. I believe it is an old version of Auto Cad. A free copy is available at
https://www.solidsolutions.co.uk/solidworks/free-tools/2d-cad-draftsight.aspx
Solid Works Puts it out to interest people in drafting. At least that is what I've been told.
Bob
Glad you're safe and alright.
Bob
- Omega1234, qwerty2008 and mtaylor
3
Thank you for the info. But that means, the air stream most be very slow or, it would blow away the part you want to solder.
Bob
- thibaultron and mtaylor
2
I must have missed something. What is the advantage of the hot air over the iron?
Bob
2
She's beautiful, let me know when she's ready to sail. I want to book passage.
Bob
- mtaylor, Chasseur, Mirabell61 and 3 others
6
She's a beautiful boat. Thank you for letting us watch your build.
Bob
- popeye the sailor, mtaylor, PeteB and 4 others
7
Thanks, Popeye.
Thanks to all of you. The curved portion is frequently referred to as an eyebrow. But under the eyebrow there is some sort of carving. That's what I'm looking for.
Bob
Bristol Pilot Cutter by michael mott - 1/8 scale - POF
It's nice to see more of such a beautiful boat.
Bob
