captainbob
Gone, but not forgotten
Everything posted by captainbob
  1. NO NAILS! I agree with your choice to try silicone to hold the brass. If that does not work rough up the inside and use epoxy. Bob
  2. Our prayers and good wishes go with you. Bob
  3. And looking very good. Bob
  4. Looking good, Vaddoc. And yes the mast top always looks busy with the shrouds, stays and halyards all coming together in one place. Bob
  5. Thanks Pete and David. "Are you going to stain or paint her?" Ah yes that's the big question. She's a Coast Guard ship whit a steel hull that was probably painted Navy gray. Steel, hum, that means no wood grain showing doesn't it. Hum. Well hopefully it will be a surprise, Maybe to me as well. Ah yes, just like a Zen master, I never know the end results until it happens. Bob
  6. I'm with you, Patrick. I always look forward to my next update. Bob
  7. I do almost everything in bass. Where strength is needed I use ply and I may use other woods for trim. But Bass is the wood I use most. Bob
  8. Not much done but the hull is getting there. Here are pictures of the bow. stern and rudder area. Bob
  9. Tom, Welcome aboard. I went from drafting board to AutoCAD in the early 80's and then to SolidWorks in the mid 90's. When I came back to AutoCAD in retirement I had to learn 2D all over again. Ah the joys of ageing a lot of things are new again. Bob
  10. Thank you Nils but it looks like the hull is welded except for the bow post. The main deck house and rails are riveted and the top deck is wood. Bob
  11. Dimitris, please come aboard and join the party. the more the merrier. Bob
  12. While at Michael's you should have asked for "seed beads" they are the little glass beads that are made into bracelets and such using a loom. Bob
  13. Glad to have you aboard, Lawrence. Grab some popcorn from steamschooner and join the party. Bob
  14. All kinds of suggestions but in the garage you can get away from it all, just hope the garage is heated. Bob
  15. Frank and Wayne, You're not late, I barely got started. Glad you could make it. Bob
  16. Thank you Gerty it was a fun build. Mark, I found several line drawings. Since I could not check them against the boat I checked the three views against each other and the drawings in the book won. Julie, Thanks for the complement and the list of books. Bob
