Everything posted by captainbob
	Patrick, I hope you realize that what you are doing is imposable. On the other hand it's a fine job. Bob
- 1,083 replies
	If the epoxy is worked well into and through the glass cloth the glass will disappear and it becomes like a heavy varnish but it takes some practice to get rid of the air trapped between the fibers of the glass. Thinning the epoxy with alcohol will help. Use a very light weight cloth like 1/2 ounce. You don't need a lot of strength for a model. Women's nylon hose is strong enough. Bob
	What a lovely work space. I'm sure you spend many happy hours there. I sure could. Bob
	Finish on the hull depends on usage. If it is in the water as a one time thing then any good poly or paint will do but if you plan to sail her many times then use epoxy. No mater how well it is sealed the wood will swell and shrink with getting wet and drying. On one of my boats I used epoxy inside and out without the glass and after a couple years of use I can see light between the planks. Bob
	There are dredge cable rollers on the rails on both sides of the boat even with the dredge winder. The rollers protected the sides of the boat as the dredge was being taken in or out. Bob
	Thanks, Jack. I guess the Pequot at 166 feet hadn't gotten around to adding the 'W' to it's number as of May 1944. Or maybe the 'W' was a book keeping thing and not necessarily shown on the boat. Bob
- 348 replies
- pequot
 - cable ship
				Can't Find Thin Brass Strips
captainbob replied to mikiek's topic in Metal Work, Soldering and Metal Fittings
Go to Specialshapes.com like George said. That is where S&K gets there brass and then they repackage. Bob -
				Lettering
captainbob replied to chborgm's topic in Painting, finishing and weathering products and techniques
irfanview Thanks. Bob -
	Ken, thanks for the camouflage color information. The Pequot was a Coast Guard boat that worked up and down the east coast of the US in the ports and bays. I don't think it was ever camouflaged. The black and white pictures show it always had a dark hull and a white deckhouse. Bob
- 348 replies
- pequot
 - cable ship
	Some designers knew how to create beautiful boats and still make it easy on the builder. Bob
- 258 replies
- buzzards bay
 - herreshoff
	Thanks for going into such detail on your build of the Heroine. It is interesting to see the similarities and at the same time the differences to later riverboats. Bob
	Thanks Ken. The white I have is more of a warm white but going towards the gray makes sense. I'll have to look into it. Bob
- 348 replies
- pequot
 - cable ship
	Phil, none of us started out as master craftsmen but as we build we get better. So start a boat with a build log, we're all here to help. Bob
- 2,625 replies
- kaiser wilhelm der grosse
 - passenger steamer
