Everything posted by wefalck
France is entering an almost complete curfew tomorrow. We've done our shopping, but normal working life from home continues for me, with modelling in the evening. Good luck down under !
Good to hear ! Actually, I would be very much interested to see more about your locomotive pursuits !
- 2,215 replies
There are two issues: not to spread the lead carbonate dust and to stop further corrosion. Just mop up the dust wet, not dry. Covering the lead parts in an impervious layer of paint may help, but there is no guarantee. A dry atmosphere helps. Avoid all acids.
- 77 replies
- point berlin
- diorama
There is at least one quite good book on her foe, which might give some transferrable details: BOWCOCK, A. (2002): CSS Alabama. Anatomy of a Confederate Raider.- 191 p., Rochester, Kent (Chatham Publishing). Rigging practices may have differed somewhat between the RN and USN, but the various books on HMS WARRIOR might also provide insights into warship fitting out and rigging details of the 1860s. Plus of course the huge amount of research Pat has done ...
This looks like the dreaded lead-corrosion, which is why museums ban its use in new models. Be cautious when mopping it up, not to inhale the dust. It would also be better not to use the affected parts. If you have the possibility, make a mold and copy them in resin.
- 77 replies
- point berlin
- diorama
As a matter of fact, there may be various types of alloys behind what people use as 'white metal'. Today Cd-free versions are common. The composition determines the melting point and the viscosity of the molten alloy, hence the capability or otherwise to fill fine parts of the mold. Unless you are going to work with it on an industrial scale, I would not be too concerned. Depends also what you mean by 'working with it'. Just handling ist not a problem and presumably you would wash your hands anyway, when you get out of your workshop. If you grind or file it to any large extent, perhaps a dust mask might be a good idea, but really only, when you generate a lot of fine dust that could be inhaled.
- 77 replies
- point berlin
- diorama
I would assume this is white metal. I have thoroughly decreased it with acetone and then spray-painted it with acrylics without a problem. Railway modelers tend to use an etching primer, but they handle their models. If you just install the part and don't touch it afterwards, you probably get away without priming.
- 77 replies
- point berlin
- diorama
Miniature Desk-Top Laser-Cutter
wefalck replied to wefalck's topic in Modeling tools and Workshop Equipment
I actually do have quite a bit of experience in doing the drawings for etching and have done some reasonably successful etching at home. The drawings as such are not the problem. My main obstacle was always to produce masks in which the black was sufficiently dense and uniform. The wet process part can be mastered, but is a nuisance (though I am actually a sort of chemist by training). I try to begin with that side of the drawing that has most details on it. For instance, the 'outside' of parts with rivets and such surface detail. I complete all the drawings that are going onto one fret. I arrange the drawings and then draw the fret together with register marks (a white dot with a cross-hair) in each corner. All this is 'grouped', as my CAD software calls it. The group then is mirrored. After ungrouping I can edit out all the detail, or add more detail, for the opposite side of the parts. By proceeding in this way, I ensure a (theoretically) perfect register of the drawings. The problem could be in practice, that the cutting software does not align two drawings perfectly to the zero point. Or the somewhat flimsy construction of the cutter does not ensure that the carriage with the laser returns to the same origin within a 0.05 mm. With the small parts I am producing, I need such close tolerances. I have no immediate intentions to try this out, as my needs are more or less satisfied with the pieces cut from paper. The problem with building from original drawings is that you have to develop all the model drawings and in order to keep track of things, this is done in an iterative fashion, iterating between drawing and building. Hence, I have been trying to turn etching into an ad-hoc process, as you would use say a lathe or mill. Otherwise, etching becomes very expensive, as you might not get it right in the first try. -
The problem is that the cutting software does not allow to superimpose images, it does not have 'layers', as CAD software would have. Therefore, I am afraid it would be 'eyeball MK1'-registration ... If you do surface etching, it is not just mirroring the drawing. You will have to produce two different drawings that have to register perfectly. A very laborious procedure with a lot of scope for error. I usually make one drawing, mirror it and then change it. -
Thanks for the kind words and the 'likes' ! ******************************************* The hydraulic recoil-brake The 30.5 cm gun in pivot-carriage C/76 was one of the first guns in the Imperial German Navy that was fitted with a hydraulic recoil-brake, at a time, when compressors and brooks were still the standard. The recoil-brake consists of a long cylinder with screwed-on cylinder-covers at both ends. The covers are pierced for piston rods and are sealed with packed glands. The piston rods are fixed at the front and rear end of the carriage respectivly. The piston is designed as self-opening one-way valve. The cylinder is filled with glycerine through a valve on top. The front-end cylinder covers acts also as cross-head and the upper carriage is linked up through two short forked connecting rods. The cross-head runs on a kind of slide to support the weight of the brake. The two piston-rods are only connected by the short piston, which also acts as valve, and that would not be able to support the weight. Working drawing for the parts of the hydraulic brake When the gun is fired, the upper carriage slides back and the piston is pushed through the glycerine, converting the kinetic energy of the recoil into heat. The valve in the piston prevents the upper carriage from sliding back into firing position. In order to bring the gun forward, the rear end of the carriage is raised by turning the excentric bearings of the rear wheels and opening the valve in the piston. To facilitate this, the rear piston rod is hollow and a spring-loaded valve-rod extends beyond the piston-rod. The valve rod can be srcewed in and out by the aiming gunner using a long lever. In this way he can let the gun roll back into the firing position in a controlled way. Unfortunately, not much of the hydraulic brake will be visible on the finished model, so that it was reproduced in a somewhat simplified way. It consists of five parts. The individual parts of the hydraulic recoil-brake (the grid of the cutting mat is spaced 5 mm) The piston rods were fashioned from clothes pins of 0.6 mm and 0.7 mm diameter respectively. Clothes pins are very suitable for piston rods, as they have a nicely polished surface. The eye of front piston rod was milled/filed from the head of the clothes pin. The cylinder was turned in one piece together with the covers from a short length of 2.5 mm round steel. On the micro-mill a hole was cross-drilled for another short piece of steel that had the cross-head pins turned on. This piece was soft-soldered into the cylinder cover. The packed gland is compressed by a hexagonal nut, for which the hexagon was milled on in the dividing head in the same set-up. The forked connecting links were laser-cut from paper and consist of three pieces each. The bronze housing for the valve spring was turned from 1 mm brass rod. The valve lever will be added at a later point. Dry-fitting of the recoil-brake into the lower carriage. It’s kind of a pity that the recoil-break witll be barely visible once the upper carriage is in place. Two grills for the guns crew and a protective tunnel over the rear end will hide most of it. To be continued ...
Indee, I could make a jig to locate both, the cutter, as well as the sheet metal, but the problem I expect is with the alingment of the images on the screen. One has to load the left and the right sides consecutively. However, with a carefully designed procedure it should be possible. -
I didn't get around to give this a try, but I have the idea of covering some brass with a thin layer of black paint and then burn it away for etching. This would do away with the step of having to create masks. It should work for single-sided etching, but getting the brass aligned properly for burning on both sides would be a bit of challenge. -
I gather specific rigging plans and details are difficult to find, as they were to a great extent ‚shop practice‘. However, there are various textbooks and seamenship manuals that cover mid-19th century practices also for steamships from which one could reconstruct the rigging.
I have just added to the original post a screenshot of the cutting software user interface -
Actually, it is not a K40. The 40 stand for 40W and this is a completely different anyímal. Once I had it hooked up to my wife's old MS Windows XP mini-laptop and downloaded the driver, I was seriously working on it within minutes. The learning curve was not with the machine itself, but hitting the right cutting parameters for the material and drawing in question. -
A few month ago I acquired a KKMoon K4 3W miniature desk-top laser-cutter and it has proven to be a useful investment. Therefore, I would like to share a few operational insights, though you can find a variety of ‘test’ videos and the like on the Internet. As with many Chinese products of this kind, it comes in various guises and configurations that may be mechanically identical or not. The traders’ descriptions are often somewhat haphazard and also suffer from translation issues. I am not sure, whether KKMoon is a trader or a manufacturer, their Web-site does not actually list these laser-cutters. Prices between the different offers on the Internet marketing platforms can vary as much as 30%. However, I paid just over 100€, shipping included. Image of the laser-cutter as advertised The stated main specification of the machine I bought are - Size: about 155 mm x 166 mm x 143mm - Weight: ca. 600 g - Laser Power: 3 W (3000 mW) – blue = xxx nm wavelength - Engraving Area: about 80 mm x 80 mm (3.1" x 3.1") - Engraving Depth: about 1 mm /0.04" (Adjustable in the range of 0-1 mm) - Mechanical resolution: 0.05 mm = 512 dpi - Supporting System: for Windows XP / 7/8/10 and MacOS 10.10 or later - Supporting Image Format: JPEG / JPG / PNG / BMP - Connectivity: Micro USB B to USB A (cable included) - Frame Material: ABS The laser-cutting system consists of three main components that determine its capabilities: the mechanics, the control board, and the software. Mechanics The mechanical resolution of 512 dpi is not that brilliant, if you compare this with modern scanners or printers, but then mechanics have their price. The 3 W diode laser has an adjustable focal point. Control Board I know next to nothing about electronics and commercial products, such as the control board that is being used in this machine. It would be particularly interesting to know, whether the board could be driven by other types of software. Perhaps someone from the Forum community has insights into this. Driver The software consists of two components, the driver and the cutting software itself. The driver is a standard piece of software under MS Windows and either comes with your MS Windows configuration or can be downloaded from the software producer’s Web-site. The driver runs under MS Windows XP/7/8/10. I am using an oldish mini-laptop with MS Windows XP on it. The driver unfortunately does not run under MS Windows emulation Parallels under MacOS 10.7.1, nor under the iOS for the iPad pro. The cutting software, however, seems to run in Parallels under MacOS 10.7.1. It should also run under MacOS 10.10 and higher, but I could not test this. Cutting software The cutting software is a very simple piece and is based on bit-image processing. In other words, the image is processed line by line from the top down and whenever a black pixel is encountered, the laser flashes. As noted above, the software can handle JPEG-, JPG-, PNG-, and BMP-files, but not TIFF. Images of up 1600 x 1600 pixels can be processed. There are three variables that can be adjusted to control the cutting process: the laser power in %, the cutting depth in 0.01 mm increments, and contrast (0 to 256). It is obvious, what the power adjustment does and I assume the cutting depth is determined by the length of the laser pulse. The cutting speed cannot be adjusted explicitly. What influence the contrast setting has is not completely clear to me, as the screen appearance of the image changes, even when I use a 0/1 b/w bit image. In practice, however, it does change the width of the cutting traces. The image to be cut can be freely moved around the cutting area of 80 mm x 80 mm on the screen. Screenshot of the cutting software user interface Set-up The machine is mobile and in principle does not require any special set-up apart from a flat surface. However, any energy penetrating the material cut will be taken up by the surface on which the machine stands. This means that the material has to be fire-proof. I happened to have a piece of roof-slate at hand, which turned out to be very useful for the purpose. Pieces of marble or tiles would do as well. The laser beam needs to be focused onto the material to be cut. The machine comes with a piece of black cardboard for the purpose, but this is thicker than many of the materials to be cut. It is better to focus the beam on the material in question. The laser spot is very bright, making it difficult to see, whether its size is minimal. I found it useful to illuminate the cutting area with a strong table lamp so that the contrast is reduced during focus setting. The material to be cut needs to lie absolutely flat. I have been thinking of making some clamping rails or similar. It turned out that short tabs of cellotape are quite sufficient for the purpose. The small pieces of material are just taped down at each corner onto the slate. Cutting times I did not make systematic tests, but the examples shown here took about 10 minutes to cut. I would estimate that covering the full 80 mm x 80 mm cutting area would take in the order of about one hour. Steering wheels cut from 0.15 mm thick Canson paper (120 g/m2) (cutting area about 40 mm x 40 mm) Capabilities Whether a material can be cut by laser depends on a number of properties of the material in question. First of all the material must be either combustible or it must be able to be evaporated. The material must be capable to absorb enough energy to reach its combustion point or its evaporation temperature. Whether a material can absorb enough energy depends in turn on a number of factors. A key factor is its albedo, in other words, how well the material reflects or absorbs light. Bright and shiny materials reflect most of the light, as do white and light coloured materials. Hence they are not absorbing enough energy. Conversely, dark and in particular black materials absorb most of the light that is shot at them. Another factor that determines how much energy is needed to combust or evaporate it is its volumetric density. Compact materials with no pores contain more mass per volume than porous materials and hence need more energy per volume to combust or evaporate. The volumetric heat conductivity is also important. If the material conducts heat well, the energy transmitted may become dissipated before it reaches the flash-point or the boiling-point. While in theory virtually all materials could be cut with a laser, in practice the available laser may just not be powerful enough. In practical terms this means that it is not possible to cut metal and transparent or translucent materials with this small laser. The 3 W laser just does not impart sufficient energy to melt and evaporate metals. Not surprising though. Plexiglas or tracing paper let all or too much of the light pass and therefore cannot be cut. Bakelite paper has a high evaporation temperature and is translucent. It can be cut through in thicknesses of up to 0.1 mm, but edges become charred. A strategy can be to only cut part through and then brake off the part along the cutting. This works only for simple shapes with straight edges and not too small parts. As set of doors (ca. 11 mm high) cut from 0.1 mm bakelite paper White polystyrene is too reflective and is only lightly engraved, if at all. I did not have black polystyrene at hand to try this out. I would abstain from cutting PVC due to the generation of toxic and corrosive combustion products. I have not tried ABS or Lexan, but would expect similar issues as for polystyrene. Celluloid might cut well, if you have a coloured variety. Transparent celluloid, including drafting films such as Ultraphane, will not work. The high flammability of celluloid may be an issue. White paper works moderately well due to its high reflectivity. An important factor is also its weighing and seizing. Weighing with barite or titanium oxide makes it more difficult to cut, as both materials are refractory. A seizing with glue or plastic polymers increases the volumetric density and therefore make the paper more difficult to cut. Coloured papers and cardboard work best, but thicknesses above 0.5 mm become more difficult to cut. The deeper the cut the more charring of the edges will occur, loosing precision in size and reducing the minimum size of features that can be cut. I have not had the opportunity to cut wood, but I would expect that low-density woods cut better and then hardwoods. The size limitations are likely to be similar to those of cardboard. Cork should cut reasonably well, but I have not tried it myself. Drafting for cutting As for any other ‘machining’ operation, the ‘tool’ diameter is an important consideration. The effective diameter of the well-focused laser-beam is in the order of 0.1 mm. These leads to the rounding of internal corners in this order of magnitude, but the actual rounding depends also on the size of the opening to be cut. Smaller openings may have a more perceptible rounding than larger ones. In practice, the charring of the edges leads to slightly larger openings than those drawn. Thus the diameter of e.g. holes needs to be drawn 0.1 mm less than required. Similarly, slots should be chosen 0.1 mm narrower than the nominal width. The laser sends a pulse for each black pixel encountered. When converting vector drawings into bit images, the question arises of the actual size of the parts that appear white in the final image to be used in the laser-cutter. This may depend on the line thickness chosen and the kind of drafting program. I found that I needed to experiment with the cutting parameters (power setting and contrast) and in some cases needed to redraft (parts of) the drawings in order to arrive at the correct size. Several iterations may be needed to arrive at the correct size. This also depends on the material, thicker material requiring more adjustments. Every part that is black in the drawing will be burned. In order to reduce the laser time and the fumes generated, it is good practice to fill in any empty space. While this would be good practice in photo-etching too in order to safe etching fluid, often this is not done. However, when converting drawings for laser-cutting it is a good idea to fill in the empty spaces. I use a 2D CAD system for drafting (EazyDraw™). This program allows the drawing to be exported into picture formats such as JPG. The resolution for this step has to be chosen so that the final part has the correct size for a resolution of 512 dpi or 202 pixels per centimetre. This means that a part that is 1 cm long should be 202 pixels wide in the JPG etc. file. In order to reduce the area to be burned, I usually import the image into Adobe Photoshop Elements™ and whiten all the respective areas. Sometimes is also convenient to draw the parts in solid black, which then necessitates their inversion in Photoshop. I typically export the drawings at 1024 dpi and then reduce the image in Photoshop to the desired width in the number of pixels as calculated for 512 dpi after the post-processing has been done. This allows me to ascertain that the drawing has the desired size. In this way it is also easy to produce cutting designs in various scales from the original drawing. As the cutting happens on a flat surface and there is no mechanical interaction with the material, the cut pieces do not move from their place during the cutting process. Therefore, retaining tabs, as you would need in photo-etching, are not needed and the parts can be completely cut out. This avoids the problem of distortion during separation from the fret, particularly of very small parts. A typical JPG-image as used for the cutting process (size around 35 mm x 30 mm) Safety Lasers are dangerous for the eyes and you are advised to consult the respective guidance on laser safety. The laser-cutter comes with a green protective glass on one side. I also bought a pair of green safety-glasses for adjusting the laser focus, as viewing the focal point through the shielding glass is inconvenient. The combustion fumes of certain materials can be a nuisance, noxious, or carcinogenic. In any case they are smelly. As noted above, it is wise to reduce the areas to be burned in order to minimise the amount of combustion products. For certain materials some kind of forced aeration may be needed, or you need to set up the laser-cutter outside. Some materials may also be a fire hazard. However, none of the materials I worked with seem to have been problematic in this sense. There would not be enough mass to sustain a serious fire, but a fire-proof base is important. In any case: never leave the machine running unobserved ! On the Internet you can see people, who have encased their cutters and added forced ventilation to it. Whether such arrangement is warranted, depends really on how intensively you use it. In my case it just runs occasionally for a few minutes at a time. Conclusions This technique cannot fully replace photo-etching to produce small, complex and delicate parts, but is is a versatile ad hoc option requiring little preparation in comparison. The cost of materials is minimal and therefore that of trial and error. There are no chemicals to manage safely, but fumes can be an issue. There is no equivalent to the ‘surface etching’ process, parts are strictly two-dimensional. As in photo-etching, there is, however, the possibility to build up parts from several layers. Metal surfaces and its edges can be made very smooth. Achieving the same effect with paper or cardboard is difficult, even when treated with wood-filler to produce some sort of compound material that can be sanded. In some applications that surface roughness does not matter or may be even desirable. The mechanical resolution of 512 dpi and the diameter of 0.1 mm of the laser-beam impose limitations to the minimum size of parts that can be produced. Laser-cutting with such small desk-top machine cannot compete with commercial etching processes using high-resolution masks. In scratch-building, when parts need to be developed as the building goes on this kind of laser-cutting certainly is a useful ad hoc and flexible process.
Of course, 'ponte' in Italian means 'bridge' as in e.g. Ponte Rialto. It also means the 'bridge' on ships. I don't know the etymology of the Italian word 'ponte' in a maritime sense, but it means any structure build over something, including scaffoldings. On the galleys of old a bridge-like structure run across the rowing benches, which later may have developed into a full deck on sailing ships. In any case the word is used for 'deck' in Italian.
- 77 replies
- point berlin
- diorama
Yes, I figured that one will need one round piece per corner. In the past I used a paper template stuck onto the top and then touched it with caution on the disc-sander.
I have to remember that idea of quartering a round piece of wood to get the radius of the corners right 👍
A bit further up you asked about that vertical stick the seaman is holding with his hands and I don't think the question has been answered yet. This thing is a 'Kolderstock' in German/Dutch and 'whipstaff' in English. It acts as a kind of fulcrum for the actual helm on the rudder. The staff rests in an olive-shape bearing in the deck: From: http://www.sailingace.com/segellexikon/d/kolderstock/kolderstock.htm Well into the 19th century the steering wheel was not all the common and used only on large vessels. Smaller vessels were steered with the helm directly, often aided by tackles. The kolderstock went out of use towards the end of the 17th century. I gather this vignette is meant to depict a part of the Brandenburg frigate BERLIN. The elector of Brandenburg started to build up a considerable fleet in the 17th century using Dutch know-how. 'Ponte' is Italian and just means 'deck' or perhaps here 'poop'. Perhaps you may want to change the title of your thread accordingly. Looking forward to progress on that nice vignette.
- 77 replies
- point berlin
- diorama
