Everything posted by wefalck
  1. Thanks gentlemen ! Unfortunately, I seem to loose or damage parts during assembly faster than I can make them. It's kind of two steps forward and one step backward all the time. Meant to assemble the binnacles today, but dropped parts unretrievably on the floor and messed up some with my beloved CA 😡 Update coming ... one day.
  2. These books are rather rare. I chanced onto my copies while trawling antique booksellers in Copenhagen in the late 1990s (when I went there on business quite frequently). The full references are: [FRIIS-PEDERSEN, J.] (1980): Sejlskibe - Danskbyggede traeskibbe opmålt, tegnet og foto-graferet.- Handels- og Søfahrtsmuseets på Kronborg Søhistoriske Skrifter IX: 107 p., København (Høst & Søn). [FRIIS-PEDERSEN, J.] (1981): Sejlskibe - De sidste i Grønlandsfarten opmålt, tegnet og fotograferet.- Handels- og Søfahrtsmuseets på Kronborg Søhistoriske Skrifter X: 108 p., København (Høst & Søn). [FRIIS-PEDERSEN, J.] (1983): Sejlskibe - Nordiske fartøjer opmålt, tegnet og fotograferet.- Handels- og Søfahrtsmuseets på Kronborg Søhistoriske Skrifter XI: 96 p., København (Høst & Søn). They have not been authored by himself, but were issued by the museum in Kronborg Castle (now located outside of it) based on his work. In fact most of the drawings I had in mind only showed the cross-sections of bulwarks, but not actually the constructional details of the waterways and covering boards. Above is a drawing of a single-decked small vessel that shows the covering board sitting atop a plank that in turn sits atop the inner waterway-plank that is sort of hollowed out on the inside. One should perhaps also consider that the measures given in the classification are probably the starting dimensions of the timber. If the top-timbers serve as stanchions as well, they may have been tapered quite a bit (are there dimensions for the rails ?). Also the waterways would have been shaped. I always wondered, how the large quantities of water coming on deck in a storm would be drained with this kind of arrangement. With low waterways and on smaller vessels the lowest bulwark plank often was raise a couple of centimeters or so above the covering board to allow shedding the water. The metal scuppers on the inside of the waterway planks certainly would not be sufficient. Later vessels with metal bulwark plating had freeing ports. There are not many drawings of the deck planks in the above books, but in the few, that are included, there don't seem to be any margin planks and any notching into the waterway-planks either. They just butt against them, even, if that means that they feather out (which would be difficult to caulk). It seems, however, that the deck planks may have been slightly curved to avoid too many planks with feather-edges and to have them instead butting against the well-rounded bow-section and the more square stern-section. The above books are also interesting, because they study the decorative profiling of a lot of planks and timbers. Edges were rounded and decorative beads were cut into the margins of e.g. bulwark planks. This is a feature oven overlooked by modellers, unless they work in really large scales. Dito the edges of stanchions would have been beaded.
  3. Well, the idea of these automatic pipettes is to dispense precise and repeatable amounts of liquids from something like 2 microlitres and up by pushing the button.
  4. Yep, understood. But I wanted to show that some model shops try to take innocent modellers for a ride. It may have worked in those dark, pre-Internet ages, but today we have access to a global market and share knowledge beyond the plate and the trade - and they still try. I think these automatic pipettes with their disposable tips would be quite handy for applying measured quantities of glue say when planking. I also thought of creating my own rivet-strips on decal paper by placing measured blobs of acrylic gel, for which these pipettes would be useful too.
  5. It looks, as if the Micro-Mark guys moved the comma too far to the right. On ebay you can get such adjustable pipettes for less than USD30 : https://www.ebay.com/itm/Single-channel-Adjustable-Volume-Pipettes-Transfer-Micropipettor-Lab-1000-l/143391759789?hash=item2162d09dad:g:XCYAAOSwaCtdmJne I remember from the time, when they were first introduced into general lab-work in around the early 1980s, they were not that expensive.
  6. Is this a 'professional secret' or would you mind showing the various stages of how your watercolours are developed ?
  7. I could imagine that it might be useful tool (apart from the price) for free-hand cutting or carving, but how would one make straight long cuts in thicker material ? I don't think it would replace a circular or scroll saw.
  8. There seem to be many different ways how these planks were arranged. What is strange indeed, is that the covering board is so narrow - the idea of the covering board, notched out for the bulwark stanchions is avoid the difficult to caulk seam along the stanchions. Are your 'top-timbers' really the stanchions ? If not, this may explain the narrow covering board. Otherwise, I could imagine that the 2nd (or 1st, which is wider) inner water-way plank has a sort of quarter-round rabbet planed in, that brings its inner edge to plank thickness, so that it can serve as margin plank. I would think that most of the planks are sitting on the deck-beams and certainly not on the deck-planking. In FRIIS-PEDERSEN's books on Danish ships there are sketches of all sorts of arrangements for these planks on ships from the same period as LEON. I would play around with the cross-sections of the planks to see how the puzzle might fit together.
  9. Cross-drilling round stock acurately is always a challenge. One way of doing it, is using a kind of jig: a piece of hard wood (or better metal) is first drilled with the diameter of your work piece, then a second hole is drilled at 90° to this with the diameter of the hole to be drilled and exactly into the centre - careful marking out and drill-press with a vice helps. This jig will help to exactly centre the drill with little chance to wander off. Neverthells, a small punch-mark or filing a flat will prevent the material to be drilled from rotating. A luxury and more permanent version of this would involve some kind of clamping device for the material to drilled, such as a set-screw for instance. I am not so sure that I would soften the brass, as soft brass normally requires special drilss with a steeper fluting and different cutting geometry so that it doesn't hook.
  10. Thumbs up ... what else ? A while ago, I went through the same problem of getting the angle of the hawse-pipe right.
  11. Nice metal-work ! I assume that the emphasis is on functionality and not on prototype looks ?
  12. Actually, your 'dog's breakfast' looks quite realistic in the sense that the interior part often was left quite rough in real ships You may have discussed this earlier, but I am too lazy to go back to earlier posts: I am surprised to see the framework without any bracing during the building. Aren't you afraid of warping during the building ?
  13. Seems to be quite a large-scale project for a jeweller
  14. Cool thing, the miniature plow plane. It seems to come only with a 2.4 mm wide blade, at this is what the German importer says. Correct ?
  15. I actually like this idea of slipping a flat piece of wood for the blades over the round oars. May not work for sea-oars. but certainly for this type of freshwater-oars with wider blades.
  16. Living in France I use a French product ...
  17. And you need the appropriate heat-source, a torch, as the melting point would be around 600°C as opposed to 350°C or lower for soft-solder. There are silver-soldering pastes, btw.
  18. Perhaps trying to find a picture of the real thing may help to understand what the final product should look like. Otherwise, making a jig from a small piece of wood would probably help putting part 23 and 22 together. As 22 simply butts against 23, I would rather solder these joints than glue them. After cleaning up the part and perhaps some pickling, part 24 can go on with CA. Alternatively, one could solder 24 onto 22 first with a higher melting-point solder.
  19. The tanker seems to be flying the Danebrog - the Union between Denmark and Norway ended in 1814 ... Great watercolours anyway !
  20. I am going to retire to a sea-side city in a few years time, but the down-side is that it is an open coast. I would love to have such a neat boat in such a lovely area as you are in. Unfortunately, most of similar areas in Europe are in regions with pretty miserable weather and short summers .... I am jealous ...
  21. Personally, I prefer these old-time machines and have a whole collection of antique watchmaking lathes and milling machines. However, some people prefer the Sherline machines even in a professional context in spite of also having antique machinery. Take a certain Jerry Kieffer for example, who is mentioned on the Sherline Web-site and who is an accomplished model engineer and a professional horologist. Using aluminium alloys, these machines appear to be stiffer than you would expect from their weight. Otherwise, it is certainly true that a a heavy machine reduces vibrations, which adds to the precision of the work. While it is also true that one can do delicate work on a big high-quality machine, I found that having to move large masses of cross-slides by cranking not necessarily adds to the quality of small parts. This is one reason, why watchmakers lathes are small. For the same reason I built myself a micro-milling machine from watchmakers lathe parts. If one is already a reasonably accomplished meccanic, one can probably take one of these Chinese lathes and milling machines and turn it into a useful tool. It is kind of safe to consider them as kits in an advanced stage of machining
  22. Ahh, this is going to be an interesting building-log ! Somehow I have always been fascinated by these craft (and birchbark canoes). There were so many different forms and variants across the Arctic, from Greenland to the Alëuts and across the Bering Strait into Siberia - one-hole, two-hole and three-hole ones (the latter for travelling Russian dignitaries in Siberia). About ten years ago I ended up in what became the French Arctic Research Institute, working inter alia with ethnologists and teaching students from Artic regions environmental sciences, risk assessment etc. We also had a fun-course, where each of the staff could give lectures on subjects of their special interest. I gave a lecture on arctic boats. For this, I amassed quite a bit of literature. If that is of interest, I can post here the bibliography.
  23. Two observations: - I use the Sherline motors on my watchmakers mill (until it ate the commutator) and lathe (the older one that still works) and never found it lacks power (in this case the transmission with round belts is the limitation). - I am using the lathe and the mill equally often probably; there are many things that can be done on a lathe, but not on a mill; many things can be done on a lathe with a vertical slide, that can be done on a mill. Sherline offers CNC-ready machines and conversion kits. I gather third-party conversion kits are available for the other makes.
  24. Museum conservators and restorers snuff on a mix of materials because it may cause problems for them. I can understand that position, but some parts are easier or better to make in one material than in another. The end justifies the means. As long as you work in relatively small dimensions issues such as different thermal expansion coefficients or different swelling due to different humidity uptake are not so big issues. It is also important to use glues that work with the chosen material. So, in general I don't have a problem with mixing materials and also use styrene, even though there may be issues with its long-evity. It really depends on the purpose of the model what kind of materials you use. If it is model to show a working hypothesis or to serve as a prop in some film or static visual imaging process, one does not need to be too concerned about the stability of the materials. Also, the level of detail has to be appropriate to the purpose. For static display models the situation is different. Hence, I think your choice of material and level of detail is absolutely appropriate.
  25. Just catching up with things after emerging safely from having organised the annual conference, an excursion and the AGM for our German association last weekend in the Baltic city of Stralsund. 'Houtboard' seems to imply that it is a cardboard made from, inter alia, wood shavings. Is this correct ? Why do you prefer this kind of cardboard ? I have been attracted by cardboard, because it is easy to work, less messy than wood, and glues well, but in the end found it not effective, as it is neigh impossible to sand cleanly, even when soaked in sanding filler. I never got clean edges and smooth surfaces. Perhaps it is my way of building that requires adaptation and shaping. So I moved away from its use again. P.S. Sometimes we Germans also confer here among ourselves in (some sort of) English
