Everything posted by wefalck
Very nice presentation and glass-case ! Me personally, I dislike, however, the cold-white LEDs, they give everything a 'clinical' or 'industrial' aspect. I prefer warm-white LEDs at 3600K, more compatible with a comfortable living environment.
Shop Fire Extinguisher
wefalck replied to Roger Pellett's topic in Modeling tools and Workshop Equipment
What are you doing that you need a fire-extinguisher in a hobby workshop ? -
Instructions Stink, Can't Find a Sample Picture
wefalck replied to mikiek's topic in Masting, rigging and sails
JCF is right, I have never seen an outhaul on the tack of a main topsail. The fact that it can be on the 'wrong' side of the gaff halliards does not impair its efficiency dramatically, given the moderate overall efficiency (by modern standards) of such kind of rig. The situation is different for the topsails to other gaff-sails. Here the triatic stay between masts gets in the way and there can be outhauls that allow to lift the tack and sheet over the triatic stay - or men need to be sent aloft to do this. -
I am guilty of having used brown packaging tape (the type you need to moisten, not the self-adhesive one) wrapped around a metal rod in several layers and then soaking it in shellac. Spinning it on the lathe allows you to easily slice off rings with a cutter - a lathe cutting tool would fray the edges. This kind of tape is also used to seal the back of framed paintings and have such paintings that were framed well over a hundred years ago without visible signs of deterioration. If you are concerned about acidity, you can test the material before use by pulping it and sticking indicator paper into it. It is important to remember, however, that these hoops were not seamless, but had overlapping ends that were lashed together. The lashings go through holes drilled some distance from the ends. I represented this by making the hoops slightly larger then needed and splitting them obliquely with a scalpel. This also allows you to put them - prototype-fashion - onto the mast after the rigging is installed. The ends are glued together and will come under the lashings of the sail.
Traditional Wooden Boats in the Norwegian Maritime Museum, Oslo
wefalck replied to wefalck's topic in Nautical/Naval History
Very simple: there are shovel-like implements with short handles, bailers. I think you can see one on one of the images. If I am not mistaken they found such bailers in the ship-graves. It works with keel-boats as well as with flat bottoms. -
... and, if it had been asbestos, its safe removal and disposal in a licensed facility (according to EU legislation) would cost you more than the boat is worth 😲
I recently spent a few days in Oslo and had the opportunity to visit the Norsk Maritimt Museum. They have a small collection of wooden boats strongly reminiscent of the Viking Age - more than a thousand years on: https://www.maritima-et-mechanika.org/maritime/oslo/oslo.html For comparison, there are also a few pictures of the boats from the GOKSTAD-grave in the Vikingskibethus.
Fillers for bulkheads
wefalck replied to legend's topic in Building, Framing, Planking and plating a ships hull and deck
The fillers should be somewhat softer than the bulkheads, but not too soft, so that one doesn’t sand hollows into it. l found MDF board a useful and cheap choice with the added advantage that it is not directional. -
I used to make such bolts and nuts in my pre-lathe days on the hand-held drill: take a piece of brass rod (I actually used small brass nails that turn better, due to being work-hardened from the stamping process) into the chuck, turn a step on the front with a small file, then (using the hex-nut of chuck as guide) I filed the six sides by counting the number of file strokes on each side, finally filed the short 'bolt' that will go into a pre-drilled hole and parted off. You won't produce them by hundreds this way, but it's quick enough for machinery, such as winches or the engine. Today, of course, I use the lathe and the dividing head on my milling machine.
On the flooring: was it actually done like this, i.e. like a ship's deck, and not rather in sections that could be lifted up for access to the bilge ?
Strop is a piece of rope spliced into a ring and used to attach things, such as blocks, for instance. If a block is going to have a hook at the end, the strop is going all around the block and through the eye of the hook. It is then tied together between the hook and the block. Strops and the likes are usually tarred. In fact, the strops may be also 'wormed'. The tar until the early decades of the 19th would be derived from the destillation of different barks/woods and dark brown in colour, rather than black. 'Pitch-black' tar only became available as a waste product from the destillation of coal to obtain gas for street-lighting in the 1820s or so. In consequence, it might be better to work with natural colour 'rope' and dye it a dark brown.
You need to check with the suppliers/manufacturers.
Building up the keel and stem-/stern-posts this way certainly is an option, particularly, when you paint the model afterwards. If you opt for an 'artisanal' kind of model that shows your skill at woodworking, you probably would need to go for cutting a real rabbet into massive wood. BTW, I did not understand the above picture: the actual keel and the posts should be wider than the 'false' keel plate in order to provide a step against which the planks can land.
I don't think it is known, how these boats were built, using moulds or just by eye. As you are going to reproduce a reconstruction, making moulds or a plug to reproduce the reconstructed lines-plan would be the way to go. You say "The scale makes true mortice-and-tenon construction pretty challenging", but you don't say what your planned scale will be ...
For wood, you should look for 2-flute carbide endmills then. The ones with 1/8" shaft are easy to find on ebay in diameters up from 1 mm to 3.2 mm, i.e. 1/8", and cheap. Larger diameters tend to be more expensive. These carbide endmills are not really suitable for steel, but can be used on brass and aluminium, as well as on plastics, such as acrylic glass. For milling on bevels and V-grooves, you can also use single-lip carbide engraving cutters, again with 1/8" shaft. They can be also sourced quite cheaply on ebay. For milling half-round fillets and flutes, there are 2-fluted ball-nose end-mills in carbide. Same source again. On ebay you can also find small wood-working routers with 1/8" shafts as sets at a low price. Some of them may be only CV steel, so they may not last too long.
As Kurt noted above, the technical reason for using double-planking is that the bulkheads on kits are spaced too far in order to prevent the planking from sagging. Letting aside the aspect of gaining experience (which is not so important, if you plan ahead and work carefully), there is another and probably faster way around this: (partially) filling the spaces between the bulkheads with scrap pieces of wood. The wood should have more or less the same hardness as the bulkheads. One colours the edges of the bulkheads and then glues pieces of wood between them that are just a tad proud of them, creating a sort of thick shell. You then sand the pieces down until you touch the coloured bulkheads. During the fairing you will bevel the forward and after bulkhead until only a thin coloured line is left. Depending on how the waterlines look like, in the midship section not much fairing may need to be done. In any case, you will end up with a hollow, faired hull that is ready for planking.
Which varnish??
wefalck replied to Edwardkenway's topic in Painting, finishing and weathering products and techniques
Even in the days, when I applied Humbrol by brush, I avoided altogether the Matt Varnish because of exactly these white spots. Actually, I don't see much use for really matt varnish in ship modelling. Very few parts, apart from those where the paint has been eroded by seawater and UV light, would be completely flat. -
Which varnish??
The 'matt' in Matt Varnish is brought about by adding very finely ground pumice or the likes to the varnish. This will settle with time, so needs to be very thoroughly stirred before and during use. The white patches may be higher concentrations of the matting agent. I remember this from the days, when I used Humbrol enamels. Question: why do you put clear varnish on something already painted ?
