bhermann
Everything posted by bhermann
  1. Good to see you back in the shop, Elia. The mast hoops are fiddly beasts and your approach looks to be yielding some decent results, even with the troubles they cause. Bob
  2. Nicely done, Rod, and so well documented. You've made a silk purse out of a sow's ear - congratulations on a fine job! Bob
  3. I'm sorry the cloth sails aren't working out for you. I'll be watching with great curiosity to see if the silkspan turns out to be a better option for you. Bob
  4. This has been entertaining to follow thus far, now that I've found it I'll pull up a chair and follow along. It's always nice to see a Bluenose (or two) actively being worked! Bob
  5. It's great to see you back in the shipyard, Elia. You appear to be back to your fine level of work right out of the gate. I hope to join you back at work soon, my Bluenose has been sitting patiently for 12 years now. You are an inspiration to get back into it! Bob
  6. Hi, John. The Bluenose practicum is available at Bob Hunts site, Lauck Street Shipyard at https://lauckstreetshipyard.com/. I used it when starting out my Bluenose as it was my first wood model build. I hope you don't mind me jumping in on this. Bob
  7. I'm so sorry to hear about your many issues over the past few years and the loss of your father, and happy to hear about your new puppy. I have been thinking about you as the log has remained in a sort of limbo for some time. Looking forward to reading the finish of this "build book" and seeing her sitting in her place of pride. Bob
  8. Beautiful job, Tim! Your workmanship and attention to detail produced a fine finished model. The embellishments on the name plate are a nice touch as well. Congratulations! Bob
  9. I had the same thought as Ronald-V when looking at the last photo in your post, Gregg. It depends on where the hole for the spacer is on the left side of bulkhead 17 is to see if it will fit when flipped. If it is to the inside, as the right side hole is, then trimming the tab seems to be your only choice (unless you want to try cutting a square hole in bulkhead 17 to allow the tab to fit where it wants to go. Your fix for bulkhead 16 should hold just fine. Nice work and photos, as always. I love the kit design that supplies the spacers and places to put them, maybe other kit companies will take note! Bob
  10. Congratulations on a well-executed and well documented - and beautiful - model. Gregg. I have very much enjoyed watching her come to fruition and your thoughtful commentary along the way. With winter coming and more inside time I am hoping to finally re-start my effort, although I'll be thinking "Wish I'd done that as well as Gregg did". Also looking to see where you go next and will be following along there - I think I hear the Conny calling Bob
  11. Looks very good, Gregg. I like that you brought the gaffs down to the boom. So many of the sail-less schooners I see raise the gaff to where it would be with the sails installed which looks a bit strange to my eye. Actually seeing your rigging choice gives me yet another alternative to consider - this should add another couple of years to my analysis paralysis! If you would like to elaborate on the difficulties you had with the silkspan, I'd love to hear about it. I am convinced that this is the sail material to use, and I am almost decided NOT to sew anything. I can understand that you may not want to clutter your log with this info, so don't feel bad about not responding. Great photos and explanations, as usual! Bob
  12. That's an interesting thought. I suppose it's possible, but I think it would make adding the sails more challenging. Great, one more thing to mull over - this should hold me up another two years Bob
  13. That is some very nice work, Gregg! I can't wait to hear what you decide on the sails. My own debate on that has kept my Bluenose in limbo going on 11 years now. Sails? No sails? Cloth sails? Silkspan sails? Maybe your decision will inspire me at last! Bob
  14. That is a superb job of attaching the sails and making them look lifelike! You are really raising the bar with your fine work. Bob
  15. Agree on needing several coats. I hand painted using ME. The black took three coats, the red was 6 or 7! In the end, it all looked good. Bob
  16. That is some more nice work. I hear your concern about the waterline marker. I recall sticking a pencil between two heavy Cisco certification books and dragging the levelled hull past it. I also recall not being happy with the result and retaping and painting by eye to fine tune things. As with all things Bluenose, take your time, rework as needed until you are happy with the finished product. Bob
  17. That is some very nice work, MC! Do you plan to inset the chain plates into the hull instead of leaving them proud of it? It is a detail that I missed after cutting the slots through the rail. Bob
  18. Now I'm going to have to review my miscellaneous rigging hardware placement. I am sure I missed the eyes between the shrouds, and some of the other details may be a bit week. A great reminder to keep checking everything! Bob
  19. Great job on reaching this milestone, John. She is coming along beautifully! Keep this up and you may inspire me to take up my own build again Bob
  20. Sigh, hope you feel better soon - can't wait for the next round of shots to be available! Bob
  21. Sanding and filler are our friends, first some sanding, then some filling, rinse and repeat, finishing with a fine grade sandpaper. Taking the time to get this right will be a big benefit in the long run. Looking good! Bob
  22. I've got this one in the works too, still my first attempt even if I am 16 years into it. I'll be following along with interest! Looks like a nice solid start for you. Bob
  23. You sure did a great job of diving into the details and have produced a fine end result. Looking forward to where you go from here! Bob
  24. That is some nice work! I agree with Joshua that a gloss finish looks out of place on these models, but you are the captain here and can go with what pleases you. Bob
  25. Responding to the February 18th post (don't know how I missed it at the time), I realized after I had installed my chanplates that they actually sit flush with the hull and not proud of it as I did them. I think this may inform the decision whether you include them or not - they would not be very apparent at the 1:64 scale we are building at. Good luck with figuring out the sails, there are too many options to think about and it has brought my build to a halt for years. Cloth sails in general are too thick to maintain scale. I am considering doing them anyway, or maybe doing paper strips to build each sail panel by panel. In any case making photocopies is a good idea! Your work is looking very good to this Bluenose builder! Bob
