augie
Gone, but not forgotten
Everything posted by augie
  1. Um......thanks Popeye. But I'll defer to Mobbsie on the ship's boats
  2. Very well done. Like I always say....... the smaller it is, the longer it takes.
  3. Oh, that's right! They are sitting on top of the piano. You're good Andy
  4. Thanks again! Seems like everyone is looking forward, with great enthusiasm, to planking. Everyone but ME! The task ahead will rival that of planking the basketball court at Madison Square Garden. Besides, I LOVE plans, blueprints and line drawings. So much so that I have a fully built Piper J-3 Cub hanging in my office 'in the bones' ....... uncovered so the entire structure is visible. So perhaps I'll just leave her as is :D . A new concept ---- the PRE admiralty model ! But no, we'll forge ahead. Mobbsie- haven't completely decided yet on the finish. A lot will depend on how the planking shapes up. She won't be coppered as that wouldn't be accurate. I've always been partial to a natural finish. But the fine examples I see here on MSW are changing my preferences. That's astounding since I'm known to be as stubborn as a stump.
  5. OK, we have length and height. Now when do we start adding the width????? There must be about 15 yards and spars sitting about somehere
  6. Yes Sherry. They were very long and thin. I think they were actually mostly used to maneuver in close quarters.
  7. I'm with the others on this. I use pva diluted a bit with water and generally go with 2 coats.
  8. SJORS - No, we don't cut anything out from the beams. These are the small sweep ports which will be created as we plank. Each will have a closed door and a metal hinge holding it closed. So we'll never see the beam. The actual gunports are framed above on the gun and quarter decks. I'll be painting the insides of those soon so you'll have a better perception of it.
  9. ANDY --- Thanks for the reminder. It's been fun so far......but 99.75% of what's been built will never be seen again!!!!! And thanks to everyone for the kind thoughts.
  10. Be interested to see which 'part' of you wins out. You can't beat natural wood........but then 'white stuff' has a charm of it's own.
  11. Is that ANOTHER new avatar I spy???? Between all the ships and buses, it's hard to keep up!
  12. OK, the dust has settled A line of sweep port 'frames' has been installed the entire length of the hull. These frames are 3/8 x 3/8" square stock aligned with laser etched lines on the bulkheads. The alignment of those lines was checked with a plank prior to setting in the blocks. Note the double block amidships which accommodates the larger ballast port: Once the frames were in place the entire hull was faired for the last time. Chuck provides a template to align the sweep ports. Here it is attached to the hull: The template allows the ports to be marked with a pencil. It is the planking which will actually define the ports later on: Two items remain before planking above the wales begins. Firstly, I need to construct and install 6 simulated sheaves to pass through the hull. Then, some fun is at hand establishing the color for the ports and bulwarks...but first things first.
  13. Either that or go old school. Level the model itself. Then hang a line from the ceiling on a plumb bob. Move the model to the appropriate position and install your stanchions in line with the vertical line.
  14. Great tongue-in-cheek characterization of OSHA regulations. Would probably also include the use of supplemental oxygen for high altitude work
  15. Great to have you and the Admiral back home safe and sound. Now, I believe there are 7 whaleboats waiting in the wings
  16. Are you getting the 6 or 12 pounders? Either way, they're great.
  17. Nice.....and very dramatic. Have fun on the flip side.
  18. Again with the 'mill'. It's a Zona saw and a sanding block :D (lubricated with elbow grease).
  19. Now Anja is in the bathroom ????? I understand how it goes. I moved the bedroom set into the garage so we can have more room for crafts. Tell Mobbsie to bring his Aggy along so we can see some side-by-side photos
