Kelp
Members-
Everything posted by Kelp
Hi Dan, You got yourself a great deal on the kit! I'll be watching with interest, as I also have this kit in my closet for a future project. As for the keel, I'd probably buy a piece of plywood and cut a new piece, that way it would be good and flat. It might be quite difficult to straighten out the piece you have now. Be careful when cutting the slots on the new piece for the bulkheads because you don't want them to have too much play. The bulkheads should fit snug. Best of luck with the build, Don
Hi Tom, Do you know when the restoration on the Constitution is scheduled to be completed? I remember in 1997 there was a major restoration. Is this the same type of work being done? Your model is looking fantastic! Thanks, Don
- 1,348 replies
- constitution
- model shipways
Hi EJ, This should be a fun model to build! Im looking forward to watching your progress on this site. Don
- 961 replies
Excellent commentary on your progress. I like how you are describing every step as it will make life easier for future Constitution builders. Best of luck on the build! If you have questions along the way, quite a few modelers here have built the same kit and will be glad to help out. Great start! Don
Hi Ulises, Thanks for your reply. I looked more carefully at Heller's instructions and found that the carriages were to be painted the barn red color as you suggested. I look forward to seeing photo updates of your Royal Louis model. It's coming along nicely! Don
- 786 replies
- Royal Louis
- Finished
Hello, I'm building the Heller Royal Louis and can't make out what color is supposed to be used for the gun carriages. What would be a typical color for gun carriages for French ships of this time period (1700's)? I've seen some photos with the carriages red, the same as the interior bulwarks. Thank you, Don
Very nice coppering job Hamilton. I also left the copper natural on my Cutty Sark model and it has aged nicely, looking like an older penny. Don
Hello Ulises, I am building the Heller Royal Louis. The color code for the gun carriages isn, t very clear. Can you tell me whar colors for the carriage and wheels are listed on the instructions for your kit? Great job on you model! Thanks, Don
- 786 replies
- Royal Louis
- Finished
Hobbie, Here are some very helpful comments from Tom, who built the San Felipe: Members 346 posts LocationAuckland New Zealand Hi Don-- I hope you are enjoying the SF build! You are correct, each of the sections should be cut out of the sheet with tin snips. Cut along the outside edge only as close as you can and then file off any excess. You don't have to paint over the blue areas--that is just a dye to help you see the raised sections and that dye rubs off with solvent. There is a debate on how to handle the window panes. Most people I believe paint them with blue or gray paint to simulate the reflection of water or sky. That's what I did and you can see in this picture, which also shows a couple of cut out pieces in place: On another model I once tried to cut out the inside of each window thinking I could put glass or plastic behind and make it look like a real window, but it is impossible to cut the little bits of window out without destroying the entire piece. If you decide to paint your windows, it's not a big challenge. You don't have to be too careful because you are just painting the recessed sections. You can rub off any excess paint with turpentine. One way to do it neatly is to stretch a cloth soaked in turpentine over the top of a cylinder, like a paint bottle, which makes a flat surface and rub it over your piece--it will just take any excess paint off and leave your painted window looking good. For the non window parts of the metal, I used the bright blue that I used on all other parts of the ship's trim. Hope this makes sense. Let me know if you have questions and good luck! Cheers, Tom
You must mean this piece of brass. I'm also at a loss on what to do with it. There are a couple of people on this site who have built the San Felipe. I'll see if I can contact one of them to help out. Don
Hello Ulises, I have started looking at your build of the Royal Louis. Very nice work! I'm just beginning to work on the Heller plastic Royal Louis and your build photos will be a great help. A general question.. What did you use to glue the metal gunport frames to the hull, superglue or some kind of epoxy? Thanks, Don
- 786 replies
- Royal Louis
- Finished
Hamilton, Copper tape cut to tiles or pre- cut tiles will look much better than the wood tiles and definitely worth doing. Don
Jan, Congratulations on your completion of the Nina and Pinta. The models look fantastic! Don
Mike, Fantastic job on the planking! I have also worked on this kit (currently shelved while I'm finishing a different kit) and found it to be one of the best kits to build. If I remember correctly, the instructions didn't mention when to drill the mast holes. Just an alert to drill them before you lay your decks. I look forward to watching the progress of your build. Don
Hi John, Can you describe your process for printing out the letters on the stern, such as type of paper & font, etc. How did you get white letters? Thanks, Don
- 159 replies
Bob, I'm glad you're going to poly this model. It would be a shame to cover the nice wood grain with paint. It's looking great! Don B.
- 196 replies
- higaki kaisen
- woody joe
