klimi
Everything posted by klimi
  1. Oh what a speed of your build. Congatulations. I´m currious on your next model. Cheers Pavel
  2. Nicely done crew Frank, where will you be? On the top of mainmast? Pavel
  3. Nice and celan work Ilhan, like your details Pavel
  4. Hello again, I repaired one side and i think, that it is fair done. I tryied to make a patina. First time i painted a wood thin layer of color and then i used a grafity powder after that i did second coating. I think that i know, how i wanna go on. I wish that my model will be look like realistic, so i try make a each part not so clean and certain direction roughly trimmed. Like on the old ship. I will see. Next step will be make a second side and then windows. and here are next pics.
  5. Amazing model, is nice to see your model done, because your model is for me nice inspiration i´m looking forward for your next build. And do you not really try to make own scratch build?
  6. wooow incredible work, keep working, i looking forward on the next pics. Your carving work is absolutely amazing. Pavel
  7. Hello Nenad, is nice to see your progress. In summer i was a little bit busy and i just checked a few topics here. Mostly i was looking on the pics and i like, that you improve Cutty Sark on the highest level what is possible for you to do. I´m lazy to read all replies now, but i gonna follow your adds. Good luck Pavel
  8. Thanks Hamilton, but i´m not satisfied with wales aroud the bow. Because it doesnt follow the planks. I think, that i can try cut the yellow plank out and if will be plank under it in good condition, then i´ll cut out the others. I´m a litle bit afraid out of this, so that the hull stays good.
  9. After a long time I returned to work on the model. The first thing I started to fix the planks at the stern . Now it is well aft beam '' '' or as I call it, however, remains on the other side. Followed by a couple of attempts on the windows and in the end I tend to think that the window frame will make a 1 mm slats and bars in the middle of 0.5 mm . Does anyone here from you proven method in terms of build bars? There seems to me the best opportunity to stick 3 longitudinal slats and then between 8 to fit the pieces. 7 Furthermore, I wonder whether I should redo a few other things. The first is the plating of the hull at the bow . Firstly, I do not like the way I finished more than the tip is in the plans , which show that those boards are connected almost horizontally . So I thought in the last part of the dividing cut and stick below . I fear , however, that there is quite chances of spoil it , even though covered with planks could be replaced, which is just about the time, but the result would be more satisfied. Another thing is the thickness of the wall , which is also the plans thinner and also a black board on board is connected to the step smoothly and not what is with me. Which I would like to address cutting red planks and grinding and then stick it again , or make new ones. Thus, there would be room for a black board even if it looked smooth. Now I am waiting Resolved second beam at the rear and then about going into repairs.
  10. Hi Sparrow, very nice model, i´ll follow your progress, i´m looking forward for next pics Pavel
  11. NenadM: Yes, I think so, because work on hull was long and it looked, that it is infinity, but a few steps back, when I glued beams, the hull came out. I´m looking forward on details on deck, but most, on masts and rigging. But this work is fine, is kinda meditation, if it can say.
  12. Hello NenandM, I think that in your situation don´t care, if you have such free time to work, because I like your technique and good step one by one good fugured out. Pavel
  13. Hamilton : Yes I did, in the first paragraph is it writthen, that this ship is my first. I made some planes and basic ship as a child, so this kind build is my first. But now is my work slow down, because i´m gonna do last exam and than i am going on summerjob and also i wanna enjoy summer. but i wish to still working on the ship. Pavel
  14. Thank you all, i´m very pleased by yours nice words. Your comments give me more flavor in the works and I will try to do the best possible result
  15. Thank you alot, i´m pleased by that, you like it. Frank: eavour, what are here. The limewood and the yellow planks I did dirty by graffiti powder. It looks more natural, mainly the yellow color, it looks not as plastic. Next move is a stern, make a windows, and a down part with title Bounty. The windows i wanna do, that i´ll make a drawing of windows. On the paper i will glue a planks, it hold the right shape and than make it out and from behind glue a foil out of disket. DSiemens: Thank you, think, that carving isn´t so hard, I carved the piece to the basic geometric shapes and after that i was using sand paper. I am looking forward until i will make a figurehead, it will be harder than those basic pieces. Pavel
  16. Continuing in the decoration, it was quite good, just not able to do absolutely accurate ornaments, so I tried to do something a little credible. I would like to optat that will be more rewarding first stick ornaments on the vault or arch of the stick first and then fit the
  17. So again a bit further, since the last post I tweaked imitation tarring on board. Following the example of one guy who showed progress on http://modelshipworld.com/index.php?/to ... ils/page-5. First I applied aboard graphite powder, spread it on the deck brush and then wipe with paper surpluses. Next, I painted the deck with oil and let dry for about 5 minutes and then scraped the blade of the knife and eventually married again with oil. The result, I think it is much nicer than when I had split boards made ​​only pencil. I also did a "railing" on the front, it is carved out of balsa wood, it was ultimately the easiest way to do it. Finally, the stretching rails around the body. With them I proceeded as with planking when I shaped wet latičky around the trunk and then dyed and glued, super glue, which I again spotted on scraps of paper. The black slats, I tried to indicate division and so I just gently took a scalpel, painted, glued and then a completely resurfaced the part where a lot exceeded. Otherwise, I did not want those substances were completely flush, because if it previously did so with some bullshit.
  18. Hi Dan, nice to see next bounty here I´m also on bounty progress by scratch, I´m looking forward your build and I wish you fun too.
  19. nicely done,if i see this model, i´m thinking about this ship, that she will be maybe my next build. love the details
  20. Crazy idea but great done model, it´ art and craft
