glbarlow
Everything posted by glbarlow
  1. Nice work on this detailed model, it looks great. I like your choice of ‘red.’ What did you use?
  2. Sometimes I just have to stop and reorganize, I have stuff everywhere. I do like those files, thanks again for the recommendation.
  3. Good observation. All the sides of the gun ports run perpendicular to the water. Per the plans gun port sills on 4-6 do slant upward following the run of the deck so you’re right about the slant but it’s correct per the design. Chuck included reference lines on the bulkhead. I just had to match the top of the sills to each mark. 4 does seem to stand out more in the photo, but it’s the same as 5 & 6. I think the spacer bars, which are more or less straight, accent the slant and not in a good way. They’re ugly but I hope helpful later in the build. If you look at the previous post of the port side the slant is there but looks more ‘elegant’ without the spacer bars. Thanks for the comment. Everything about this build is new to me, I’ll take all the help I can get.
  4. First I’ve heard that working. I’ll quit offering advice then.
  5. You'll want to close that gap at the bottom before adding a plank. I cut the shape of the bow from a scrap piece of wood using the plans as a template. I can put the soaked wood on it and clamp the heck out of it so its a tight fit. If you keep going from here make sure to get clamps down at the bottom to get it tight on the frame. The first rule of modeling is when you think you have enough clamps, go buy more clamps. You're having fun now....
  6. While I still have fine tuning to do, I’ve completed the ports and fairing on both sides. The second side went in easier since I had a little experience, I’d also cut some of the pieces by duplicating the fit on the port side before I installed them, making finding the size and angles easier on the stern ports. In the foreground are the various sized wood I ripped to make the ports - I’m sure the remainder will come in handy later. You can see I’ve added some ugly, casually placed reinforcement between bulkheads without ports. I took this from Rusty’s log sort of, his were much neater. I used 1/16 and put them close to the outside after doing the fairing. I’m anticipating some challenging sanding on the inward side later, these are more preparation for that. Of course they’ll be covered by planking and if the get in the way they’ll be easy to remove. So I sacrificed form for function, there went my pretty faired ship. A lot of doing the second side is keeping it equal in all ways to the first side, my little port leveler made sure I had the ports aligned and the sills on opposing sides level with each other. I even measured the width of the remaining bulkheads at the stern and bow so I don’t end up with a lopsided ship. I may still end up that way, but this helps reduce my chances. Everything measured up fine, once again a testament to the design. I am taking it very slow and careful with this frame - hopefully that pays off later. My other consistency jig was my “port sizer” I had the wood gauges to use as I was building - my last step was take a square jig - reduced in size just enough so it was 17/32 including the 320 grit sandpaper wrap. While I was close for the most part, using this little tool to run through and through settled all my ports to be consistent in size, including the chase ports up front where it really came in handy. My tool of choice for cutting the chase ports was my Razor Saw. As Chuck advised, I cut inside the line and short of the bottom, used my #11 blade to clear and my port sizer to size after first using some sanding sticks to get it close. I measured the port side to the plans, I was more focused on matching the starboard to the port - remarkably they came out the same. How’d that happen - oh I measured a lot. I will confess I was working in millimeters. I’m trying to be a good imperial boy, but I fall back to the MM ruler every time I need to measure something close. I’m still trying to get my head around numerator/denominator measuring. I wasn't listening during the fractions portion of my elementary education. I know some have opted to line the chase port with wood. I have elected not to do so, though I thought about it. The wood to me is so smooth and the cut so square I’m ok painting it as it is. Speaking of which, here is my earlier mentioned choice of Golden Cadium. It’s not quite as bright as this photo, but it is very red and I’m ok with that. Finally, here is my collection of various tools and sanders I used for this stage of the build. I instantly regretted piling it on my ship. The flexible 3M holder was used for the heavy lifting. It has velcro face and matching sandpaper, I used 80, 120, and 220 with it. The yellow handle has the same velcro connector, I used it for tighter quarters and fine tuning. The sanding sticks, 120, 220, and 320 grit for even more fine tuning and opening the ports. I will finish the ports with a fine stick before painting. I discovered these Vallorbe Barrette files on Derek’s Speedy build log, they are really great. They file only on one side, I have them in coarse and medium. I’ve always had an issue with a standard flat file since it files on the side edge as well. These eliminate that issue, important when you’re trying to square something up, like a port. I also prefer the triangular file for corners as opposed to the square one for the same reason, I can file the side I want without impacting the other and the point of the triangle cuts a nice corner. I have so many versions of needle files, they are now tossed in a drawer. I now have a full set these Swiss Vallorbe files, they are sharp and cut evenly. I also highly recommend them. There is my file lesson for the day. So I feel a stern is coming, see what I did there. Uh Oh, more new ground for me. Here I can ponder such questions as why is a square tuck a triangle. I won’t get ahead of myself. First I have to attach and fair some stern brackets without breaking anything.
  7. Thanks Chuck, I appreciate your keeping an eye on it as I proceed. While the ports are new to me I know I have bigger challenges ahead. Fun stuff. Derek, I was never a fan of planes, or they weren’t a fan of me, but this little jewel is making me a believer. That photo was after I finished my last model and before starting this one. It was a momentary moment of being organized 🙂 We have our grandkids 3 days a week, so I’ve become a teacher following the online program her school put together. I had respect for teachers before now I an even greater appreciation. Yes, jelly is the same here and I know exactly what they mean.
  8. Now interesting stuff starts to happen, or interesting for me anyway. Failing to find an outsourcer, (I didn’t really look, I instead did my isometric exercises Sand On, Sand Off) I spent a couple of days sanding to get to this point. I concluded it was time to stop and get the ports in before I sanded away the bulkhead extensions. Lining up the ports is so much more easy thanks to the reference lines Chuck provides on the starter kit bulkheads. I’m not sure I’d started this project if I had to cut them out myself, where’s the fun. I was prepared to make micro adjustments by measuring and doing the look test but frankly it was near spot on just with tacking the batton to the reference lines, though I still measured and looked to be sure. I later met with near disaster when I started the starboard side. The hard part of this task is getting the pushpins to stay in the bulkhead extension, I pushed a little hard and snap.:-/ I pinned it back with an inserted brass rod and splinted it up. It’s not so pretty now, but it will be covered up soon enough. I should know how to avoid this mistake, stupid pushpin, and I was even pre-drilling the holes…Oh well, I’ll be sure to check the fairing closely, though I tried to account for that as I repaired it. Modelers don’t panic, we adapt, overcome, and improvise - Clint Eastwood in Heartbreak Ridge would approve. I started doing testing what color red I am going to use. I’ve always used Admiralty Paints but their only red - Ensign Red - just wasn’t red enough and Cheerful has to be red, right. To be clear, I really like red with this ship. I settled on Golden Cadium. Go Red or Go Home. I’ve since tested it on a piece of Yellow Cedar thinned down and multiple coats (7 so far), I like the look of it. As I installed the lower port sill I made sure they were level with the hull, my many variations of little levels make this easy. I was working from outside in so I could have room for the clamps. There is a little fun beveling to get the outer ones to fit the shape of the hull, just a little bit. I went ahead and thinned down the bow port filler to about 1/8 with my Dremel after reading ahead in Chuck’s practicum, then cut the port. One of my many uses of left over MDF from past kits is in this case making port sizers. So yay, the chase port is a square smooth 17/32 like it’s suppose to be. I’m still having trouble adapting to imperial measurements, this is my first time not using metric. I’ll say it again, metric just makes so much more sense to me. Why is the US still stuck…he said rhetorically. Here is where I as a kit builder knew I wasn’t in Kansas anymore. The sides of the gun ports call for multiple, seven to be precise, different sizes to match up to the plan location and size for the ports between the bulkheads. This I where kits wouldn’t go, they’d be limited to a few sizes of stock wood, and of course gun port patterns. It took me a second to wrap my head around the fact I was no longer limited by what stock wood is included in a typical kit. I purchased the wood package from Chuck, this lovely bundle of Alaskan Yellow Cedar billets comes in multiple sizes, six of the seven needed were in the package. I used my Byrnes saw to rip ¼ inch widths of 1/32, 1/16. 3/32, 5/16, 1/8, 5/16 (all in the package). For the last one I just took one a piece of the 5/16 square piece I’d already ripped for the port sill and cut it to the called for 3/16. See how I did all that imperial thing there… I will say once again the best tool I ever bought for model building is my Byrnes saw. Now, with a little help from Chuck, Rusty, and Jim Byrnes, that I know how to properly rip a plank with the proper blade, I’m cutting and ripping whatever I need with joy in my heart and fingers still attached to my hands. If you don’t own a Byrnes saw, buy one. You’ll never regret it. (Though I learned he’s on Covid hold until the end of June for new orders waiting for his supplier to deliver 120v engines, he still has 220v). I made a longer gunport checker for the gun ports, which I will also use to make sure they are lined up with the other side. I also use it to double check the two side pieces will create the called for 7/32 opening. That whole measure twice cut once thing. I also determined I didn’t need the pieces quite this tall… So here she is with the port side ported and faired. The batten lays smoothly top to bottom. Now that I’ve splinted my broken bulkhead extension work can begin on the starboard side. Comments and feedback welcome. It will be a day or two before I can get back at it again, I still have to process my granddaughter’s 7th birthday portraits as part of my other photography hobby. On a side note, if you ever want to make a 7 year old's day, prevented from having a normal birthday party by Covid and 2020 catch phrases like lock down and social distancing, hold a car parade. Her parents arranged to have her friends and family do a slow drive-by their house honking horns, holding signs, and making noise. She got to see friends she hasn't seen since schools were closed in early March, her teacher participated as well. I have an English friend who shared the Facebook video with the very true statement "if this doesn't cheer you up, nothing will." She was sooo happy. And as a result, so was I.
  9. Do both at the same time, maybe you’ll invent something new😂🤣
  10. You aren’t familiar with the method. You don’t do both at the same time and when you have bent the plank right it does in fact fully fit. I did your way for a long time, this way works soooo much better for me. But then I’m very comfortable and have always used CA on planks. I don’t have time or patience to watch glue dry a plank at a time. But like you said waste wood trying new things and learning what works best for to get to a finished planking. It is true it’s not for gunport patterns, and there are different ways to do that too. I described my method in another Speedy log, though with Speedy it’s an easier bend than some. Lots of ways to do things, no one should inflict theirs on someone else, I’m just passing in what I think is a great technique for me.
  11. Before you start boiling wood check out Chuck Passaro’s method of plank bending. I used it on my last model and it changed everything in how the planks fit to the hull. It’s worth the time to learn and much easier in the long run
  12. I don’t know if Chris’ instructions mention it: run a batten along the hull at various heights, when it smoothly touches every bulkhead bow to stern you’ve achieved a faired boat. Leave the char on the trailing edge of the several bow and stern bulkheads to not lose the shape of the hull and have a lopsided boat. Although maybe you want a lopsided boat, being from Ana.🤣
  13. Looks like you haven’t yet truly enjoyed the fairing experience. You haven’t finished until you’re knee deep in sawdust.
  14. I built this model, my second build as I recall. It was a good learning experience, but not near as challenging as my first AVS. Honestly after seeing your work on the longboat I think you’d be disappointed with the materials and design. I’d recommend the Cheerful or if you’re not ready for that than one of the Vanguard Models kits. Much better design and far better materials. The instructions Chris provides are all lessons applicable to future models...like Cheerful 🙂
  15. You did a great job on this, especially with learning new things as you did them. A lot to be proud of here. You’re ready to start your Cheerful. Well done.
  16. First off, your hull looks great! You may want to fit a small piece to cover that gap at the bow, painted you won't know its there but it will be obvious if its missing. At this point the fact that they don't line up is less an issue once the bowsprit and all the rigging is installed. I've never ever built a ship that I didn't have to get creative to modify, adapt, and overcome issues with the stern - there is always something. I think as I showed, I mean the other Glenn showed, and what you held up you can make it fit. Just do it concurrently with the boom crutch ready to go. Even if you don't install that until later you want to know how they look together and adjust from there - at least that's my recommendation. PS: I like your file stand, mine are just laying there in a pile though I did ask my wife to make be a little felt sleeve to store them in.
  17. Very kind of you. I'm not at that point at the moment but I really appreciate your offer. Actually I've gone nuts and started building Chuck's Cutter Cheerful, I'll be way over my head in no time. I've started a build log if anyone's interested, the link is in my signature. I'm still buying the Master Shipwright version of Flirt as soon as its available. Chris, I also got an aluminum block brass rods, and a metal drill bit. I'm going to try to build your mast marker. I didn't know you could just buy a block of aluminum until now...
  18. The goal is simply to wind up with the second planking the width of the stern post, really either approach will do it - gotta sand something.
  19. Framed, taped, and ready for fairing to begin. I only had to make a few adjustments on bulkhead 8 otherwise everything dropped right in and easily squared up. I used my mini-squares and worked from bulkhead [+] in both directions, that gave me room to clamp the mini-square as I went. Not sure why the photo is so big, this is about twice the size of the actual tools. These little square have been one of my best buys. They come in handy a lot throughout a build. The bow and port fillers fit without adjustment, a testament to the design, but another of those positive affirmation things that let me know I’m doing ok so far. Now, unless I can outsource, the fun of fairing begins. First I moved to a stand that allows me to safely hold it upside down. I opt for function over form. I’m not a woodworker and just use what I have available, in this case adapting the fairing stand I had for Vanguard (why it’s oddly long). Furniture anti-slip pads on the bottom, some felt on top, sized to fit the deck and high enough protect the extensions and the stem. Nothing fancy and about an hour’s work. So yay. I’ll use the laser burn as a guide keeping the edge closest to mid-ships brown until the very end. Then finish it off. This will keep me from removing to much wood and/or losing the proper shape of the hull. We’ll see how that goes… Now to do a google search for model ship fairing outsourcing...
