Thanasis
Everything posted by Thanasis
  1. Hi George. I admire your tidy workbench and having seen your previous work, I'm sure for the magnificent result. Thx Thanasis
  2. Thank you all. What I meant was to make any modification only on the sides of the groove. I would never touch the already shaped and pre-caulked plank.. My suggestion with the folded sandpaper is what you see in the (photoshopped) below photo. You can keep a strip of folded sandpaper between a " Bulldog clip" and use the folded edge in the groove. Keep the jaws of the clip as close to the folded edge... Thx
  3. Hi. Did you try with a suitable finger nail file or with folded sandpaper...? Thx
  4. Hi. I don't know how much "tiny" but see whether those joints from an old umbrella might suits you... Thx
  5. Hi. I follow the procedure where the upper deadyes are already attached on the edge of a shroud but the seizing knots are slidable. So I have the ability to align all of them. See there "A way of seizing (my way)" Thx
  6. Thank you Chaptman Yes I have read about that also in the fight against Aegean pirates, where the chase in no wind state, was kept on by rowing boats. But again in this case the boats were parts of the chaser ship. In my cases these small fleets (one schooner and 12-13 boats), were formed quikly to seize the chance. And what make me wonder is , whether was posible some of those specific type of boats (is narrated as "maltese" boats), could be kept in ports or near by, for these kind of missions. Thx
  7. Thank you both. Yes, it's rather something similar since the tactic in Danish gunboat war, was exclusively between armed small boats attacking a target. In my cases there were only armed men using the unarmed boats like tranfering vessels. Thx
  8. Hello all. I'm in the middle of a search related to an Ottoman small rowing boat, maybe also with some kind of riggs, back in 1800. In two historical cases, this kind of boat in a number of 12-13 of them full of gunmen, were accompanying-supporting a schooner, as all togethere, were attacing in an enemy vessel. Does this pattern indicates a kind of a naval tactic of that time. Is there someone who could inform me about. Many thanks in advance. Thx
  9. Hello. Having inventing this "my way of seizing" I would suggest to take a look in the below sketches. A. Shows how you should fold the thread around the bowsprit if there are already other rigging stuff alongside. It also shows the "premade" seizing, from which all the thread's edges should pass. Here the seizing is off the tool but it would be easier if you pass all the edges of the threads while the seizing is on the tool. B. Shows the already placed seizing (still a bit loose) and the deadeye in the upper loop. C. Shows that first you have to tighten the maine thread and then the thread of the seizing. At the end there will be a double loop around the bowsprit and a single one around the deadeye. Cut all edges and a bit of glue will secure the whole set. I hope it could be helpful. Thx
  10. Hi. There is also the below fishing tool which is called "Tie-fast knot tiyer" You can see its uses for ship modeling in the link. My way of seizing Thx
  11. Hi Cristiano. I just visited your build log, and I find your work amazing. Congratulation for your search and certainly for your beutiful model. Thanasis
  12. Hello and happy New year.
    See whether you can find something new-useful in the link (pdf file).
    There is some sources about the ship's base in Samos in page 67 and drawings and  a photo in pages 148-149.
    http://ikee.lib.auth.gr/record/128802/files/GRI-2012-8293.pdf
    Take care
    Thanasis
    1. woodrat
      woodrat
      Thanks, Thanasis. The pictures are very useful .
      Dick
  13. Congratulations George. I just show your progect, having stay away from Pcs for the summer and I'm amazed by your scratch building method and the excellent and beautiful result. I'm looking forward to see your work on "Karteria". Thx
  14. Hi again. This is what I found in another book...
  15. Hi. According to my library, Those blind chain plates, seem like additional suport (beneath) for the channels themself. The eyebolts could be fitted for general use...(?). Thx
  16. Hi. See whether these sketces could help you... Thx
  17. Many thanks Liste. You are as always much analytic in your explanations. However I must say you set new elements in this discussion for which there are no (I don't have) any information from hystorical Gr texts I've read nor for the total Carron's products to rely on. These are the comertial for merchant use (special or by order I guess) carronade and the gunnade. And although I accept any simple description for the weapon from a ordinary sailor of that time, or from an with less knowledge historian, I don't know how to see this description from an English naval officer, who, I point out again, writes about gunnery results without ful information about the gun or its nationality. In any case, I really thank you all for this discussion which was much enlightening, at least to conclude that I can make only guesses. Thanasis
  18. Thank you all for your participation. I must say that, like in some other threads in this forum, I'm trying to exam infos that are revealed in texts from here and there, about a weapon on a schooner. What was written, is that on the schooner was a "big cannon" or "a heavy gun" or "a 48pdr gun" or "a gun with big caliber" or "a carronade" or "an obusier (howitzer)" and so on. The weapon was set in the prow as chase gun and nothing more. So examing the case of a carronade and as far I know, between 1800-1822 there was not 48pdr carronade but as I recently found, a Spanish 48pdr obusier (howitzer) that was used in Trafalgar naval battle (1805). According to what is written the French answer to a " carronade" was a 36pdr obusier (howitzer) and I don't know I should say, that in this naval battle, the English were refering to French captured "obusier de vaisseau" (naval howitzer), as carronade. Next I'm coming to the use of that weapon. If was a carronad, could be used as chase gun? As I' ve read it was used as unti-personel weapon. Couldn't its small range be a problem as chaser? I also have read that there were many type of carriages for a carronade to be placed on but despite the way, I want also to exam how the Spanish vertion obusier (howitzer) could be operatted. And finaly about the shot (ball) of a 48pdr cannon. No matter what the weapon (48pdr carronade of the text) was loaded with , why on the schooner were shots (balls) of a 48pdr cannon? Many thanks
  19. Thank you Wefalck. So, if I understand well, you also assume that. a. He refers to a carriage that was giving the ability to move the barrel also left or right. b. There should be a deck fitted pivot for securing the carriage and safe fire from the weapon. c.Yes, there was not traversing carriages at that time (1821) and especialy in a schooner, so that carronade coudn't be in a gun port possition. As about the shot, I gather that a 48pdr carronade could fire a 48pdr cannon ball under conditions. Thank you
  20. Hi all again. Sorry, I was waiting the resurrection of my pc to get back... So I pretty please for your help to my following queries about the writing of the text in the first post. a.The writer describing the carronade, specifies that is on a swiver and what we assume, is that he reffers to a mounted pivot-carriage. If I'm not wrong, the carronades were produced mainly on a pivot-carriage and had the ability to move up and down by a screw. So, can we assume that by using the term "swivel", determines that it was placed on a carriage by which had also the ability to move left and right? And if is so, can we consider that this carronade was not placed in a gun port (which it would set limitations) but maybe amidship or in the prow? b. Why the writer again specifies that the carronade was loaded by "a shot (ball) from a 48pdr gun (cannon)"? I'm not familiar but this seems to me that the carronade was loaded with a non proper ammunition, something for its own. Am I right? I would like to have your opinions. Ps: My English can't help me to see the defference between pivot and swivel. Many thanks Thanasis
  21. Thank you all. My last finding might explains everything.... I would appreciate if someone can confirm what I read somewhere that "the French supplied the Spanish with their own French made obusiers". http://www.histarmar.com.ar/InfHistorica/ArtilleriadeMarina/8-obuseros.htm
  22. Many thanks wefalck. The text it's from a translation since from the hardcover appeare that the book was published in London. The rest of your information are much convinient with what I also tent to belive in my research. However, it seems to me rather inaccurate for a Naval officer and in his "Memoir on the use of..." to reffer to his conclutions leaving ambiguities.!? I would be much obliged if you can direct me to a source, for placing big guns on slides. Thank you Thanasis
