Posts posted by druxey
Coming along well! As for oxidation(?) I wonder whether the color change is due to air or exposure to light. Skin oils will mark wood, for sure. If a piece gets 'dirty', I clean it using isopropanol.
- Keith Black, HAIIAPHNK and mtaylor
- 3
Those open rails were perfect for securing lines around.
- allanyed and Chuck Seiler
- 2
I make the carling scores angled and then cut the ends of the carlings to a similar angle and trim carefully until they fit flush to the beam top.
- mtaylor and mort stoll
- 2
When I wrote earlier 'from the keel up' I did not mean that the keel itself was covered first; just the hull planking. Those plates were put on next to last, with a small flange over the keel/garboard to overlap the first row of hull plating. The very last was under the keel itself, with another overlap to the side keel plates.
- Wintergreen, mort stoll, CiscoH and 4 others
- 7
- davec, CiscoH, GrandpaPhil and 2 others
- 5
I don't know Håkan's method, but I use miniature chisels. First, two diagonal stabbing cuts to define the two sides of the score, then shallow cuts to cut the score to depth. Once you've confidence practising on scrap, it is not that difficult to acheive.
- albert, TBlack, Wintergreen and 2 others
- 5
On British Naval ships, plating began at the keel upward and from aft forward. Upper and aft edges of the plates gave the overlap.
- Bob Cleek, Thukydides, catopower and 4 others
- 7
We feel your pain. But those beam arms were good practice for what will come above on the gun decks!
- AON, mtaylor, mort stoll and 1 other
- 4
And now, a really good clean up, I think.
- Canute, rlb, thibaultron and 5 others
- 8
Thanks for the reference, Siggi!
- mtaylor, Keith Black, Siggi52 and 1 other
- 4
Welcome aboard and thanks for introducing yourself, Mark.
- MisterMeester, Keith Black and mtaylor
- 3
A very nice trio indeed! Well done, Eric.
Please use a soft-headed hammer for the purpose!
- mtaylor, Canute, thibaultron and 1 other
- 4
Nice pissdales, Siggi. But I thought that they were a bit smaller than yours. Do you have a reference for their size?
- Keith Black, FriedClams, mtaylor and 1 other
- 4
Looking lovely, Keith, and not in the least like any firewood that I've ever seen.
Having worked with padauk (full size, not on scale models!) in the past, I know how easily it can split and splinter. That you have been able to carve at scale the way you have is astonishing! When you began, I was very skeptical.
- mtaylor, HAIIAPHNK, Keith Black and 1 other
- 4
Love the dirty, oily finish! I can almost smell it.....
- Canute, mtaylor, Old Collingwood and 4 others
- 7
Muscongus Bay Lobster Smack by cdrusn89 - FINISHED - Model Shipways - 1/24
in - Kit build logs for subjects built from 1851 - 1900
Check the photos in the instructions for how the rudder should look!
