Posts posted by druxey
The bow ports were not armed: no space for working a gun! The were used as bridle ports for anchor handling. The vertical half-port lids illustrated were 'for example' and not drawn for all the other ports. You could not have a conventional lid as there was nothing but the rail above the port opening. There was no place to fit a hinge to! The advantage of these lids was that in a heavy sea you would not ship as much water over the decks as would happen with open ports.
mnl is correct; watercolor is a transparent medium. You can also see the background through the ships' masts and the knee of the head.
- thibaultron and mtaylor
- 2
There are several suggested routes you might take. Try this first, though:
If you used white glue, rubbing alcohol will soften it so that you can disassemble the planks and try again. Wetting the planks , you can re-shape them, then let them dry. The second time you now know what to look for and check on. It's always a learning process, no matter how long you've been building models!
'Sea' what you can do! (groan)
Lovely touch and a tip of the hat to SeaWatch!
Only 1,100km or 684 miles for me! More economy with a Honda Civic....
- mtaylor, Jack12477, thibaultron and 1 other
- 4
Perhaps a thin wash of brown to tone it down a bit more? It draws my eye just a little too much. Again, it's a matter of personal taste.
- Chuck, mtaylor, Thukydides and 3 others
- 6
Lovely clean work, Erik!
- Canute, Stuntflyer, Erik W and 1 other
- 4
Spare spars might have been lashed to the bulwark tops except that, in your case, the rail does not continue over the ports! Possibly they were lashed vertically to the foremost shrouds.
Very nice work on the spars and the finish looks excellent.
Very effective and grungy!
- mtaylor, Jack12477, Keith Black and 2 others
- 5
A head stick was certainly in use in the 18th century on fore and jib sails, as shown above, but I've never seen a contemporary 17th century English yacht drawing or painting that even hints at their use. If anyone can point to the arrangement this at that time, I'd be appreciative of the evidence.
I rather like the 'greasy' bars, actually, Mark! A nice inadvertent touch. Good start to planking. I hope you'll leave some of those frames showing.
- mtaylor, Keith Black and No Idea
- 2
- 1
Lovely progress, Mark. Looks like the grill bars could use de-greasing!
Hope you are recovering well.
Very, very impressive all round, Erik.
- Canute, Ryland Craze, Erik W and 2 others
- 5
Steven: You need to stretch the SilkSpan, wet it with water alone first and let it dry to make it drum-tight. Then, when you re-wet it with dilute acrylic, it will initially sag, but re-dry tight and smooth again.
- Mark Pearse, Ian_Grant, Cathead and 4 others
- 7
A very nice result, MC, your frustrations notwithstanding!
SMS WESPE 1876 by wefalck – 1/160 scale - Armoured Gunboat (1876) of the Imperial German Navy as first commissioned
Fascinating and amazing detail!
