Everything posted by druxey
That was an hour's celebration and fun. Thank you, Steven!
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Heaven knows what might have happened had Caligula survived longer!
Just catching up with you, Mark. Unfortunately, in our ship model world re-do's are the rule rather than the exception. It makes you a member of the club. There, feel better now? Hope the rework goes well for you.
- 505 replies
- vanguard models
- Sphinx
The dory kit is not 'dumbed down', as other builders will testify!
Lees unfortunately nodded here: man ropes were not knotted at intervals. However, footropes to the jibboom were.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Porchie: Even though the paintwork may not be brilliant, try to keep as much of the original as possible. Resist the temptation to paint over what is there! Restoring missing patches of paint is a better solution. Keith: I agree that earlier 'restorations' make life far more difficult than an untouched model. Everyone: whether or not 'real' ships were rigged with seven yards per mast or not is irrelevant to this model. One doesn't try to alter things when restoring however 'inaccurate' it may be, unless it is obvious that something was not original but a later addition.
Handles are handles (one I have was made in India) but the blades should be the real deal. A box of 100 will last a long time!
The dory kit will be a good re-set for you. Good luck with it. The dory is a good starting point for learning basic techniques that will help you with more advanced models later on.
Coming along well, Mark. I've found marking levels inside the hull easier by poking a thin piece of wood or metal attached to my height gauge between the frames rather than by reaching over as you have done. Funny how myths like ammonia have circulated for years. There are others: don't use beeswax or tea on your rigging or sails; both are acid and in the long term do no good. Conservators' wax and material dye or acrylic paint are much better options.
NAIAD 1797 by Bitao - 1:60
druxey replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
A happy New Year to you indeed! -
I'm sure you'll be getting up the learning curve quickly! I used a pin vice for drilling small holes using HSS bits for years before I could afford a decent hand-held power rotary tool. I held one forefinger over the far end of the tool to steady it (very little pressure!) and rotated it with the other hand. I had very few breakages after that with even #78 bits.
Well done: good shots with your 'cannon'! You could try ironing out the bubbles on the sail on low heat. Congratulations on successfully completing your model.
- 17 replies
- norwegian sailing pram
- Finished
You still use pennies, South of the border???? This looks like an interesting build, Chris.
Lovely work, Bitao.
