druxey
Everything posted by druxey
  1. I honestly don't think, even with a metal slitting blade, that trying to cut such thick brass will do your Byrnes' saw any good. You might do better to consider a jeweller's saw and cut by hand, unless you have access to an industrial strength saw. Replacing the motor or other parts, since Jim's death, would also present a problem.
  2. Those images make me smile. Well done!
  3. I understand others have received their copies, so it sounds entirely possible your has gone AWOL. Try e-mailing the publisher again.
  4. There are a number of good books on construction of this era that will explain all that you've asked about, and much more. Take a look at he SeaWatchBooks web site for a good selection.
  5. This is well worth looking forward to, Dan. Thanks for sharing your process. I note the difference in mortices for the lashings between the battens on the ship itself and the cross sectional model. the lashings just appear and disappear again.
  6. 'Shivers' are sheaves: live ones are rotating ones in the fixed blocks in the sides of the ship. So, in modern language: fixed blocks opposite the mizen mast.
  7. I believe that Texas A & M is still one premier place for marine archaeology.
  8. Ah, the joys and frustrations of rigging! Hopefully you can install the cleats before permanently securing the masts with shrouds.
  9. This is a problem with modern re-drafted plans - unless it's stated one doesn't know! Contemporary plans show both the line of beams at the side and centreline. In this case you don't even have a line of ports to give you a clue. The Royal Museums Greenwich hold a sheer and profile of the Pandora class: https://www.rmg.co.uk/collections/objects/rmgc-object-83477?_gl=1*1l5sqqk*_up*MQ..*_ga*NTU5MTEyMTE3LjE3MzE2NzU5NTI.*_ga_7JJ3J5DBF6*MTczMTY3NTk1MS4xLjEuMTczMTY3NTk3NS4wLjAuMA..*_ga_4MH5VEZTEK*MTczMTY3NTk1MS4xLjEuMTczMTY3NTk3NS4wLjAuMA.. This would be a more reliable starting point for you.
  10. Beautiful and clean work, marsalv. I usually delay attaching the knee of the head until after planking and work on the external hull is complete, to prevent it breaking off. Also, it is not in the way when planking the bow.
  11. Excellent advice for those with sufficient patience!
  12. Congratulations on completing your model, Greg. Lovely looking case. But might I suggest a couple of ventilation holes in the base covered with fine mesh to prevent insect entry? A sealed case is not good for a model.
  13. That is a lovely hull you have there - it looks in pretty good condition.
  14. Examples of wooden pin in the Royal Museums Greenwich collection range from 43 to 49 cm (17" to 19") in length and 4 to 5 cm (1 1/2" to 2") in maximum diameter.
  15. Just checking out your work so far, Håkan. Beautifully done. Glad to know that this will be continued.
  16. Hopefully the bulkhead bracing will keep the hull straight.
  17. Condolences on this, Alan. As the others said Mark II will probably go quicker and be better than the Mark I version.
