Everything posted by druxey
How will laser cutters compliment our hobby tomorrow?
druxey replied to EspenT's topic in 3D-Printing and Laser-Cutting.
Tomorrow is already here!Pparts that are 3D printed are really high resolution now, but items such as carved work lack a certain 'life' and look too perfect. -
I simply use a coffee mug warmer as not a large container is needed for model parts.
- 257 replies
- pegasus
- Swan-class
Swan class 3D model in progress
druxey replied to dvm27's topic in CAD and 3D Modelling/Drafting Plans with Software
Lovely but, as someone else pointed out, the water drainage holes in the spritsail are still needed.- 141 replies
- pof swan series
- swan
I usually dip the parts in water after Sparex before blackening. You don't want to contaminate the blackening agent! (Acetone shouldnot be necessary unless you touch the parts between steps in processing.)
- 257 replies
- pegasus
- Swan-class
Different chemicals are involved for blackening pewter than for brass/copper. For pewter selenious acid, for copper or brass one of several sulphur compounds. Diluting the solution slows the chemical reaction and produces a thinner and more stable surface layer.
- 257 replies
- pegasus
- Swan-class
The translucency of the sails in 'sunlight' is very impressive!- 141 replies
- pof swan series
- swan
Are you referring to the fish davit? It can be mounted port or starboard as required. See TFFM, 12.7 to 12.9.
- 257 replies
- pegasus
- Swan-class
Actually, one has better control using a larger tool. You will file across the transom rather than along it. (For model work I usually use a ½" bevel edge chisel - or larger - a lot of the time. One can judge angles more easily than with a narrow tool.)
- 39 replies
- Norwegian Sailing Pram
- Model Shipways
Having the transom too far aft may come back to bite you. The planks may fall short at either bow or stern. I'd go for the isopropanol for a do-over. It won't hurt a bit!
- 28 replies
- Lowell Grand Banks Dory
- Model Shipways
Here is a diagram of a chain pump. From the inscription, it looks to be from 1772: https://www.rmg.co.uk/collections/objects/rmgc-object-86580?_gl=1*guf33e*_up*MQ..*_ga*MTE5NTQwMjM0MC4xNzI5NjgyNjk2*_ga_7JJ3J5DBF6*MTcyOTY4MjY5NS4xLjAuMTcyOTY4MjY5NS4wLjAuMA..*_ga_4MH5VEZTEK*MTcyOTY4MjY5NS4xLjAuMTcyOTY4MjY5NS4wLjAuM The segmented tubes (square in section on the 'down' or return side) were replacing the bored elm pipes.
Lovely! Just remember that the ensign (or any other flag) goes in the same direction as the wind filling the sails!- 141 replies
- pof swan series
- swan
