Everything posted by druxey
Swan class 3D model in progress
druxey replied to dvm27's topic in CAD and 3D Modelling/Drafting Plans with Software
Those images make me smile. Well done!- 141 replies
- pof swan series
- swan
This is well worth looking forward to, Dan. Thanks for sharing your process. I note the difference in mortices for the lashings between the battens on the ship itself and the cross sectional model. the lashings just appear and disappear again.
- 22 replies
Thresher & stable engine by RGL - FINISHED - Plus Model - 1/35
druxey replied to RGL's topic in Non-ship/categorised builds
Very convincing rust and grime! -
'Shivers' are sheaves: live ones are rotating ones in the fixed blocks in the sides of the ship. So, in modern language: fixed blocks opposite the mizen mast.
Just stumbled across this log. Lovely work!
- 201 replies
- Oyster Sharpie
- first scratch build
Nautical archaeology internship programs
druxey replied to Ferrus Manus's topic in Nautical/Naval History
I believe that Texas A & M is still one premier place for marine archaeology. -
Ah, the joys and frustrations of rigging! Hopefully you can install the cleats before permanently securing the masts with shrouds.
This is a problem with modern re-drafted plans - unless it's stated one doesn't know! Contemporary plans show both the line of beams at the side and centreline. In this case you don't even have a line of ports to give you a clue. The Royal Museums Greenwich hold a sheer and profile of the Pandora class: https://www.rmg.co.uk/collections/objects/rmgc-object-83477?_gl=1*1l5sqqk*_up*MQ..*_ga*NTU5MTEyMTE3LjE3MzE2NzU5NTI.*_ga_7JJ3J5DBF6*MTczMTY3NTk1MS4xLjEuMTczMTY3NTk3NS4wLjAuMA..*_ga_4MH5VEZTEK*MTczMTY3NTk1MS4xLjEuMTczMTY3NTk3NS4wLjAuMA.. This would be a more reliable starting point for you.
L'Amarante by marsalv - 1:36 - POF
druxey replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Beautiful and clean work, marsalv. I usually delay attaching the knee of the head until after planking and work on the external hull is complete, to prevent it breaking off. Also, it is not in the way when planking the bow. -
Excellent advice for those with sufficient patience!
Congratulations on completing your model, Greg. Lovely looking case. But might I suggest a couple of ventilation holes in the base covered with fine mesh to prevent insect entry? A sealed case is not good for a model.
- 123 replies
- Le Pourquoi-Pas
- Constructo
Examples of wooden pin in the Royal Museums Greenwich collection range from 43 to 49 cm (17" to 19") in length and 4 to 5 cm (1 1/2" to 2") in maximum diameter.
