Everything posted by druxey
I slide the tube into a hole in a brass plate of the thickness needed for the slices. I then use a razor saw to cut off the protruding tube. This prevents distortion and makes for consistent slices. A few passes with a fine file over the surface cleans up the ring. If there are any protrusions in the hole, a small pointed burr will clean them out. I then take out the ring, place it on a brass block and (gently) flare each side with a centerpunch.
- 525 replies
- anchor hoy
- hoy
Thank you for your thoughts and comments on resistance silver soldering, Gerald. Most informative. Thanks also for the url. Amazing work, beautifully executed. (Folk: if this site is available to view only for one month, rush, don't walk there!)
- 281 replies
- falls of clyde
- tanker
Nice to catch up with you, Rusty!
- 310 replies
- cheerful
- Syren Ship Model Company
Another miniaturist strategy is to laminate the hull in such a way that one thin lamination becomes the boot topping. Disassemble after shaping the hull, paint the various sections, reassemble and - voila! No masking required. Of course, that strategy is too late to use on this model.
- 287 replies
- michelangelo
- ocean liner
If the curve is slight, thin paper will form nicely. I suppose, say, under the counter, you will need to pattern and cut a section to shape.
- 287 replies
- michelangelo
- ocean liner
The problem of too thick striping tape is one I've had as well, Dan. My solution was to stretch and paint thin paper the color required, then cut off narrow strips. I then tape the ends of the strips face down so they won't blow away and spray glue the backs. Result is instant thin striping tape. Might work for you?
- 287 replies
- michelangelo
- ocean liner
Welcome, Sharp, you ex-pat! You'll find lots to look at here.
Oh, yes, I've had that problem!!! I also add x and y scales, and also I was told never to scale off a print. I've rejected commercial prints from e-files, not hard copy scans, as some commercial printers also do not print at exactly 100% unless calibrated against a test print and corrected. It's a printing jungle full of traps out there, folks!
Tried turning the model upside down and shaking it, Ed? Just kidding! Lovely work and progress, as usual. I love the open boat partially in frame as seen in the second to last photo.
- 3,618 replies
- young america
- clipper
Bitumen can be problematic. It never really dries out completely. However, I don't know about very thin washes of it; perhaps this isn't an issue. In paint it certainly 'crawls' over time and can alligator as well. You could try washes of acrylic or, if you don't want to use that, artists' oil paint. Burnt umber or Van Dyke brown would be better substitutes.
