Everything posted by druxey
That finish looks really nice, Toni! Do you brush it on?
- 1,449 replies
SOLEIL ROYAL 1669 by michel saunier
druxey replied to michel saunier's topic in - Build logs for subjects built 1501 - 1750
Impressive! -
This seems a reasonable proposition. There should be sufficient space under the lower chocks to slide the pawl into place.
- 525 replies
- anchor hoy
- hoy
Dan's method is the best way: and you don't need the expense of a lathe! That's how the old-time mast and spar makers did it as well.
If that errant impression is bothering you, Clare, try this: As you are using a very soft wood, repeated drops of water on a paintbrush tip into the hole should swell the wood and close the gap, or at least minimize it. Hopefully the stain you've used won't be affected. Thank you for the explanations and terms used: it's fascinating stuff.
Brilliant. The pirates pirating off other pirates that.... on and on, like an infinite hall of mirrors! Hopefully they will soon disappear up their own collective fundus.
I usually love those 'aha!' moments, Dan. This isn't one of them, I take it!
- 1,449 replies
Nothing like experience, eh? The revised version looks good. However, is either the drumhead too large in diameter or the pawls and spindle too small? I was looking at the image on page 1 of your log.
- 525 replies
- anchor hoy
- hoy
I would concur with Dan. However, it is possible that the score for the fish davit to sit in is angled and is deepest inboard, tapering to nothing outboard. If so, the outboard aspect would be exactly as drafted.
- 1,449 replies
Thank you for my smile this morning, Ed. Beautifully executed work!
- 3,618 replies
- young america
- clipper
If the NMM (now RMG) database has mis-identified this, one can let them know by clicking the box below the description: Help us Do you know more about this? Share your knowledge
Ah, well. You still have the evidence of your deck joinery in your photographic records. Well done, Frank.
I apologize for the late reply, Steven: I was away. The clips from Oz are seen in the photo. No idea where my wife picked them up, other than an office supply type store. I imagine you should be able to find them. As for removing 'extra' glue from the interior of the hull, if you used white or yellow glue, it should soften with a careful application of rubbing alcohol.
For those not familiar with 4H leads, these are invaluable (held in a clutch pencil/mechanical holder) for mark-out. Sharpened, they keep a point and one can draw extremely thin lines using them. They improve accuracy of mark-out dramatically! Cliff is offering you a great deal - take advantage of it!
- 3 replies
- 4h leads
- mechanical pencil
For yet another approach, see the topic under 'Reviews': Swan IV, Sailmaking Supplement.
Thanks for this contribution, Richard!
- 4 replies
- 70 gun
- third rate
(and 4 more)
Good progress, Maury. You might consider raising the demarkation line a little fore and aft before painting the underwater body. It counteracts the optical illusion of the ends of the line dropping due to the shape of the hull.
- 525 replies
- anchor hoy
- hoy
