druxey
Everything posted by druxey
  1. All you need is a ply sheet with the correct shape cut out and mounted at the correct height on a building board. The model sits vertically inside the cut-out.
  2. Copper is described as 'ductile' and will stretch a good way before reaching (and exceeding!) its elastic limit.
  3. Ah! I see you were able to move Albertic safely to your new home. Looking forward to your progress reports, Michael.
  4. Welcome back, Gary! It's nice to see your beautiful model beginning to progress again. Nice workbench too!
  5. Ideally internal stringers would solve the issue (while still retaining the cross-spalls) However, in your case perhaps an external jig will be required to maintain hull form until you can install stringers and permanent cross-members.
  6. Time spent fine-tuning tools is well spent!
  7. Check the factory primary bevel. Keep it as recommended by Mike Y and add a secondary edge bevel.
  8. Lovely work and photography as well!
  9. Congratulations on completing a lovely gem of a model, Rusty.
  10. Mark: for various odd-shaped spaces, I've seen wedge-shaped ledges rather like the ones in my illustration.
  11. There is no 'correct' or 'wrong': it has to be something that you are satisfied with.
  12. I concur with Mark: this was probably experimental. Obviously it was not successful as it was not generally adopted!
  13. Miniature left hand taps and dies, although not inexpensive, are available, Frank.
  14. Nice beginning, Chris. When my daughter was young, I had to take ten years off from any modeling. Well, not quite true: I built a number of things such as a doll's house with her! But no ship modelling.
  15. You are definitely Master of Moving Metal! Your brief history was fascinating to read: congratulations on the Significant Anniversary. I hadn't realized that you were responsible for that lovely Bucklers' Hard diorama, although I was well aware of your beautiful model car work.
  16. Yes, Greg; those old-time shipwrights knew a thing or two!
  17. Like I said - you'll be done in no time! She's looking very nice indeed, Mike.
  18. Copper will work more easily and not corrode. I'd agree with you that the wire should be replaced. Annoying!
