druxey
Everything posted by druxey
  1. Well done, Erik. I doubt that anyone will spot the slight misalignment at the bow.
  2. Impressive - as usual, Amalio!
  3. I'm relieved that you didn't use a sledgehammer to align those frames, Gerald! It's always a delight to read about your methods and processes and see the results. And yes, I'll be patient until you reach the turnbuckles.
  4. Lovely work so far, Frank. I still can't get over the light scantlings of those frames!
  5. Beautifully executed, Michael. Using dial indicators is a spot of genius!
  6. Prob'ly, Mark!
  7. And you'd probably lose count of the turns! Lovely result, Gaetan.
  8. I don't believe that I've ever seen parcelling carried out on a model before. Groundbreaking stuff, Ed!
  9. See my illustration of a fixed block. I only found this out from the extract of the draught shown a couple of years ago. It makes sense for repair when necessary. Fixed block rev.psd
  10. A good solution, providing that you do not get cumulative error along the deadwood.
  11. In the photos, the pattern of nails appears to be as they would have done this c1800. It's pretty unobtrusive: the rougher the surface, the more drag and turbulence it would create. At scale size, the pattern would almost disappear.
  12. Good to see the hull growing, Ben, even if it is slowly. Don't forget to add the 'ears' on the fixed block later.
  13. Oh my, Karl! Carefully does it on this model.
  14. Even in extreme close-up your work looks impeccable, Amalio.
  15. I've used Titebond without issues. Remember to to make a balanced 'sandwich' with grain alternating directions at the gluing face. The glue does re-activate with heat, but I'd be concerned about how deep into the layers heat would penetrate. Heat is great for simple veneering, though. (See John's posting, above.) I apply Titebond generously and clamp the assembly well with waxed paper or cling-wrap to contain squeeze-out.
  16. Neat work, but the nailing would be less obtrusive at scale.Try flattening the dimpled plates again, and see how that looks.
  17. Looking terrific, Albert.
  18. And I always thought 'Air conditioner' was 'Egg-nishner'! But we digress....
