druxey
Everything posted by druxey
  1. Remember to factor in the weight of a sweep that is 30' 0" to 50' 0" long!
  2. 24' 0" planks are well within normal limits. Sounds good!
  3. I was thinking of sweep ports on the upper deck. On the berthing deck it must have been a very different operation. I suspect using tackle from the yard arms and feeding the inboard ends of the sweeps in through the ports.
  4. In such a situation the bolt was probably secured through the inboard edge of supporting gangway knee.
  5. Helmut: I 'm sorry that you've had major health challenges, but you seem to have overcome many of them! Hopefully things are now stable and improving, and that you can continue your modelmaking rather than health concerns.
  6. Even if one is not 'into' making dioramas, this is an inspirational volume to look through from time to time. Beautifully photographed and described. Oh, many happy returns and wishing you a healthy, happy year ahead, Mr. Elwood!
  7. I've never seen a model where the mast wedges actually were functional as in full-size practice. An impressive miniaturization of the technique, Ed.
  8. Congratulations on completing and, well, launching your launches, Bob! Cute little things, aren't they?
  9. Nice to see you back, Dick. The arrangement you show looks very convincing. Logically it would be easier and safer to bowse down the laniards from inboard - especially if one couldn't swim - although the spread of the shrouds athwartships would be less advantageous.
  10. There is vinegar (CH3COOH) aka acetic acid in mustard.
  11. They would have been threaded through the sweep ports (on the diagonal, as the width of the sweep blade was wider than the port) from inboard. It would have been quite the operation, even in a dead calm.
  12. No. 2 style: If one substituted a metal ring for the rubber or neoprene one and slightly modified the taper, it would function the same way and be heat-resistant. BTW, I have one of Michael's third hands: it is brilliant.
  13. Great discussion! While Lees' contribution to rigging knowledge is significant, there are some errors still uncorrected in his second edition. Even Steel contains the occasional typographic error. None of us are perfect, but we can usually sort things out from multiple sources.
  14. Just catching up with this thread. There is no substitute for a quality tool. I smiled at Michael's reference to James Krenov. A wonderful designer/craftsman. For gnarly woods, a cabinet scraper is a useful alternative to shards of glass, and perhaps a little safer as well!
  15. Going back to the first image, I'd not noticed the men pictured inside the 'hamster wheels'.
  16. Oops! I stand corrected; I goofed. I plead wooly-headedness due to 'flu! The power of 8 it is. I didn't have enough brainpower today....
  17. Un autre chef d'oeuvre, Gaetan??? And that that scale! It's too bad that each time you double the scale, the volume of wood required multiplies by a power of 4. We await the laying of the keel ceremony....
  18. Yes, the cross-section of a plugstock rudder is circular. The stock plugs the hole!
  19. The stay collar should loop around behind the gang of shrouds rather than over them. As the stay tightens, the shrouds will be cinched in slightly. As Chuck says, avoid that strap!
  20. I doubt we would have spotted the flaws if you hadn't circled them!
  21. Interesting. However, gun ports were never placed one above the other on different decks.
  22. That's a lot of add-ons required for a top of this era! Beautiful as usual, Ed.
