druxey
Everything posted by druxey
  1. I believe WOP is the acronym for 'Wipe-On Poly(urethane)', Wefalck.
  2. Looking good. After you've done a few hulls, it will be much easier! The first time is the toughest.
  3. It's interesting to note the variations in direction of keelson scarphs. On my present model the pieces were installed starting aft.
  4. Great progress, Frank. I can imagine the awkwardness of planking that bulkhead in situ. And the language that accompanied it!
  5. As usual, you live fully up to our high expectations of you! Lovely work.
  6. Did you look at David Antscherl's planking tutorial? That speaks to this topic.
  7. Good progress, Steven. Is there a reason you didn't plank both sides in tandem?
  8. These elevation marks were made and used only on land-based ordnance. Obviously they would be useless at sea!
  9. Just caught up with you as well, Drazen. You use some interesting strategies with excellent results. Looking very nice!
  10. With all due respect to lehmann, many years ago I used the method I described on a model for my daughter. It worked fine. Of course, if the ply is too thick, it's another matter, but I don't think kit maker supply wood any thicker than they need to!
  11. Cher Michel, C'est magnifique! Thank you for sharing your work with us. Your workmanship is superb. If you continue and rig the model, it will be even more impressive.
  12. You will return and continue Bellona, Mark? Be still, my beating heart! Looking forward to the next instalment. In the meantime, wishing you a safe and hassle-free move.
  13. I believe that you are correct, Alex. The waterway/margin plank was a longitudinal stringer that strengthened the sides and, like the deck clamps, would have most likely been joined in the same manner.
  14. Hearty congratulations on the completion of a very fine model, Chuck! Well done.
  15. I guess there is an exponential amount of dust produced as the scale of the model increases! Have fun, Gaetan....
  16. As has been remarked many times on MSW: ebony is hard to work, does not glue or bend well and is toxic. It is also expensive. Consider dyeing a different specie of wood black instead. Holly has worked very well for me.
  17. Paper patterns won't distort if the adhesive does not contain water. I use rubber cement (a thin coat on each surface, allow to dry and press together).
