rlb
3 Followers
About rlb
  • Birthday 05/17/1960
  • Gender
  • Location
    Troy, New York
4,873 profile views
  1. Glad to see you back in the workshop, Elia! I am still working on my Oneida, off and on. More off than on. Last year I thought for sure I would finish, but no, I haven't touched it since last May. Perhaps I will be inspired to continue soon. Ron
  2. Tonphil1960, Gregory is basically correct. I started with the Lumberyard "kit", but I have gone far past what you would get if you build the kit as it comes to you. I am using the Chappelle plans and sail plan from the Smithsonian (along with many additional sources for various things) to build a more detailed and nuanced version of Oneida. Below is a link to the Smithsonian website-- https://americanhistory.si.edu/about/departments/work-and-industry/ship-plans Good luck! Ron
  3. Hi John, I haven't checked in in a while, great work on the coamings and the grating! I haven't seen anyone do one of those by hand. I'm sure someone has, but I haven't come across it. Nice work! Ron
  4. Alexander, Thank you for your kind words. When I need inspiration, I don't have to look further than your own work! Ron
  5. Thanks for this timely tutorial, Toni. It is exactly where I am at with my Oneida.
  6. Dave, that is a great point. I have thought about it, and my initial thought was to greatly simplify the collar and do the canvas cover. Then I thought that fiddling with trying to make a cover, and realistically fastening it would be difficult. However, I didn't research to find out what it needs to look like and how others may have done it. Now I feel like doing some searching on this! I have no concerns that any work will have been wasted (after all, on one will ever see the stove!) At this point my options remain open. Ron
  7. John and Dan, I enjoyed meeting and talking with you both. Always nice to get to know someone beyond their profile photo and user name! Mast collars: I started by cutting a bunch of pieces with a 45 degree angle and gluing them together. If I really wanted to get it right, I should have cut 22 1/2 degrees off each side of a piece, to have the wood grain radial. I was satisfied with just showing that the collar is made of eight simulated "wedges"-- These were then sanded roughly round-- Next I drilled out the center, glued in a short piece of dowel, and turned the piece round. After it was round, I drilled the dowel out-- Here you can see I've started roughing out the opening of the first one to fit the fore mast, and other has the dowel glued in-- I used my lathe, but lacking that I could have chucked the piece in a standard drill-- One difficulty was shaping the cut out to accommodate the rather sharp rake of the masts, especially the mainmast. In addition, my shaping of the masts was not perfect, with some variation in the eight sides. That and the rake made it so the collar will only fit on one way (hence the label "F"(forward) on each collar. Each one broke apart at least once as I was chiseling it out. That ended up being a good thing, as the joints became a little more pronounced after regluing. One down, one to go-- Here are some photos of the masts with the collars dry fit on deck-- I believe that is now a wrap for the hull and deck. I am not going to redo the gratings--the holes are only a tiny bit too large. They should be no bigger than 2 3/4", and they are 3". So with that, it's time to start making rope for the standing rigging. All for now. Ron
  8. Oneida is getting ready for her playdate with the other ships tomorrow in New London, CT-- Ron
  9. It's definitely a "forest of frames"! She's going to be a beautiful model, John, as your others. Ron
  10. Hi Dan, I'm planning on going this year, but I was on the fence about taking Oneida, since I took her last year, and thought maybe I should wait until she's finished before bringing her out again. But with that encouragement, I think I'll bring her! Ron
