Posts posted by MikeB4
I have finally reached completion. This project has brought me both great satisfaction and agony from time to time. The fact that I got to build this challenging little model online with all of you is still amazing to me.I think about the models I built as a kid, I never dreamed of how someday we'd have this technology that would connect us all. This is a fantastic website and I hope it will be around for years to come.Thank you for all your support.
I miss placed the deadeyes that came with the kit and I've spent way to much time looking for them. them damn gremlins are t it again, Fortunately my Fair American kit had some that are the right size only made off walnut. They'll do, by the time I'm ready to build that Fair American kit I'll have upgraded most of the parts with better stuff than what comes in the kit anyhow.
I don't know what your experience with ship model building is, this same kit was my first model and I didn't quite get the deck whittled out to the specs they needed to be. Once I got to the point where I was to install the deck furniture I found that everything didn't fit on the deck the way it should have. So if this is your first wood kit my advice to you is take your time and make sure you carve the hull to it's proper dimensions this is in my opinion the most important aspect of the build, it's your foundation basically everything is added to that hull and if it's off everything is off.
I have a pair off pliers that are specifically designed for looping wire. It's probably the most used tool I have in my toolbox besides my Xacto knife. I don't think I could effectively fabricate any of the iron work without them. Anyway they retail for only around $13 US dollars and they're well worth every penny.
I finished the chain plates. I decided to make another attempt at soldering, which I had completely failed at the last time I tried. Although I'm pleased with the out come this time around it wasn't easy. It was quite a struggle to get the solder to flow. I cleaned the parts in acetone first to make sure there wasn't any oil on the surface of the metal. Then applied flux with a tiny piece of solder. The flux would bubble up from the heat and evaporate before the solder would reach it's melting point. once I got it to melt it would bead up and not flow properly because there was no flux on the part at that point. I managed to get the chain plates done but it took hours, Needless to say there's something here I still don't get when it comes to soldering.
- Ryland Craze, jct, PAnderson and 6 others
- 9
I completed the Jib. I also decided to mount the boat to it's base at this Time, I think this will make it easier to rig. You'll notice I extended the the front Iron band for the jib. it fastens further down the stem than what the directions show you. I did this because there's a piece of brass wire running from the top of the stem to right above the fasten. Yes, I broke the stem off, I almost made it threw the build without this infamous break. At least I know I'm in good company. I don't feel to bad about this Modification because looking at the original museum model it appears to fasten further down the stem also. I know this in no way makes mine a museum piece but at least I don't have to feel it's completely inaccurate.
Eric,
Where can you get those basic rigging tips?
Mike
- Ryland Craze, dgbot, Jack12477 and 3 others
- 6
Your boat is coming along nicely,Good work.
- Ryland Craze, Erik W and Canute
- 3
I've decided to send away for the right size rope. I'll obsess over it other wise, you can never have to much rope around anyhow.
- Erik W, RichardG, Ryland Craze and 3 others
- 6
- Duanelaker and Erik W
- 2
18th Century Longboat by MikeB4 - FINISHED - Model Shipways - 1/4"=1'
Yes, I'm going to shop around for a case that will fit and display this properly.
