Everything posted by mtaylor
I did some looking at my info.... French frigates didn't seem to have them according the plans. I have to wonder if there was any reason why they're on some and not on others. I don't recall seeing them on US frigates either so maybe they're a ship of the line only thing?
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
mtaylor replied to Bitao's topic in - Build logs for subjects built 1851 - 1900
Bitao, I'm with the others and will welcome you home to MSW. I know that reading your build, I'm learning a lot.- 257 replies
- young america
- Finished
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Pat, it looks like it's flip a coin time on the belfry. Given the info you've shown, it would seem that metal would have been likely but then a case can always be made for wood. My thinking is that being attached to the water tank that metal would seem more likely. But then again, you're the model builder, the master of the realm, and most knowledgeable.- 1,006 replies
- gun dispatch vessel
- victoria
Top and butt
mtaylor replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
I think it the "sap:" is the sapwood. The outer layer just below the bark. But, I'm not sure about the 6 foot part as I would have thought that the sawing operation would have removed much if not all of it. -
Thanks for clearing that up on the French. I was wrong.
I always thought it was only the English who used them.
Crack filling technique
I use plain water. Mix the water and glue first, then add the dust. -
In a nut shell... yes. If I plan in pear, the filler is made with pear dust. And Turangi made some good points also. -
Don, save the sanding dust as you sand as sawdust is too large to large. I use a coffee filter rubber banded to shop vac. Then, equal parts PVA (white) and water and make a thick slurry with the sanding dust. Pack it in, let it dry and resand. -
Anyone out there working on a card model?
mtaylor replied to gagliano1770's topic in Card and Paper Models
There's been quite a few card models here. Go to the kit area and search using "Card" and "Titles Only",. -
I'd recommend white glue such as Elmer's Glue All or the yellow Elmer's Wood Glue for wood to wood. For wood to metal... either CA or epoxy. Others will have their preferences but those are mine. I like the Elmer's as alcohol easily breaks the bond if need be and removes the clue from the wood when need be.
Very timely on this since according to my NRG calender, yesterday was the anniversary of the battle. Adding this one to my growing queue of podcasts.
