Everything posted by mtaylor
My observation is.... get the kit you would love to build even Victory. Then after getting it, open and box. After realizing it's the deep end of the pool, put it in the closet and during the learning, take it down occasionally for motivation. The ModelExpo series seems like a good place to start or some of the others that have been mentioned like Vanguard Models. You're next step.... take the advice given about starting simple. The first kit I bought was Billings Vasa. Took one or too looks and put it up on the shelf and then started on a simple kit and went from there. After some simple models, I felt comfortable trying the Vasa. This was back before internet forums such as this so basically, I was on my own.
Nice work. I hope it cools down for you soon.
- 553 replies
- sloop of war
- constellation
(and 3 more)
Sweet work, Glen. I suspect all of us following along were holding our breath with you on the bottling.
- 194 replies
- Bottle
- Treasure Fleet
(and 3 more)
Very well done, and I empathize completely with your agonizing reappraisal of the ups and downs. You've learned a lot in a short period of time and that will carry you through the next project. For those of us following along, we've learned a few things also. It's all part of the journey and thanks for sharing yours.
- 460 replies
- Finished
- Flower-class
Welcome to MSW, Giuseppe. When you do get your model and start it, do start a build log. It is a great way to get help when you need it and also to meet others.
Nice work and raising the ensign is a good sign.
- 460 replies
- Finished
- Flower-class
I suspect you are on the right path with this. Hemp was used for the tillers and because of this'resulted in it being shot away and thus the need for the solid rod. There might have been some issue with use of iron rope like maybe it was too stiff.
Take a deep breath, Glen and maybe an adult beverage to calm the nerves. Very well done and looking super.
- 194 replies
- Bottle
- Treasure Fleet
(and 3 more)
Good luck on the search, Brian. Seems rabbit holes around are always deep. Your last photo and markup have the solution. However, since this was connect the rudders and if the rigging got shot away, then turning one rudder would only move the one with the shot away rigging in one direction. Unless it was a very stiff, almost solid wire with little bend to it.
Interesting. This is one deep rabbit hole to dive down. I would think that hemp rope would have rotted away but then again, I'm no expert. If it's chain, then centers might be filled with mud/rust. The kink could be two links rusted together. Which raises a question... other gunboats of the period that have been found, what did they have? My first impression was that that part was an iron/steel rod and what's labeled "tiller" might not be a tiller
Bristol Beaufort by AJohnson - FINISHED - Airfix - 1:72
mtaylor replied to AJohnson's topic in Non-ship/categorised builds
No rush. We're a patient lot. -
Mango, Toni is right on how to mark off and plank. I'll add the following file to help out. It's a planking fan. Simple to use... plankingfan.pdf
- 20 replies
- Planking
- Lining out
Jim Byrnes Thickness Sander Operation Tips
mtaylor replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
While I don't have the Byrnes, I find that speed and feed rate play a factor as well as depth. My guess if you feel speed and feed are good, lessen depth. Also, check that the wood isn't tilting particularly near the end of the sheet. I made an extension for my sander to stop that. It's basically just a block of wood as high as the bed and sits on the output side. Edit.. I see Druxey and I cross posted. Do try the output side extension. -
Nice looking stable of aircraft. As for the Mosquito... go for it. Do a log. -
I'm not certain but I would think that they would be rare that small. The rigging, for example, would really be tiny. Now ships in a bottle is a different matter.
Looking for pre-made sails for Mamoli Britannia
mtaylor replied to Bob Lowther's topic in Wood ship model kits
Do consider opening a build log for your model. It's probably the best way to meet others and also get and ideas during the building.
