Posts posted by jimbyr
As far as pin vises go.....Starrett. Not cheap but they'll last a lifetime and the drills won't fall out. Moody also used to make a good set if they're still around.
Jim
- toms10, Roger Pellett, Bob Cleek and 4 others
- 7
Anthony
Good chisels are expensive. I have a full set of Pfeil intermediate chisels, expensive but I don't think there are any better than that. Have had them for 25 years and still as sharp as new. I also have a miniature set from the Russian fellow that sells them on this forum somewhere, they are also excellent. My 3rd set is from Lee Valley in Canada, Hirsch micro carving chisels. They are also excellent and I use them the most for all the tiny stuff. In my opinion, stay away from the cheap budget tools.
regards
Jim
Jt
If you're building her as launched
"Uss Constitution Super Frigate of many Faces" by William Bass........Hard to find
"A most Fortunate ship" by Ty Martin
"The 44 Gun Frigate Uss Constitution" by Karl Heinz Marquardt
Jim
- Canute and michaelpsutton2
- 2
I use only Cleveland and Guhring Parabolic drills in the shop
Jim
- Canute, Rik Thistle and mtaylor
- 3
This is a set of machinist angles on ebay. You can set any angle with these up to 45 degrees, most sets usually have a 1/2 degree angle also. They are 34 bucks
regards
Jim
Auxiliary Tilting Table
To mount the tilt table on your saw you must first remove the fence extension if you have one. The tilt table utilizes the same mounting and alignment holes. Position the tilt table on the fence so the dowel pins are aligned with the corresponding holes on the fence. Once you have it in place, insert the four 4/40 cap screws to secure the tilt table. The fence should now move freely from 0 to 45 degrees. To lock the tilt table at any angle, lock the two 8/32 cap screws at the pivot points front and back. Two hex wrenches, 3/32 and 9/64, are supplied to install and lock the table at any angle.The tilt table does not have a scale on it to set the angle. The best way to set the angle is with a set of machinist angle blocks. If you do not have a set of machinist blocks, you can cut the desired angle on a piece of scrap wood using the miter on the regular table top. Once you have the desired angle, place the block between the tilt table and regular table top and lock the pivots.
It is easier to use the tilt table if you mount the saw on an angled surface. A 2 x 6 or 2 x 8 x 12" long cut diagonally works fine. Cut the 2 wedges and screw them to a piece of 1/4" plywood. Mount the saw on the fixture.
Andreas
The rip fence which comes on the saw is 1/8 high or 3.175mm high and is used to rip planks. There is a removable rip fence extension that raises the height to 3/4 or 19.05mm for cutting thick stock. Since you are in Germany you should definitely get that option with the saw because if you order it later it's going to cost you 3 or 4 times the price of the extension just to have it shipped over there. The taper gauge is used to rip tapers against the rip fence, it goes from 0-30 degrees. The miter bar is the same size as the miter slide that comes on the saw and is used to make jigs. The standard package for you guys overseas is the saw, rip fence extension, metric mic stop and a few slitting blades. Keep in mind that shipping is ridiculous overseas so the best thing to do is order everything you think you need or will need in the future with the saw because it will not raise the shipping.
regards
Jim
Model Machines
- Ryland Craze, MEDDO, mtaylor and 5 others
- 8
Jack
They are for aligning the fence during assembly
Jim
hans
What's your order #
Jim
Since we opened up the website for 120V machines we have been swamped with orders. Today I put together 24 saws and that's not all we are shipping this coming week. So...please be patient. We'll get them out as soon as possible
thanks
Jim
- Canute, Rustyj, pythagoras and 7 others
- 10
We order anywhere from 600-1000 at a time
Jim
- Canute, Ryland Craze and mtaylor
- 3
- Landlubber Mike, mtaylor, dvm27 and 14 others
- 17
Richard
NAFTA expires in a few days. They have a new system replacing it. I have no clue as to what it will be like or the cost on your end. But, if you want to send the whole saw back I'll update it
Jim
- mtaylor, Canute and Retired guy
- 3
Richard
2 days and it's back on it's way to you. Are you sending the whole saw or just the table assembly
Jim
- 3
Byrne's Saw Reference (also good for other desktop hobby saws)
in Modeling tools and Workshop Equipment
Scrubby
The best way to square the fence is with a dial indicator if you have one or have access to one. The first set of instructions is for an indicator. The second set is for the machinist square.
Dial Indicator
1. Remove the fence extension, four 4-40 cap screws located at the corners, use a 3/32 hex wrench.
2. Clamp indicator to miter or cut a piece of hard wood 1/2 by 6" so it fits in the miter slot nicely
and fasten the indicator to the wood.
3. Loosen the front four, 4-40 cap screws on the front of the fence bar with a 3/32 hex wrench.
Do not loosen the back 2 screws.
4. Slide the fence up against the indicator point until the indicator spins
1 revolution and lock the front fence block with the brass thumbscrew.
5. Reset the indicator bezel to "0"
6. Slide the indicator down the fence as far as the blade center. Do not go
past the blade center, the fence starts to taper at blade center.
7. Tap the rear fence block until the indicator needle is back on "0"
8. Snug the rear fence block brass thumbscrew.
9. Recheck the fence with the indicator
10. Adjust the rear block as necessary by tapping it with a soft mallet
11. Recheck the fence with the indicator
12. Lock the rear brass thumbscrew
13. Recheck the fence
14. Tighten the front 4 capscrews
15. Recheck the fence
16. Loosen the front and rear thumbscrews and slide the fence away from the
indicator.
17. Slide it back to the indicator and lock the front thumbscrew and recheck
the fence
ALWAYS LOCK THE FRONT THUMBSCREW FIRST.
Machinist Square
2. Loosen the front and rear brass thumb screws.
4. Place the machinist square up against the front of the table with the beam up against the fence. Don't worry about the back of the fence not being up against the square, it has a slight taper to it. The fence starts tapering at the blade center.
5. Snug the front and rear brass thumbscrew. Always front first.
6. Tighten the front four 4-40 cap screws
7. Recheck the fence with the square. If everything is square lock down the front 4-40 screws. If not adjust the fence until it is square.
8. Take a few test cuts on some scrap.
regards
Jim
