Posts posted by jimbyr
MBS
Sometimes the website doesn't email the emails. Use mmllc@cfl.rr.com and Donna will send you the manual
Jim
model Machines
- BobG, bruce d, Ryland Craze and 1 other
- 4
Steve
We ship blades in 2 days. Machines take 2 weeks
Jim
Capella
Starrett or Moody, the best there is
Jim
- Bob Cleek, mtaylor, Roger Pellett and 1 other
- 4
The website email is not always working the best use mmllc@cfl.rr.com that is our direct email
Jim
- Ryland Craze, VTHokiEE, mtaylor and 1 other
- 4
I have 5 kits
1 Constructo, HMS Bounty, doesn't look like it was started, not sure all the pieces are there but probably are. ...............Sold
2 Scientific, Charles W Morgan. has been started, not sure all the pieces are there.
3 AL Swift, doesn't look like it was started, not sure all the pieces are there but probably are.
4 Blue Jacket Smuggler, looks brand new......Sold
5 Modelers Shipyard, A Schooner of Port Jackson, has been started, not sure all the pieces are there but probably are.................Sold
These kits are free, you only pay for the shipping, send me your address, first come first serve
You can PM me if you would like any of them
Jeff
These are the ones I use most, they are all Two Cherries
5303-10 1mm wide
5306-10 1 mm wide
5301-15 1.5 mm wide
5311-05 .5 mm wide
5339-15 1.5 mm wide
5311-10 1 mm wide
Jim
- mtaylor, thibaultron and Canute
- 2
- 1
Tom
I bought both sets 5 years ago when they were 1/2 price. Haven't seen it since
Jim
- 3
Tom
Yes you can buy them individually
Jim
- mtaylor, Canute and thibaultron
- 3
Jeff
If you're interested in these I'll make you a list of the ones I use the most, only about 5 of them
Jim
- thibaultron, Boatsinc2000, Canute and 1 other
- 4
Jeff
I use Two Cherries micro chisels
And i also have this set from Lee Valley
They are not palm chisels but are only 6" long and go down to .5mm and are excellent quality
Used them on this
Jim
Tooter
I have a Grizzly GO555 14" bandsaw. Have had it for 18 years, cast iron table good fence ball bearing guides and can change blades in 2 minutes. Good saw. When I bought it it was 400 bucks, now it's 795.00
regards
Jim
- Canute, mtaylor, Roger Pellett and 2 others
- 5
Looks like you would have to change the complete Sherline head stock.
https://www.sherline.com/product/30111-er-16-headstock/#specifications
It's 200 bucks and runout is .0005 - .001
Not sure I would do that.
If you're looking for an ER-16 collet chuck for something else I can recommend one
Jim
ER-16 collet chucks are compressed from the front and rear equally if you have a decent collet and chuck. They hold any size drill or endmill quite well if you use the correct size collet for your tool. I have never had one squeeze out a small endmill or drill. I have about 250 or so ER-16, ER-25 and ER-32 collets. They are all made in the USA, none of them are from China. If you use a collet with a draw bar the tool has to be the exact size or it will only squeeze the tool at the front of the collet. Good quality ER collets are the best around
Jim
Bob
It's not done yet, still have to make the stops on the quill and the lock on the other side. If it goes into production it's going to be expensive. The bearings and the ER-16 collet chuck are over 200 bucks. About 300 bucks just for the store bought stuff + material and time
Jim
Gaetan is right, most of the benchtop mills don't have the capability to drill holes. This benchtop mill is a Taig, it came with the standard head on it, no drilling. I made a new head with a quill, it has an ER-16 collet chuck on it up to 10MM capacity. It also has a 1/4 HP motor on it which will run from 600-10000 RPM and has 1 3/4 drilling capacity. The run out on the spindle is .0002 which is about the best you can get. It has a Fafnir taper roller bearing on the bottom and a ABEC-5 radial bearing on the top of the spindle and also in the pulley. I put a Newall magnetic scale digital read out on it also. The head is designed similar to the old Bridgeport M head. Also made a vise for it because the one that came with it wasn't too good. This machine is deadly accurate
Jim
Model Machines
- Keithbrad80, Bob Cleek, Canute and 6 others
- 9
John
Don't know what everyone else does but this is what I do. If you're cutting planks say 3/16" wide x 1/16 thick what I do first is cut my stock from a billet on the band saw about 7/32 wide x 2" . Then I run them through the thickness sander down to 3/16" so now I have a piece of stock 3/16 x 2" + or -.001 on the 3/16 thickness. Then to the saw with a 3" .03 slitting blade and cut the planks 1/16 thick. After you glue the planks on you're going to sand them so the 1/6 thickness really doesn't matter much
regards
Jim
- Bill Tuttle, mtaylor, Roger Pellett and 3 others
- 6
Actually I wouldn't approve using the saw as a flat plate. You can get a granite surface plate in many sizes which are flat within .0003. I have an 18 x 24 plate I got at an auction for 25 bucks, flat as a pancake. You can glue on it and make a mess and clean it off with a scraper and lacquer thinner. Won't harm the plate at all. If you shop around you can get a new one 12 x 9 for about 30 bucks. Here's a 12 x 18 on Amazon for 100 bucks and free shipping. weighs 90 lbs.
regards
Jim
Band Saw Recommendations
in Modeling tools and Workshop Equipment
Chris
I use the grizzly G0555. It has bearings on the blade
Jim
