Old Collingwood
  1. Evening all, double tasking today - So I sanded the wing/fuselage join, then I fitted the airbrake assembly, and the tailplanes. OC.
  2. Evening all, Last stage of this build - I finshed making the tow ropes, these were fiddly little fellas as they are made of thread, this needed re-twisting then gluing to keep the shape, then the ends were glued, I then had to manufacture Two clips to hold them at the back - but was able to use the Two original ones from the kit (the other Two went missing). I then painted and weathered them. So I am calling this Finished. Sincere thanks to all the feedback and help encouragement with this build - it was a great model to build and am I looking forward to the M1 kit "oh yes deffo" So here are the last pics of it. OC.
  3. That is looking so nice Alan - that soft edge masking has come out spot on. OC.
  4. I think it must be that Terminator freezing type thing were the join can just be snapped clean off. OC.
  5. We have all been there Denis - I cant count the number of kits that were trashed when things went wrong for me - at least you was able to save it - and to be fair - I could not tell the mistake without you mentioning it - thats a credit to you for fixing it. OC.
  6. Thanks Mike, I think its all down to practice and getting to know what you can do with whats you have to hand. OC.
  7. Thank you kindly Mike, I have a wee bit more to do to it yet - might do another figure for it as I have the set. OC.
  8. Looking good Denis - lots of yummy detail there. OC.
  9. Evening all, we bit of progress - the bird has wings - I started off painting/weathering the wheel wells, then the wing assemblies where contstructed, then glued in place, I tiny bit of putty in a hair line gap - but not a bad fit, still needs a bit of sanding to blend the lines. OC.
  10. Good to see you back on this - sometimes a second attempt is what it needs - sometimes for your own piece of mind. OC.
  11. You have got the patience of a saint - you know that saint with lots and lots of patience. OC.
  12. @king derelict Thank you kindly Alan, they are very nice kits, always liked their accuracy and the way they go together - both this and my Chinook are both Italeri. OC.
  13. Evening all, more progress - I fitted the intakes the after the join had dried I sanded and blended them, next was a panel that fitted under the wing that contains some good wheel well detail. OC.
  14. Thank you kindly Mark, they are the pre cut masks - just have to remove them from the backing paper and place them, they are a bit fiddly but saves having to cut out your own. OC.
  15. Evening all, I managed a couple of hours on the hawk, I firstly masked up the cockpit glazing then again using some wire I ran some glue along the edges and glued it down, after it had set I noticed a slight gap at the rear so I used my Vallejo putty - its very good on fine cracks/gaps as it can be cleaned up immediately. So this is where I am at present. OC.
