"sore fingers and muscle y arms" are appropriate terms for the result of the next stage. OC.
- 505 replies
- vanguard models
- Sphinx
1/48 Italeri Hawk T.1A (On Hold)
Old Collingwood replied to Old Collingwood's topic in Non-ship/categorised builds
Thank you Alan. OC. -
Evening all, spent more time at the bench today - first job was to wet sand areas where the first primer went down rough with splats and over sprays - actually took quite a bit off, then after wiping over I decided to give it a go again - my airbrush was now working as it should - but I am learning its about practice getting the right layer/s down without runs or build ups and also difficult placing the model - I had to sit it on a small box ontop of my rotating spray table spraying the top side first - drying with hairdryer then turning it over and spraying the underside - outcome - still some over sprays and marks from where the plane rested on the box. So some more light sanding to do and a bit of isolated spraying. Fun and games folks. No pictures as I am not happy showing it at this stage. Think I prefer my figure painting as I have more control over them with a hairy stick. OC. -
@king derelict Alan I have one of those spray jars with a sealed top that you can spray into to clean the airbrush, I use a mixture of warm destilled water and my cleaner usually by filling up the bowl a few times and spray into the jar till I get that sound telling me just air is running through it I then spray it against the side wall of my box booth to check if any liquid/water is stil coming out, I do that a few times. I think the culprit is the Vallejo Acrylic Surface primer as the small dried paint flecks that where in the nozzle where Black and thats the only Black thing thats been through my airbrush - wonder if I could thin the primer down a bit say 30% so it flows better even with my flow improver bottle (this gets a few drops per cup of paint) All a learning curve for me. OC. -
D9R by Kevin - Meng - 1/35 - PLASTIC - started 2015
Old Collingwood replied to Kevin's topic in Non-ship/categorised builds
Looking forward to this Kevin. OC. -
Evening all, so more bench time - I fitted the last of the small items then I reached primer time, my feeling at this time was😀 as I love using my airbrush, any way I mixed some of my primer along with some flow improver and first aimed it at the side wall of my cardboard spray booth and the airbrush was blowing bubbles with no paint coming out the nozzle, so I emptied it out and took my airbrush apart and cleaned it again, then I tried again - it was sparying agian but not at all smooth it was splattering - thank good ness it the primer and can be sanded. I decided it was best to do a full clean of the airbrush so I took every part of it out and using my cleaner I found little bits of tiny dried on paint flecks, after the deep clean I put it back together and ran some water through it - all good again more air was now running through it. Tell you what I spent about Five minutes spraying the model and about 2 hours cleaning the airbrush - they so need so much attention and not just by spraying through cleaner and water after paint - looks like it needs stripping down after every paint session. OC. -
As Jack said - its our yearly Bonfire Night - always a bad time for our dog as the banging really upsets her. OC. -
Evening all, some more progress done in between trying to settle our little pooch who was terriefied by all the Fireworks going off around us, poor thing was trying to find somewhere to hide - we had to have the TV volume way up to try to help. So It was Flaps time - they are positionable up or down, the flap actuation arms come in Two different shapes in the kit, I decided to make them dropped - bit fiddly getting them ligned up, but after a bit of adjustment - they are on. OC. -
Evening all, double tasking today - So I sanded the wing/fuselage join, then I fitted the airbrake assembly, and the tailplanes. OC. -
Evening all, Last stage of this build - I finshed making the tow ropes, these were fiddly little fellas as they are made of thread, this needed re-twisting then gluing to keep the shape, then the ends were glued, I then had to manufacture Two clips to hold them at the back - but was able to use the Two original ones from the kit (the other Two went missing). I then painted and weathered them. So I am calling this Finished. Sincere thanks to all the feedback and help encouragement with this build - it was a great model to build and am I looking forward to the M1 kit "oh yes deffo" So here are the last pics of it. OC.
