1/48 Italeri Hawk T.1A (On Hold)
Old Collingwood replied to Old Collingwood's topic in Non-ship/categorised builds
Evening all, double tasking today - So I sanded the wing/fuselage join, then I fitted the airbrake assembly, and the tailplanes. OC. -
Evening all, Last stage of this build - I finshed making the tow ropes, these were fiddly little fellas as they are made of thread, this needed re-twisting then gluing to keep the shape, then the ends were glued, I then had to manufacture Two clips to hold them at the back - but was able to use the Two original ones from the kit (the other Two went missing). I then painted and weathered them. So I am calling this Finished. Sincere thanks to all the feedback and help encouragement with this build - it was a great model to build and am I looking forward to the M1 kit "oh yes deffo" So here are the last pics of it. OC.
Evening all, we bit of progress - the bird has wings - I started off painting/weathering the wheel wells, then the wing assemblies where contstructed, then glued in place, I tiny bit of putty in a hair line gap - but not a bad fit, still needs a bit of sanding to blend the lines. OC. -
Thank you kindly Ken. OC. -
Good to see you back on this - sometimes a second attempt is what it needs - sometimes for your own piece of mind. OC.
- 25 replies
- United States
- JSC
You have got the patience of a saint - you know that saint with lots and lots of patience. OC.
@king derelict Thank you kindly Alan, they are very nice kits, always liked their accuracy and the way they go together - both this and my Chinook are both Italeri. OC. -
Evening all, more progress - I fitted the intakes the after the join had dried I sanded and blended them, next was a panel that fitted under the wing that contains some good wheel well detail. OC. -
Thank you kindly Mark, they are the pre cut masks - just have to remove them from the backing paper and place them, they are a bit fiddly but saves having to cut out your own. OC. -
Evening all, I managed a couple of hours on the hawk, I firstly masked up the cockpit glazing then again using some wire I ran some glue along the edges and glued it down, after it had set I noticed a slight gap at the rear so I used my Vallejo putty - its very good on fine cracks/gaps as it can be cleaned up immediately. So this is where I am at present. OC. -
Thank you kindly Dan. OC.
