Piet - that means so much to me Thank You, all my friends in here are so invaluable and feel like an extended family, I have Never felt so cared for. OC.
It makes a Massive difference jack and as carl knows - I force dry my paint layers between each coat using a hairdryer, also try alternating the painting direction anotherwords - first layer front to back and around obstructions the apply heat, then the second layer from back to front and again around obstructions then apply heat again - and just repeat till you see a dried smooth finish. OC.
- 140 replies
- the sullivans
- trumpeter
Jack what I did with Warspite build - was to thin the paint and apply it in almost watery (well like thin milk) it looks like it isnt covering with the first layer or two, but as you apply more thin layers it does even out and give a smooth but not over thick finish. I love working with these - Acrylic paints, they come in gift sets designed to match certain naval colors of different time frames. Hope this helps a bit. OC.
- 140 replies
- the sullivans
- trumpeter
Thanks jack, yep diabetes can certainly be a minefield, my late farther died some years ago as a dirrect result of it, basicaly it destroyed all his organs. OC.
Thanks jack, the wife is also on a good mix of other important drugs she has to take all her life, the diabetes was the last condition to be detected - just last year, she has also been told the side affects of some of her drugs could leed to insuline issues, our diet is quite good very little sugar quite a lot of chicken and just a treat once a week when I cook a chicken curry. The problem the admiral has is a constant dry mouth (again due to her medication) so she is constantly looking for things to cure her dry mouth, she tries water but she cant stomach it (she hates it) so she started resorting to zero sugar fizzy drinks like cola, we have been weining her off these and resorting to to normal tea no sugar with skimmed milk. OC.
Thanks for all that - much appreciated - when I get to the docs tomorrow and get a replacement meter and strips, I will tell the admiral to check herself in the mornings (if she gets this one to work as it should and not eat through a million strips) OC.
The admirals was 19.1 last night when the ambulance checked her, and 18 today when the Fast responder checked her, but we are not sure what her normal range might be. OC.
The two the wife has are called TRUE You, they are basicaly the same as the one you shown. OC.
Thank you denis, yes she has two of those machines (look like a large cycle computer) they have those sharp pins that like you say prick the finger then you are supposed to put a small speck of blood on the end of a plastic strip - that is inserted into the machine, but however we have tried over the last 12months we cant get them to be accurate, so I have to get - yet another one from the doctors surgery tomorrow. So needs an easier machine thats less finnicky. OC.
A huge warm thanks for the replies about the admiral - it was her Diabetes causing all sorts of problems from sickness/diarrhea/dissyness, she was still rough today so I called a Fast Respnder out who stayed with us at home for over an hour, she was checked thoroughly but was decided it wasn't serious enough to go back to hospital - instead our local doctors surgery was contacted by the Fast Responder requesting a Doctor to come out and review the admirals diabetic situation - not long had a call from the surgery, no doctor could be found to do the home visit and I have to go there in person tomorrow to pick up a new diabetic test machine, and to ask then about her diabetes as she is not strong enough to visit the surgery yet. Appologies if that didn't make sense I've not been to sleep yet since Tuesday Night.😵 OC.
Was planning to attack the gun ports/ropes today but instead I spent some time in A/E at the hospital with the wife, as she had a bad spell with her health and I had to call 999, they sent out a First Responder who checked her over and rang for an ambulance, we were taken on the hour ride in an ambulance to hospital and arrived home after getting a taxi after 11pm. So slightly different day/evening. OC.
Evening all, more progress today inbetween playing with the dog, I found the right thickness of thread - then started to attach the handrail ropes, these runs were tied off at both ends with loops and pva inbetween, when all were done I applied some paint to blend them in. I think they turned out ok - even the odd ones. Just a couple of pics. OC.
