I agree with denis - way worth it they show very well the painting you did. OC.
- 467 replies
- mikasa
- wave models
Thank you for the kind words denis - really appreciate it, are you on about the four casements on each side below the main deck level? these were removed late 43 and just left their casements, the openings for the barrels was plated over and the casements were turned round leaving a smooth round appearence, they used to house 6in units but was decided they were not needed hence their removal. OC.
I use a small round (pointy) stick to admisnister ca - I make a puddle of it in an lid, then just dab the end of the stick in it then dab it on where I want it, this way I can control how much glue goes were I want it. OC.
- 1,090 replies
- showcase models
- vendetta
Amazing work, even if you was not skilled at wood carving - you are now, some people either have the skill or do not, you certainly Do my friend, very very nice. OC.
- 961 replies
Thanks greg, your so right there, what bugs me is the dust, no matter how many times I blow it off - its always there in my pics, sometimes its dust thats settled in the paint during application though. OC.
Oh! I just noticed - I need to squeeze those barrels in slightly, they are slightly out of true. OC.
Good evening all, quite a good day today on the ole girl, first I did a bit of tidy up with the placement of the hanger block, there was some placement lugs on the deck getting in the way of letting it sit properly on the deck, but I have decided to leave it off till one of the last jobs. I decided instead to create turrets x and y these are made up of the kit main parts, and the master barrels. First thing to do was to drill out a few of the sights that are missing on the kit turrets, this was done with a 0.5mm drill bit (after going crossed eyed doing it) then I fitted the rangefinder units to the turret, next item for my attention was the blast bags, these are well known in the kit to have the wrong alignement for the barrels (being below 0deg elevation when fitted oob) so I decided to cut away the the parts of the bags that lock into the turrets, this allowed me to sand a better angle on them allowing me to set the barrels at a higher elevation. Next I glued in the master barrels and set the correct alignemnt - the barrel/blast bags were then glued onto the turrets. On both turrets there are (two each) oerlikon round and part round shield tubs, these are two different hights due to the elevation of the x turret, these were glued inplace and adjusted for the correct alignment. So as we stand at the moment the turrets are just awaiting pe platforms under the rangefinder units on turret x, a couple of ladders and escape hatch covers, then painting (jobs for tomorrow). OC.
So, decisions - decisions tomorrow - do I glue down the completed hanger/boat block or leave it off till I have built the main tower block? OC.
Hi everyone, more work today on the 4in mounts - I painted the two that were constructed consisting of light grey inside and fittings, black breech and barrels, and mid grey outer, then when dry I fitted them down onto the deck, next was to construct the other two. Here are a few pics showing them and the two unpainted ones just dry fitted. OC.
If it was me I would paint them just for my own satisfaction that they were painted, otherwise it would bother me that they were not painted. OC.
- 467 replies
- mikasa
- wave models
Sods law - In a few days time or even weeks when the ship is built, while playing with ones dog or cat on the floor - said parts that went missing will turn up. OC.
- 1,090 replies
- showcase models
- vendetta
The cursing comes with the exhale of breath if somethings gone wrong - or a sigh of relief if the other. OC.
- 1,090 replies
- showcase models
- vendetta
Looking good denis, pe is our personal battle zone, it does help our breathing tech though - well does mine when I hold my breath while working with pe. OC.
- 1,090 replies
- showcase models
- vendetta
More work today - first I attacked those saggng lines, I just adjusted them slightly and applied more ca - did the job I think, then I had a change of plan with the paint scheme on the mast, I decided to paint the mid upper part black and keep the lower and extreme top light grey, next I attached the ladder to the mast and considered it a done job. Next was to carry on with the main deck under the hanger/boat deck, this is the general area where the 4in gun mounts live, first I built four pe boxes and attached them to the armour shields, then I painted and placed two ammo casses in the mid area(Still needs a final coat on the boxes, then I turned my attaention to the 4in mounts. These mounts include the Master barrels - first I had to cut away the kit barrels just leaving the breeches, then I had to drill nto them with a 0.5mm drill bit - then I just glued the barrels using ca checking the alignment, then while these were setting I had to work on the base for the mounts just a quick tidy up, then when the the glue had set I was able to attach the two shoulder mounts and glue it down to the base, then just a simple job of gluing on the cover. Another batch of pics today showing the process so far. OC.
Yep guess so, I was trying to make do with what I have for now, as I have a small lit of things I will ned to finish her. OC.
Thanks pat, apart from the sagging cables - I am tempted to try to get them taught again tomorrow. OC.
Thanks mate, bit of a backward step though - due to me trying to rush more work to the mast area, I knocked it a couple of times on my magnifier as it was quite low to my build, and the wires have streached and are now sagging, cant realy correct it as doing so will spoil things. So they will have to remain as un-tensioned cables. OC.
