Evening all, a bit more progress today this time on the hull, first off I ftted the last two booms - simple operation just cut from the fret trim up and glue in place then painted hull color, next was the two main anchors and the spare one - these are the kit plastic ones as they are quite a good shape, I trimmed the pips of the edges and gave the edges more shape, then I attached the shank uisng ca for strength, then I painted all three the same color as the hull and added a slight dry brush on the edges, then I glued them into place. Next I decided to have a go at some paravane cables, first off I needed some very fine wire - so I found a way to create some, inner brass wire from low voltage wiring (like phone chargers) I found an old one with about a meter length so it was just a case of stripping the outer casing then each positive and negative till I found the brass inner thin wire, I cut a length about a 8 inches long, then I centered the mid point around the inner first bollard and added a touch of ca to the wire, this held it in place, then I pulled the wires forward and over the extreme front hull and down to the bottom of the hull and fixed them from both ends into the anchor hole points. Then a coat of flat black. Just the two pics today.
Planing ahead for my work tomorrow - I will take off the boat/hanger.crane block and put it aside, then with the hull without too many obstructions or delicate parts, I will work on the anchors then paint and fit them, the same with a few of the hull booms that need wok on them and a bit of paint then fitting. Then back on the deck I will be able to start working on the main mast and the Type 281 RDF radar from my pontos frets, I will also use some of the other pe details but will substitute the plastic masts and beams for wood dowel versions, as I have a few from my wood kits that will give a little bit more strength over the plastic ones. OC.
Thanks mate, yep I worked on the cables to get some sag in them by gently pushing down and runing a tooth pic type device along the cable, also applying heat helps. OC.
Hi all, so after a slow start earlier - I managed the complete and fix in place the second crane, so this complates the hanger/boat/crane block. OC.
Thanks for that lou, I will see if I can try that - it might not work out too well though, as I only have a small amount of paint left in my Lifecolor tubs so I dont think I would have enough paint to dip the other boom into, the build has used up almost all my paint so far also allowing for shrinkage as the set of paints is over 3 years old, I will have to put another paint set on my (needs to finnish the build list) so far that includes those Shapeways 20mm Oerlikons, some very thin wire for the comms wires then my display case. OC.
Stunning work as usual, she is going to be such a museum quality exhibit when finished. OC.
- 467 replies
- mikasa
- wave models
Good day friends, crane number one complete and fixed inplace, from where I left off i had to fit the two control cables, this was tricky as they are preformed pe parts with wheels on both ends, but they are too long - so I glued the one end then when set I secured the other end and applied some glue and trimmed off the the excess. Next I applied a few coats of paint starting with the lattice boom (trying to hand paint inside this is awkward) then I painted the cables and the drum flat black - whils't using the black I painted the end of the boom aswel. then it was the turn of the cranes body - this too was painted the same as the boom. When dry I fitted it to the deck. Here are a few pics with it fitted. OC.
Have you got the full pe intructions (Pontos)? OC.
- 467 replies
- mikasa
- wave models
She is moving on mate lots of detail going on now. OC.
- 1,090 replies
- showcase models
- vendetta
Upsss - should have said outside cooking device and hot dogs arn't they called chilli dogs or something. OC.
I will bring our sofa and leg support - where can I park that? I will of course bring our barbi complete with a few thousand hot dogs and burgers, so plenty to go round. OC.
Evening all, I started work on the cranes today I decided to make the kit one and compare it to the pe version, after cleaning and thinning some of the support struts, I decided to go with the kit one, I decided to make up some platform gantrys also some railings, not foregeting the ladder, also I added some pe bits and pieces just to give it some detail. Next off was the actual crane lattice boom, this is a alum pe part that comes with the kit, the main part is folded in three and then has the bottom glued to make up the box work, then there is a upper sheave with control wheel that I fitted on both sides, I even fitted the hook up inside the sheave. Here are a few pictures showing the state of build minus the guy lines. OC.
Thank you kindly lou, its supprising just how small the pieces are, and the level of dexterity just to hold them takes some doing. OC.
Doesnt stuff look excellent at this scale - so much detail. OC.
- 467 replies
- mikasa
- wave models
1/200 aicraft should be superb to super detail, I once built a kit in that scale of a C141B streached starlifter transport plane. This - http://dragon-models.com/d-m-item.asp?pid=CHC2013 OC.
- 29 replies
