Old Collingwood
  1. "Its looking realy good exciting like a book - amazing what all that work took" there you go I sang it while playing along on my keyboard OC.
  2. What i intend to do is - make my ole girl with one hand while taking pics outside with the other - while recording onto my tascam from my keyboard with the other two hands OC.
  3. Hi folks just saying hi Im still around just showing another reason for my distractions of late - I write music and here is another of my new toys to play with OC.
  4. Dont know about the Amazing work you have done - but I can read how old you are by your rings OC.
  5. Keep going you can do it - we will all join you for a slipway lauching party :) OC.
  6. Helps if the paint (acrylic) is watered down to thin milk consistancy I understand. OC.
  7. We have a nice little family building here, Im still here just been a bit disstracted by my little camera and intermitent spells of blue sky and aerolplanes flying over at 30.000 feet and setting the challenge to myself of catching a photo of the pilot waving at me OC.
  8. Seasons greetings greg have a peaceful healthy time and a great start to 2017. OC.
  9. Hello David sincere warm greetings to you hope you have a loverly christmas, Its all your fault - after seeing the Fabulous Warspite from up north, you got me hooked and obsessed with the ole girl All my inspiration is from that Amazing pice of artistry going on with her, just hope I can in any small way pay tribute to her Kind regards OC
  10. Could be your card or reader - is your card connected directly in a slot in the comp or via an external card reader, take either/both out and check condition of the contacts(brass shiiny sections where you plug in) make sure they are clean - if not give them a clean with a cloth, then either try re loading or re try with new shots in the camera after cleaning the memory card. Might work give it a go. OC.
  11. I only have the one telescope i meen lens for it, so im affraid we will have to do with my cam phone pics. OC.
  12. I cant see a problem there from the photo to be honest it looks realy nice and as it should look, but guess you are same as me an don close inspection we want better and worry its not good enough. OC.
  13. Yep 300mm quite average size these days but the camera helps having 24mp. OC.
  14. Its a Fixed length prime lens 300mm f4 none Vibration Reduction but fine if used with a shutter count over 1/500sec hand held. OC.
  15. Can i Take a Bench with a Fridge at the side of me - I promiss not to get confused with my other medium, any way "Whats this one called again" - Wool, Woop, Woof I mean Wood, yes that not so heard of material that a few ships where built from for a time :P OC.
  16. Looking great my friend, all the PE makes such a difference even if maost of it is heart stopping while working with it, I think my heart stops while messing with it OC.
  17. Not much to say so I will let these photos say it all - port and starboard Tubs fitted. OC.
  18. Interesting - I'm sure I have seen many times mentioned on forums for plastic modeling, that PVA is good to attach PE railings aswel as CA. OC.
  19. Next was to give both Tubs a couple of coats of light grey, of note is the lack of 20mm machine guns as they were not carried in certain Tubs during D Day, I would imagine this was due to the channel having UK and American air superiority over those areas, hence less need of fire cover. Here is a pic showing the light grey paint finish on the Tubs. OC.
